#29 |
Vampire taps should do it. I didn't solder anything.
Sent from my SGH-M919 using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#30 | |
Drives: 2014 Subaru BRZ white limited
#31 |
Well the way I have it is where the V is on with parking lights, the middle light comes on with braking but does not flash. I didn't want that. If you want the F1 flashing, you might do it a bit differently.
You can see in post #6 what the vampire taps look like. Been running it since that day, zero issues. |
| The Following User Says Thank You to SPCorBUST For This Useful Post: | Frank5364 (05-11-2014) |
#32 |
So you connected it to the car's wires not the tail lights right?
#33 |
Not sure I know what you mean?
#34 |
Drives: Scion FR-S Whiteout Automatic
So, mine doesn't come with the extra blue wire and it seems my light is mapped differently... Anyone know how to follow post #22 with my setup? |
#35 |
Drives: 2025 BRZ, ex-2012 GT86
Thanks again for the DIY. Works flawlessly. Here is the video on mine after the mod:
[ame="https://www.youtube.com/watch?v=JXNvwhIJHTQ"]Valentis with F1 Brake Light Function - YouTube[/ame] Last edited by Efferalgan; 09-14-2014 at 05:38 PM. |
#36 |
Drives: Scion FRS Firestorm
Hey guys, i opened up my reverse light to do the rewiring for v on with park lights, triangle with flashing on braking, and normal reverse. But my wiring is slightly different than what some previous poster showed. My red and orange wire are flipped. How should i proceed?
#37 |
This is what i ended up doing. Haven't tested yet. But i believe it is right.
#38 |
The wiring above worked for me for others references.
#39 |
Drives: 2013 FR-S in Whiteout
OK,so I think I messed up... By unplugging all my connector's b4 I started the rewiring process. My light was just like the one above.. Any help? One is obvious since it has two females and one male coming from the light,the other 2 not sure
#40 |
#41 |
@ANTLAY I just followed the instructions a few pages back. Upload pics so i can help. What are your goals for lighting?
#42 | |
| Tags |
| rear fog, valenti |
| Wiring BRZ rear fog light to only come on with front fogs | Scenic Driver | DIY (Do-It-Yourself) Guides | 4 | 09-12-2015 10:36 AM |
| Valenti Japen LED Reverse Tailight USDM Wiring | Furtive | DIY (Do-It-Yourself) Guides | 12 | 08-21-2015 10:31 AM |
| Valenti 3rd brake light wiring | SPCorBUST | Southern California | 4 | 09-24-2013 12:57 PM |
| Valenti Tail Lamps and Tommy Kaira Rear Spoiler | harajukukei | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 06-04-2013 08:01 PM |
| Alternate TRD Rear Bumper Possibilities | Breeze Loo | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 05-06-2013 02:06 PM |
