Old 09-22-2013, 01:10 AM   #29
phloozy
phloozy's Avatar
Drives: Scion FR-S
Originally Posted by lbroskee View Post
are these lightweight? curious on differences between these and the ones FA20CLUB is putting out
They are very light, less than half the weight of the stock 75mm. No measurements from me though
phloozy is offline   Reply With Quote
Old 09-22-2013, 06:33 AM   #30
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by xjohnx View Post
I'm using both Mike and Delicious Tuning's tunes, e85 and 93, although i'll likely be sticking to 93 for the most part.
No meth at the moment.
Mike's tune looked like it was going to put down about 250 on E85 w/ the 75mm pulley but we had to stop the runs early because of some dyno issues.
What are you doing to mitigate knock? Intercooled? Or is the knock manageable at that boost level and 93 octane?
Old 09-22-2013, 09:29 AM   #31
xjohnx
Grip>Slip
xjohnx's Avatar
haven't installed (or received) the pulley yet. I'm not sure that I will right away either. It was somewhat of an impulse purchase. Although, my IAT sensor and sensor plate should arrive from fa20club the same time as the pulley and map sensor, so perhaps with accurate IAT data (and cool early fall weather) will make it do-able in the mean time.
Old 09-22-2013, 10:03 AM   #32
Calum
That Guy
I impatiently await your IAT results.
Old 09-22-2013, 10:26 AM   #33
xjohnx
Grip>Slip
xjohnx's Avatar
you and me both. i got the tracking number 2 weeks ago so i thought it would've been here sooner but i know toni was slammed so i can see how making the harnesses for these may not have been a top priority. I'll post results as soon as i have them. I know William at Delicious said he'd need to update the tune and get his hands on one of these cars with the IAT sensor installed in person before he'd be able to update his tune for it though.
The Following User Says Thank You to xjohnx For This Useful Post:
Calum (09-22-2013)
Old 02-12-2014, 05:55 PM   #34
KSpider
KSpider's Avatar
Drives: '14 S4
Do you think there is going to be any issue with this blemish/chip in regards to belt wear? I purchased this as a blemish, so no complaint there, unless it is going to cut my belt over time ; )
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
Old 02-12-2014, 06:09 PM   #35
Raceseng
Raceseng's Avatar
Kspider - The portions of the pulley that are bare aluminum have been filed by hand to get rid of the raised portion on the v groove.
They will function fine and not tear the belt. If you are still hesitant, you can gladly return the pulley. We are sold out right now but are in the midst of doing a production run.
Thanks!
Raceseng is offline   Reply With Quote
The Following User Says Thank You to Raceseng For This Useful Post:
KSpider (02-12-2014)
Old 03-03-2014, 05:12 PM   #36
jc1993
Drives: 2013 all stock frs
is this safe on stock frs?
jc1993 is offline   Reply With Quote
Old 03-03-2014, 05:19 PM   #37
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
it is very safe for a stock frs.
supramkivtt2jz is offline   Reply With Quote
The Following 2 Users Say Thank You to supramkivtt2jz For This Useful Post:
jc1993 (03-03-2014), SkAsphalt (03-03-2014)
Old 03-03-2014, 05:28 PM   #38
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Ha!
JC this is meant as a bolt on addition to a super charger, not at all for stock cars.
Old 03-03-2014, 05:38 PM   #39
jc1993
Originally Posted by SkAsphalt View Post
Ha!
i know bro wat i meant by stock is stock block... pretty much do i have to worry bout my bby blowing up
Old 03-04-2014, 09:59 AM   #40
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
If that is what you meant, you probably should have wrote that down.
Old 03-09-2014, 04:34 PM   #41
jc1993
why else Would i say stock bro if its a s/c pulley
The Following 2 Users Say Thank You to jc1993 For This Useful Post:
ScionFamily (03-10-2014), SocalMonsta (05-20-2015)
Old 03-10-2014, 10:34 AM   #42
harkbrz
Drives: Subaru BRZ 2013
Fight Fight Fight Fight
harkbrz is offline   Reply With Quote
Raceseng | Revo Engine Pulley Product Release Raceseng Engine, Exhaust, Transmission 50 01-09-2015 02:24 PM
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Raceseng | 70mm and 72.5mm Innovate Supercharger Pulley Raceseng Engine, Exhaust, Transmission 6 09-19-2013 05:56 PM
Raceseng | Revo Engine Pulley Group Buy Raceseng Groupbuys 68 09-17-2013 12:04 PM
Daily driver dyno and modifications review (Raceseng pulley update) Fofofawcett Engine, Exhaust, Transmission 12 08-29-2013 10:57 AM
