Old 08-15-2013, 10:10 AM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by lexusb3 View Post
You need a good nights rest the day before lol
That is what the beer is for.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Draco_PR23 (08-17-2013), ecko04 (08-15-2013)
Old 08-15-2013, 10:23 AM   #30
Dezoris
Dezoris's Avatar
backup injector o rings incase one sheers off during install. happened to me and fuel was pouring out.
The Following User Says Thank You to Dezoris For This Useful Post:
ecko04 (08-28-2013)
Old 08-15-2013, 10:29 AM   #31
lexusb3
Drives: FRS
Well I had a beer while putting on my new tires the sticky bf Goodrich I have now and I put on tire on backwards -_- FYI there are directional lol dam beer or should i say beers !
lexusb3 is offline   Reply With Quote
Old 08-15-2013, 10:33 AM   #32
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Part number?
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 08-15-2013, 10:41 AM   #33
lexusb3
Drives: FRS
Also not just for u but everyone else I work at toyota corp so i can get all the toyota parts and engine code diagnostics etc etc just saying so u can always hit me up I'm always online or it goes to my email
The Following 2 Users Say Thank You to lexusb3 For This Useful Post:
ecko04 (08-17-2013), Sportsguy83 (08-15-2013)
Old 08-17-2013, 12:12 PM   #34
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by PStaff716 View Post
Very interested to see your #'s with the 57 trim. I am leaning 60 trim (if I could ever get enough $ saved lol) but I want a little more torque. What are you hoping to make? I am trying to aim for 300whp and 240tq. Just enough to walk away from all the wrx's and g37's in my neck of the woods. I figure ill need a bunch of supporting mods unless I roll with a bigger turbo or higher boost, which I'd rather avoid. @lexusb3 had great results on 5.3psi
Good luck with the install btw, hope its smooth sailing for ya bro
I'll post numbers once they're available. I won't be dyno tuned until sometime towards the end of September, beginning of October. That's assuming the kit arrives in the next 2 weeks or so. What's holding me back is I don't want to pay the dough to be dyno tuned ~$750, then upgrade to a 3" header-back exhaust ~$1100+, since i'm still stock now, and pay to be dyno tuned again due to the VE changes ~$550. Until that time, I will let @FA20Club eTune me to get me set until that time.
I'm a fairly conservative type person, I don't have any set power goals. I estimate anywhere between 270-300 whp and 220-240 wtq on my set boost target of 7-8psi. Yeah, I know, wimpy amount of boost but that's all I truly want. My car will never see a track, i'm not that kind of guy. I watch NASCAR in person when I want to see the track.
The Following User Says Thank You to ecko04 For This Useful Post:
PStaff716 (08-17-2013)
Old 08-17-2013, 12:18 PM   #35
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
There are still a few things I need to buy to prep for the install. I need to get some port injector o-rings like @Dezoris suggested. I'm in contact with someone that can hopefully find the part number for me.
I also need to figure out what type of oil & filter I want to use. I feel that ENEOS Sustina may not be the best for the boosted application. Being up in the mid-Atlantic, I don't know what to go with. After all snow starts to fall somewhere towards the end of October and won't let up until May.
I need to add a vacuum manifold, additional sensor for oil pressure to integrate with the P3Cars Gauge, catch can (AOS) which i'll probably go with what @ATL BRZ uses with the Moroso AOS.
Probably in the Spring is when i'll look to add some other supporting items like a Koyo radiator and oil cooler.
Old 08-17-2013, 12:20 PM   #36
lexusb3
Drives: FRS
i use the oem oil filter
Old 08-17-2013, 12:23 PM   #37
xjohnx
Grip>Slip
xjohnx's Avatar
It should be a standard 11mm injector o-ring. NAPA will have them.
The Following User Says Thank You to xjohnx For This Useful Post:
ecko04 (08-17-2013)
Old 08-17-2013, 12:25 PM   #38
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Thanks a ton for that info. I'll pick some up.
Old 08-17-2013, 12:30 PM   #39
xjohnx
Grip>Slip
xjohnx's Avatar
While we're talking about part #'s for o-rings, NAPA part # 2-12093 is the part number for the o-ring (qty 2) that can be used on fuel pump installations. haven't read the thread to see if you're planning on upgrading the pump though.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
ecko04 (08-17-2013), Sportsguy83 (08-18-2013)
Old 08-17-2013, 12:31 PM   #40
lexusb3
Drives: FRS
toyota
Part#Fu00300322 Port
Part#FU00300335
@ecko04
The Following User Says Thank You to lexusb3 For This Useful Post:
ecko04 (08-17-2013)
Old 08-17-2013, 12:34 PM   #41
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Yep upgrading that too.
Hopefully the small stuff like injectors and fuel pump will ship before the best of the system. I would like to already have them installed. Thanks again!
Old 08-17-2013, 12:55 PM   #42
xjohnx
Grip>Slip
xjohnx's Avatar
I'd definitely recommend doing the pump before everything else. that way you've got some time to identify any potential install issues. The injectors might be more difficult as i'm guessing you'd need a separate new map to run your new injectors before installing the FI kit.
Quick and dirty guide to track prepping your car CSG Mike Tracking / Autocross / HPDE / Drifting 166 04-05-2022 01:12 PM
Where to install amp in FRS? mit_peid Electronics | Audio | NAV | Infotainment 10 03-24-2013 01:01 PM
KW V3 on my car install ft86me DIY (Do-It-Yourself) Guides 0 03-12-2013 09:36 PM
prepping for winter Celica00 Scion FR-S / Toyota 86 GT86 General Forum 24 09-27-2012 08:17 AM
Prepping for rear spoiler install? zooki Cosmetic Modification (Interior/Exterior/Lighting) 2 09-02-2012 03:56 PM
