#29 |
Drives: scion fr-s
@Cjymiller
were the nuts/bolts needed for this? i thought the self tapping screws would be enough. would too like to see an under body shot of the screws/bolts placement if possible. thanks! |
#30 | |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
![]() As for the front lip, mine is fastened with all nuts and bolts (no self tapping screws), the same as show in the picture above. You must pre-drill all the holes and then tighten the nuts and bolts with wrenches. This is more difficult with the bumper on but I didn't want to run the risk of having a mis-fitting bumper upon reinstall.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
#31 | |
Drives: scion fr-s
so you have to drill holes for the bolts on the skirts too, correct? |
#32 |
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Technically yes. But here's a tip: only drill the front and back t use the bolts and use 3M automotive tape in between.
#33 |
Drives: Series 10 FR-S
Chargespeed Rep?
#34 | ||
Original 2013 Owner
I believe so.
φφκα |
#35 |
Here's what mine looks like. It's a bit better now, as the waves that were caused by the screws have gone away completely now. You can't see the gap really from normal eye level. It could probably be improved by lining it up a bit better:
#36 |
Drives: 94 Jeep
When you say waves, do you mean that tightening the screws caused the material to warp a little? And leaving it over time in the sun smoothed it out?
#37 |
Original 2013 Owner
Correct, in my case actually, I get subtle waving on the side facing the sun in the summer. Outside of that, they're flat.
φφκα |
#38 |
How it looked with the screws:
#39 |
Drives: scion fr-s
my set of skirts didn't come with bolts and only tapping screws. think it would make a difference if i used the tapping screws for the bolt points?
#40 |
I had a couple screws that didn't want to hang on properly. Maybe because the metal is really thin there, and/or I did a poor job of installation (not unlikely). You could always pick up a set of 4 from the hardware store. I felt it was a bit cleaner, easier, and safer, but you certainly could use the screws.
#41 | |
Drives: CBS Subaru BRZ
#42 |
Drives: 2013 BRZ Limited
| Who has Bayson R Lip kit? | Cjymiller | Northern California | 21 | 09-29-2013 09:52 AM |
| The 86 – My Review | Thavash | AFRICA | 70 | 03-07-2013 02:01 AM |
| Perrin Pulley review? Invidia Q300 exhaust review? | ScionFrsFan | Engine, Exhaust, Transmission | 4 | 12-10-2012 08:27 PM |
| EVO magazine review of GT86/BRZ review out | TheRoadWarrior | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-05-2012 08:26 PM |
| AutoExpress BRZ Review - Follow up to the GT86 Review | Zgrinch | BRZ First-Gen (2012+) — General Topics | 3 | 12-13-2011 08:03 AM |
