Old 01-10-2014, 07:26 PM   #29
psk
Drives: scion fr-s
@Cjymiller
were the nuts/bolts needed for this? i thought the self tapping screws would be enough. would too like to see an under body shot of the screws/bolts placement if possible.
thanks!
psk is offline   Reply With Quote
Old 01-10-2014, 08:13 PM   #30
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Originally Posted by psk View Post
@Cjymiller
thanks!
Here is a picture of the Nuts and bolts on the ends of my side skirts. Self tapping screws are used for all the mounting points in between.
As for the front lip, mine is fastened with all nuts and bolts (no self tapping screws), the same as show in the picture above. You must pre-drill all the holes and then tighten the nuts and bolts with wrenches. This is more difficult with the bumper on but I didn't want to run the risk of having a mis-fitting bumper upon reinstall.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
The Following User Says Thank You to Cjymiller For This Useful Post:
psk (01-11-2014)
Old 01-11-2014, 04:08 AM   #31
psk
Drives: scion fr-s
thanks for the shots!
so you have to drill holes for the bolts on the skirts too, correct?
Old 01-11-2014, 08:45 AM   #32
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Technically yes. But here's a tip: only drill the front and back t use the bolts and use 3M automotive tape in between.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 01-11-2014, 04:26 PM   #33
raytrix
Drives: Series 10 FR-S
Chargespeed Rep?
raytrix is offline   Reply With Quote
Old 01-11-2014, 07:43 PM   #34
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Correct. That is how I did it.
Definitely a good tip if you don't feel like putting a a few holes in the body. On the other hand, don't forget to consider that if you need to use a thick 3M adhesive tape, the gap will show on your side skirt.
Originally Posted by raytrix View Post
Chargespeed Rep?
I believe so.
φφκα
Old 01-11-2014, 07:51 PM   #35
Freude am Fahren
Here's what mine looks like. It's a bit better now, as the waves that were caused by the screws have gone away completely now. You can't see the gap really from normal eye level. It could probably be improved by lining it up a bit better:
Old 01-12-2014, 11:46 AM   #36
Veovius
Drives: 94 Jeep
When you say waves, do you mean that tightening the screws caused the material to warp a little? And leaving it over time in the sun smoothed it out?
Veovius is offline   Reply With Quote
Old 01-12-2014, 12:16 PM   #37
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Correct, in my case actually, I get subtle waving on the side facing the sun in the summer. Outside of that, they're flat.
φφκα
Old 01-12-2014, 01:04 PM   #38
Freude am Fahren
How it looked with the screws:
Old 01-12-2014, 02:57 PM   #39
psk
Drives: scion fr-s
my set of skirts didn't come with bolts and only tapping screws. think it would make a difference if i used the tapping screws for the bolt points?
Old 01-12-2014, 03:34 PM   #40
Freude am Fahren
I had a couple screws that didn't want to hang on properly. Maybe because the metal is really thin there, and/or I did a poor job of installation (not unlikely). You could always pick up a set of 4 from the hardware store. I felt it was a bit cleaner, easier, and safer, but you certainly could use the screws.
Old 02-15-2014, 04:19 AM   #41
Zechs21
Drives: CBS Subaru BRZ
Yeah, warming it definitely helps. I don't think the guide clips demonstrated in the video are applicable to the Bayson R kit, just the HTAutos one. I found it was easiest to drill the center hole first to ensure that the fangs of the lip and bumper were lined up as best as possible. Once I had that location, I proceeded outwards on either side. We muscled the last few drill locations to ensure a good fit.
Do you think you can measure the height to the lip for me? Already lowered and need to know if I can clear my driveway. lol thanks in advance!
Zechs21 is offline   Reply With Quote
Old 02-19-2014, 10:56 PM   #42
xcelir8brz
Drives: 2013 BRZ Limited
xcelir8brz is offline   Reply With Quote
The Following User Says Thank You to xcelir8brz For This Useful Post:
Cjymiller (02-20-2014)
Who has Bayson R Lip kit? Cjymiller Northern California 21 09-29-2013 09:52 AM
The 86 – My Review Thavash AFRICA 70 03-07-2013 02:01 AM
Perrin Pulley review? Invidia Q300 exhaust review? ScionFrsFan Engine, Exhaust, Transmission 4 12-10-2012 08:27 PM
EVO magazine review of GT86/BRZ review out TheRoadWarrior Scion FR-S / Toyota 86 GT86 General Forum 6 01-05-2012 08:26 PM
AutoExpress BRZ Review - Follow up to the GT86 Review Zgrinch BRZ First-Gen (2012+) — General Topics 3 12-13-2011 08:03 AM
