Old 08-05-2013, 12:21 PM   #29
leon78
leon78's Avatar
Drives: 13 Whiteout
Originally Posted by Marchy View Post
or perhaps the first sports car for someone who's finally made it in his mid to late 20's.
Everyone was a newb at some point, lets not turn this into MSF where we badger newbies and make them run away. If you don't like the post, hit the back button and move on.
Fucking brownie....post nudes or GTFO....FYHN....MSF FTMFW!
Hehe.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 08-05-2013, 07:38 PM   #30
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Hehe.
BRZfan is offline   Reply With Quote
Old 08-06-2013, 03:24 PM   #31
Mister
Mister's Avatar
Drives: Firestorm FRS
Hehe.
Haha
And this sums up pretty much every MSF post, the community actually helped influence me to move on from the car, and move into the FR-S (which is what I originally wanted)
On topic:
I tend to shift mine pretty short (2500ish), but a good highway ramp or sweet corner you have to let the car stretch its legs, its good for the car and it always makes your day that much better.
Mister is offline   Reply With Quote
Old 08-07-2013, 02:00 AM   #32
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
So many Motorcycle Safety Foundation jokes...
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-07-2013, 03:04 AM   #33
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I think it's only bad for the car if you're lugging it... which depends on load, gear, and rpms. I generally try to stay at 1800 and above when accelerating unless starting from a stop.
And seriously, rev the hell out of it. Have fun. Life is far too short.
As for the Mazdaspeed thing... LOL! What a bunch of pricks. Forum Wars? Never heard of it. Sad I now have. The thought of it pains me.
Old 08-07-2013, 03:36 AM   #34
tracerit
Drives: '13 SSM BRZ Limited 6MT
you guys finding it harder to shift smoothly if you shift below 2500rpm? when i shift at this rpm, i find i have to ride the clutch a bit longer longer to get it to shift smoothly. maybe i just suck haha.
tracerit is offline   Reply With Quote
Old 08-07-2013, 03:43 AM   #35
Anthony
Weight Nazi
Anthony's Avatar
Shifting down?
Old 08-07-2013, 04:33 AM   #36
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by RallySport Direct View Post
I would not worry about it, I drive mine like a grandma 97% of the time. I think the only downside is that your ECU will adapt to your light right foot and retard ignition timing a bit, so the car is not at its peak performance, but no harm should come from it.
A light foot shouldn't cause ecu to pull timing. Quite the opposite, a heavy foot, particularly at lowish rpm, gives higher cylinder pressures and heat and would more likely cause timing to be pulled. Light throttle/low load should generally allow optimal timing advance.
Driving the car like a reasonable human being in normal traffic conditions should not be any problem. Unfortunately, regularly driving the car like a normal human being at trackdays, i.e. upshifting at redline every time, might be a problem with these cars (DI failures => catastrophic engine failures)
Old 08-07-2013, 09:57 AM   #37
orthojoe
Lol. I know lionbacker personally,and can say that you guys are waaay off on some of your assumptions. Lmao.
To answer your question, no, you can't harm the car by short shifting all of the time. At the same time, you should realize that you can't harm the car by revving the piss out of it either (DI seal controversy aside). The car will save itself from any damage from revving too high by cutting fuel past redline. The only way to damage from xs revs is by money shifting the car.
I'll let you google short shift and money shift.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 08-07-2013, 10:58 AM   #38
strat61caster
strat61caster's Avatar
Originally Posted by tracerit View Post
generally how long after a start do you guys ring it out? i usually shift at max 4k for the first five minutes after start then start shifting at 5k.
*wring
I try to wait for the temperature gauge to hit the middle point which means the motor is "approximately" up to temperature. To curtail further discussion that gauge is mostly a "cold-warm-oh shit" indicator but it's good enough for 99% of owners.
ineedyourdiddly
Old 08-07-2013, 11:04 AM   #39
v1ru5
Drives: BRZ D4S 6MT L Vortech
*wring
That needle gauge is really almost useless. The middle point is a variance of at least 50 degrees F, I see my coolant temp on a real gauge hit 150 when that needle is at the middle. from 150-210 the needle doesn't move at all.
I recommend getting the car to the middle point, and then still waiting another 5 minutes of driving before wringing it out.
v1ru5 is offline   Reply With Quote
Old 08-07-2013, 11:09 AM   #40
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
This is true, and you may be right. I was under the impression that the ECU will learn habits of your driving to better suite how you drive the car. After much research it seems it may be a myth to some degree and the "learning" is more directly related to knock than throttle inputs.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 08-07-2013, 11:29 AM   #41
BRZ-OwnzJo0
BRZ-OwnzJo0's Avatar
Drives: 2016 WRX Limited
I tend to drive it harder in turns / roundabouts. I actually did a 4 tire slide and kicked the back end out in a roundabout yesterday... For a second I actually thought the back end was going to give it up but then the nanny control brought it back in the end (sports mode). I'll wind it through the gears a couple times a week now that it's hit that 1000 mile mark.
I mean.. I wouldn't NEVER wind it out. Run it through first/second every now and then... Why did you buy a sports car?
BRZ-OwnzJo0 is offline   Reply With Quote
Old 08-07-2013, 12:05 PM   #42
BRZfan
BRZfan's Avatar
I'll make sure I take extra caution when I approach a roundabout and see another BRZ.
high revving NA engine chuy21 Engine, Exhaust, Transmission 30 09-14-2014 07:33 AM
GT86 with aero kit and high wing spoiler from Australian drive event Nafe FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 43 08-26-2013 11:15 AM
Engine noise free revving or under load heeltoe86 Issues | Warranty | Recalls / TSB 4 04-29-2013 12:58 AM
Slow revving? Manual car. SprayedBigCube Engine, Exhaust, Transmission 40 07-10-2012 04:13 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
