Old 09-09-2013, 10:24 AM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Very impressive peak torque number, although I distrust old style Dyno Dynamics dyno runs that aren't done in shootout mode. My experience has been that no matter what you do the GT28/AVO sized turbo will lose some boost at you approach redline. The best you can do is try to minimize it though a boost solenoid.
Old 10-14-2013, 07:00 PM   #30
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 10-15-2013, 09:05 AM   #31
R/T Tuning
R/T Tuning's Avatar
Drives: 2013 ScionRacing FRS w/2AZ-FE swap
-r/t tuning
-greddy turbo kit
-93 ocatne
-@14psi
- also has: greddy evo3 cat back
avo catless front pipe
avo ceramic coated overpipe
greddy ProFec boost controller
omipower 3 bar map sensor
turbosmart Pro Vee BOV
deatschwerks 900cc fuel injectors
aem uego and digital boost gauge
clutchmasters fx300 clutch kit / w steel flywheel
- tuned with ecutek on our dynojet, with all racerom features: auto-blip (*rev matching), launch control, flat foot shifting, per gear rev limiting, and a customer igntion based traction control.
-well feel this is about the max for this kit on pump gas, the turbo runs out of steam @14-15 psi
R/T Tuning is offline   Reply With Quote
Old 10-15-2013, 02:12 PM   #32
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Very impressive for the Greddy kit.
Old 11-14-2013, 07:23 AM   #33
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FI Dyno thread
ECUTek Tuned by @ptuning
FA20Club EL 57 Trim
770cc FIC Injectors
8.8psi
93 Octane
Stock Fuel Pump
PTUNING 3" Header back
Exedy Stage 1 Clutch
Turbosmart Boost Tee
Old 11-14-2013, 10:36 AM   #34
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Interesting that your torque doesn't peak until 6500 RPM. You should have your full 8.8 psi way before then and should be able to make more torque earlier in the RPM range.
Old 11-14-2013, 11:09 AM   #35
nelsmar
I didn't realize this existed!
Nelsmar
Kit: Vortech Supercharger w/ upgraded 3.125" pulley
Fuel: Flex, dyno on E80-E85
Boost: 11.5PSI @ 1,100FT
Fuel upgrades were done, everything else was stock. I took the muffler & OEM intake snorekel off out of curiosity a few days before. Tuned by FA20club on the dyno (flew him in to do it). Hood open was 360WHP, hood closed was 357 with slightly warmer engine temps. Nearly identical between
My flickr - Canibeat
Local magazine scout
Old 11-14-2013, 11:11 AM   #36
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
In comparison to all the other 57 trim dyno graphs that have been posted, they build max torque around the same RPM range. It seems pretty typical of the turbo.
Old 11-14-2013, 11:11 AM   #37
nelsmar
Originally Posted by Adeets View Post
Anychance we can get this stickied so I don't have to dredge it up from the abyss next time someone needs this data.
Mods, can we please get this? I didn't realize this was here and I was looking for it earlier! Sorry to make comments in the thread but I feel it is important.
Old 11-14-2013, 11:28 AM   #38
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Can you post examples? I look at my dyno (GT28), David's dyno (AVO), and the Greddy kit up above and see quite a flatter torque curve peaking where full boost is reached and all those turbos are fairy similar to a T3/T4 57 trim. We can take this discussion to the FA20Club thread if you want.
Old 11-14-2013, 11:42 AM   #39
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FI Dyno thread
I don't think the physical dimensions have anything to do with it. The AVO kits that were tuned and on the same dyno as the one I posted made more torque and sooner but the one I posted made more horsepower than both of them.
http://www.ft86club.com/forums/showthread.php?t=40270
http://www.ft86club.com/forums/showp...&postcount=359
http://www.ft86club.com/forums/showp...&postcount=417
http://www.ft86club.com/forums/showp...13&postcount=1
AVO 10.5 PSI
http://s1283.photobucket.com/user/na...ac51b.jpg.html
Old 11-14-2013, 11:48 AM   #40
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
8 PSI AVO Stage 1.5 Kit
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 11-14-2013, 12:39 PM   #41
ptuning
ptuning's Avatar
Drives: White FR-S
It's not necessarily the turbocharger itself and definitely not the tune. Basically, running off the wastegate spring, this particular turbo setup produces x amount of boost in the midrange and creeps up to about 2 psi more towards the top end. So even though we're seeing 8.8 psi at the power peak, there is only about 6-7psi in the midrange. The manual boost controller shifts the spring pressure curve up, but does not flatten out the overall boost curve. I'm sure this would occur at higher boost levels using E85, race gas, or WMI.
So in a nutshell, the torque curve was a function of the boost curve, which is dictated by manifold design, WG setup, etc.
ptuning is offline   Reply With Quote
Old 11-14-2013, 12:50 PM   #42
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That makes sense if he is getting boost creep. Did you record the boost curve? Can I see a plot?
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 10:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
