#29 |
NASA SpecE30 Racer
Very impressive peak torque number, although I distrust old style Dyno Dynamics dyno runs that aren't done in shootout mode. My experience has been that no matter what you do the GT28/AVO sized turbo will lose some boost at you approach redline. The best you can do is try to minimize it though a boost solenoid.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#30 |
Seems Legit
Drives: Toyota
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#31 |
Drives: 2013 ScionRacing FRS w/2AZ-FE swap
-r/t tuning
-greddy turbo kit -93 ocatne -@14psi - also has: greddy evo3 cat back avo catless front pipe avo ceramic coated overpipe greddy ProFec boost controller omipower 3 bar map sensor turbosmart Pro Vee BOV deatschwerks 900cc fuel injectors aem uego and digital boost gauge clutchmasters fx300 clutch kit / w steel flywheel - tuned with ecutek on our dynojet, with all racerom features: auto-blip (*rev matching), launch control, flat foot shifting, per gear rev limiting, and a customer igntion based traction control. -well feel this is about the max for this kit on pump gas, the turbo runs out of steam @14-15 psi |
#32 |
NASA SpecE30 Racer
Very impressive for the Greddy kit.
- King Tut
#33 |
Seems Legit
Drives: Toyota
FI Dyno thread
ECUTek Tuned by @ptuning FA20Club EL 57 Trim 770cc FIC Injectors 8.8psi 93 Octane Stock Fuel Pump PTUNING 3" Header back Exedy Stage 1 Clutch Turbosmart Boost Tee
#34 |
NASA SpecE30 Racer
Interesting that your torque doesn't peak until 6500 RPM. You should have your full 8.8 psi way before then and should be able to make more torque earlier in the RPM range.
- King Tut
#35 |
I didn't realize this existed!
Nelsmar Kit: Vortech Supercharger w/ upgraded 3.125" pulley Fuel: Flex, dyno on E80-E85 Boost: 11.5PSI @ 1,100FT Fuel upgrades were done, everything else was stock. I took the muffler & OEM intake snorekel off out of curiosity a few days before. Tuned by FA20club on the dyno (flew him in to do it). Hood open was 360WHP, hood closed was 357 with slightly warmer engine temps. Nearly identical between
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#36 |
Seems Legit
Drives: Toyota
In comparison to all the other 57 trim dyno graphs that have been posted, they build max torque around the same RPM range. It seems pretty typical of the turbo.
#37 | |
#38 |
NASA SpecE30 Racer
Can you post examples? I look at my dyno (GT28), David's dyno (AVO), and the Greddy kit up above and see quite a flatter torque curve peaking where full boost is reached and all those turbos are fairy similar to a T3/T4 57 trim. We can take this discussion to the FA20Club thread if you want.
- King Tut
#39 | |
Seems Legit
Drives: Toyota
FI Dyno thread
http://www.ft86club.com/forums/showthread.php?t=40270 http://www.ft86club.com/forums/showp...&postcount=359 http://www.ft86club.com/forums/showp...&postcount=417 http://www.ft86club.com/forums/showp...13&postcount=1 AVO 10.5 PSI http://s1283.photobucket.com/user/na...ac51b.jpg.html
[insert profound quote here] Last edited by ecko04; 11-14-2013 at 01:21 PM. |
#40 |
Drives: FRS :D
Out of the FRS game
#41 | |
Drives: White FR-S
Basically, running off the wastegate spring, this particular turbo setup produces x amount of boost in the midrange and creeps up to about 2 psi more towards the top end. So even though we're seeing 8.8 psi at the power peak, there is only about 6-7psi in the midrange. The manual boost controller shifts the spring pressure curve up, but does not flatten out the overall boost curve. I'm sure this would occur at higher boost levels using E85, race gas, or WMI.So in a nutshell, the torque curve was a function of the boost curve, which is dictated by manifold design, WG setup, etc.
#42 |
NASA SpecE30 Racer
That makes sense if he is getting boost creep. Did you record the boost curve? Can I see a plot?
- King Tut
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 10:28 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
