#29 |
Drives: Firestorm FR-S
True, but like I said I'd be afraid I'd just blow them again, and if I'm gonna spend the money to get it installed on stock struts I might as well just spend that money on konis and do it myself lol.
#30 |
#31 |
Same here. But one thing I value more then my money is my time haha
#32 |
Drives: WRB BRZ
Yep, I have a prokit and got a leaking rear driver side strut.
got lucky, my dealer replaced it for warranty even with aftermarket springs on. I am in Australia by the way. |
#33 |
Wow that's some luck right there.
#34 |
If the strut is blown you should be able to see some leaking fluid around the seals, but if the shaft loosened internally I doubt you'll see fluid at all.
#35 |
I haven't noticed any fluid. Is there a way to fix it if its an internal thing?
#36 |
Not that I know of, you'd have to totally disassemble the strut and they're sealed units.
#37 |
oh, well looks like Konis are my next step. Does anyone know a cheaper place then here to get them? http://ft86speedfactory.com/suspensi...cks-struts-89/
#38 |
Under $600 for a full set of Koni's is a pretty good deal already.
#39 |
Oh allright. Yeah that was the best price I found. But they're stronger? I won't have I worry as much about spinning them when I'm installing them?
#40 |
Senior Citizen
Drives: Scion FR-S
Sounds similar to loose endlink bolts, too. I had a similar sound and just needed to really tighten the front end link bolts.
#41 |
The two that tighten to 114 lbs? How tight did you do yours?
#42 |
Drives: 2013 FR-S Blue MT
You are referring to the lower strut body/bracket bolts. He is referring to the bolts that connect the strut to the swaybar.
If the swaybar endlink bolts aren't snugged, it will rattle, particularly around corners. |
| Clanking metal sound from rear!!!! | 808Raven | Issues | Warranty | Recalls / TSB | 7 | 09-21-2017 10:09 AM |
| My Install from Simplicity in Sound | jlu | Electronics | Audio | NAV | Infotainment | 3 | 06-05-2013 05:24 PM |
| clanking sound with idle | wallace03 | Issues | Warranty | Recalls / TSB | 4 | 05-08-2013 05:19 PM |
| GT Sound Matt Install | Neilus | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 12-18-2012 06:32 AM |
| Fixed flapping, clanking sound coming from rear | Cornerman | Issues | Warranty | Recalls / TSB | 2 | 08-16-2012 09:27 PM |
