Old 11-07-2013, 08:29 AM   #29
Charky
Charky's Avatar
Drives: Fr-s 2013 Hot Lava
Originally Posted by DarrenDriven View Post
Already asked and answered.
Its true my bad
Charky is offline   Reply With Quote
Old 02-05-2014, 09:16 AM   #30
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
NIce setupppp Like a lot!
kombatlion is offline   Reply With Quote
Old 02-05-2014, 11:23 AM   #31
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Mi set up!
Old 04-10-2014, 04:24 PM   #32
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
XXR 527 18x9.75 +20 Will it fit??
Hello Guy and Gals
as title says will it fit on FR-S?
my car is lowered by Eibach Pro with stock shock and strut.
will it rub my fender?
Please advice..
Thank you!
bhbnuckle is offline   Reply With Quote
Old 04-11-2014, 04:10 AM   #33
GaN-MaN
WA 86/BRZ Club
GaN-MaN's Avatar
Drives: Toyota 86 GT MT Sonic Blue
There is an entire 82 page thread on the XXR 527/530 and i can bet Bob's your uncle that you will find if it fits in there...
Before you ask again, yes people are running 18x9.75 +20...
http://www.ft86club.com/forums/showthread.php?t=18661
2012 Toyota 86 Sonic Blue GT 6MT
GaN-MaN is offline   Reply With Quote
The Following User Says Thank You to GaN-MaN For This Useful Post:
TylerLieberman (04-11-2014)
Old 12-09-2014, 02:55 AM   #34
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Just attemted 235/40/18 on xxr 18x9.75+20 with skunk2 coilovers with 10k springs replaced all around...Max camber front...and hits fender on max drop. Rear hits fender...I'm thinking i shoulda went 225/40/18...
Celigts is offline   Reply With Quote
Old 12-09-2014, 05:50 PM   #35
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Yeah, my setup with the 225/40/18s only rubs slightly when I enter a steep driveway at an angle and loads a wheel, or at 50MPH+ freeway on-ramps. You could always raise it up 1/2" and see if that helps... but that defeats the purpose, haha.
Old 06-30-2015, 01:23 PM   #36
Albaro08
Albaro08's Avatar
Drives: Frs asphalt Grey
I like your set up but would going 18x9.75 40 make the wheel go into the fender more or out and I would like to go with meaty tires??? But still have the concave look
Sent from my D6616 using Tapatalk
Albaro08 is offline   Reply With Quote
Old 06-30-2015, 03:29 PM   #37
Timmy_Jones
Spun
Drives: 23' Supra
You are correct, but I think these wheels are limited in offset. XXR only makes the 9.75 in a +20. The more narrow wheel can be had on like a +35, better suited to fitting the car.
Timmy_Jones is offline   Reply With Quote
Old 06-30-2015, 08:01 PM   #38
Albaro08
Albaro08's Avatar
So you don't recommend going this size or find something else I want to go 235/55/18 on wheels
Old 07-01-2015, 12:00 AM   #39
Leonardo
Country Boy 4 Life
Leonardo's Avatar
That's way too big. It will never fit. 235/40/18. Or 225/40/18. I've seen 225/35/18 too.
Old 07-16-2015, 02:06 PM   #40
alvinrenz
Drives: firestorm 2015
I am planning to go with these set up with BC Coilover extreme drop. wrapped with 225/40
My question is, Will it rub on the lowest settings? if yes can i lift it a notch?
do I get a better fitment if i go 18x8.75 in the front or i should be fine in squared 9.75?
thanks for the help. This will be my first coilover and wheel fitment.
I am aiming similar to this
alvinrenz is offline   Reply With Quote
Old 01-13-2016, 03:46 PM   #41
jkrlox
Drives: argento 86 soon
Did you find your answer? Would it fit better to combine 8.75 +35 and 9.75 +20 than square 9.75?
jkrlox is offline   Reply With Quote
Old 01-13-2016, 03:51 PM   #42
swarb
You just bumped an old thread.
8.75 +35 for wider tires and minimal camber.
9.75 +20 for 225/40 or smaller and 4-5+++ camber.
The Following User Says Thank You to swarb For This Useful Post:
Albaro08 (02-06-2016)
Wheel Directory: WedsSport SA-15R 18x9.5 +48 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 09-13-2020 01:22 PM
Wheel Directory: XXR 530 18x9.75 +20 alexfrspr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 02-09-2017 08:02 AM
Wheel Directory: Rotiform NUE 18x9.5 +25 tackybrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 06-13-2015 09:05 AM
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 04:09 AM
Wheel Directory: XXR 531 18x9.5 +35 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-10-2013 02:41 PM
