#29 |
Drives: 13 DGM BRZ Ltd
You don't just redrill brakes to get a new hub pattern.
That's why there are things like the hub conversion kit on the market. |
#30 | ||
Señor Member
Drives: white BRZ 6MT
(or in other words, why are we changing calipers at all?)
#31 | |
Drives: 2005 Toyota Camry
My only concern is the stock rotors have small threaded holes (for the rotors to be backed out when stuck to hub). See here: ![]() As long as the 5x114.3mm holes are drilled properly and not too close to the existing holes, you should be fine. Print out a template of 5x114.3mm and see how it overlays with the rotors to be safe. When I first started swapping Z32 calipers/rotors onto a S13, we never had the luxury of 5 lug hubs. I was able to redrill the rotors to 5x114.3mm (using 1 of the 4x114.3mm holes and drilling 4 more) with zero issues, and virtually every S13/14 guy running 4-lug hubs did the same when upgrading to bigger brakes. And by the way: It's perfectly safe if you have enough material on the rotor hat, even wheels. See: every 9x114.3mm/9x100mm and dual bolt pattern wheel ever made. -alex |
#32 | |
Drives: 22 GR86, 13 FR-S, AP2 S2000
#33 |
Destroyer of Tires
Drives: 2001 Honda Accord, 1997 Lexus ES300
Just emailed Megan the other day about these hubs, and they mentioned that they're not on the market at the moment for some reason. They didn't have a date as to when they'd be available again either.
#34 |
Drives: LexusGS,Lotus Exige S240,LexusLX570
Has anyone tried this setup yet? I am very tempted to go for it, just a little confused on what needs to be done. Do i need to new brakes?
#35 |
Drives: 2013 Hot Lava FRS
Anyone know of someone running these yet? I know I saw one guy on Instagram running some 5x114.3 hubs but I am not sure what they were. Also do you know of anyone selling them other than Megan Racing? I swear I saw them for like $600.00 somewhere.
#36 |
Drives: DGM BRZ
Hard Race is the other brand but since they look similar to the Megan ones they're probably from the same manufacturer. I forget which one I heard through the rumor mill was having problems with the bearings.
There's a shop in Japan that modifies your stock knuckle to accomodate a different hub (Legac, R32,etc) so I'm sure it's possible if you find a good fabricator. |
#37 | ||
Drives: Toyota
Megan list their 114.3 front and rear hubs as 145mm in diameter, whereas the external diameter of the hub part of the front rotor is 139mm (see image below). The insides got to be smaller so the hubs aint going to fit. The same measurement on the rear rotors is about 200mm so if they are redrilled, the hubs will fit inside |
#38 |
Drives: Subaru BRZ Limited
Do I also need to new brakes using this kit?
Thanks. |
#39 |
I have been running for just under a year all is good
#40 |
Drives: WRB ZC6
I should make it clear for people.
You can re-drill the rear rotor and it will fit fine The front you "will" need to change the calipers and rotors because the stock front rotors cannot fit into the Megan/hardace hubs( 145mm diameters of the hub as mentioned) cause its too small making it physically impossible to retro fit with our front rotors with them (139mm hub diameter) The OP has mentioned a few methods and i think the legacy 2012+ front brake kit is your cheapest bet if your keen |
#41 | |
Drives: 2014 Toyota FRS
Can I just swap the rotor and retain the same brakes? Also the rear what rotor do I buy? I'm not a fan of re drilling them... |
#42 |
Drives: R.S. 2.0
The new WRX's have 5x114.3, would those rotors fit?
| Project Kics 11mm or 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) | Evasive Motorsports | Wheels and Tires | 31 | 06-13-2015 08:09 PM |
| CUSTOM Wheel spacers/adapters 5x100 & 5x114 conversion (15mm / 20mm / 25mm) | JonMotoring | Wheels and Tires | 102 | 04-30-2015 08:22 PM |
| Lug Nuts - Muteki, Rays, Kics, Syun Project & Megan 5x114.3 Conversion Kit | eauto | Wheels and Tires | 359 | 10-15-2014 01:45 PM |
| Project Kics 10mm 5x100 to 5x114.3 Conversion Spacer Hubcentric | deedz | Wheels and Tires | 12 | 05-22-2013 04:18 AM |
| Megan Racing's FR-S Drifting @ Extreme AutoFest | Guaruja | Tracking / Autocross / HPDE / Drifting | 3 | 06-11-2012 06:02 AM |
