Old 12-01-2013, 12:05 PM   #29
infinite012
Drives: 13 DGM BRZ Ltd
You don't just redrill brakes to get a new hub pattern.
That's why there are things like the hub conversion kit on the market.
infinite012 is offline   Reply With Quote
Old 12-01-2013, 02:50 PM   #30
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
yeah, you're TOTALLY missing the point here. Did you even read the OP and the link provided? Look:
- *Note: Please make sure the correct size rotors (5x114.3 rotors) are fitted with this kit
1/ Front brake and rotor,
Option1: Upgrade to aftermarket brake kits including calipers and 5x114.3 rotors.
Option2: upgrade to 08-13 stock STI Brembo brake kit (5x114.3 stock rotors), it is direct bolt on
Option3: upgrade to 2010-14 Legacy 2.5GT oem brake kit, re-drill to 5x114.3 on rotors
2/ Rear brake and rotor,
Option1, you can re-drill the original rotor to 5x114.3 and you can bolt them on.
so, my original question was: why can't the fronts be redrilled to 5x114 so they can be used with this kit, and otherwise use stock hardware?
(or in other words, why are we changing calipers at all?)
dori. is offline   Reply With Quote
Old 12-01-2013, 03:06 PM   #31
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by dori. View Post
sorry, I meant redrill the front brake rotors as opposed to getting an STI caliper/rotor set or aftermarket kit.
Yes, it can be done.
My only concern is the stock rotors have small threaded holes (for the rotors to be backed out when stuck to hub). See here:
As long as the 5x114.3mm holes are drilled properly and not too close to the existing holes, you should be fine. Print out a template of 5x114.3mm and see how it overlays with the rotors to be safe.
This statement makes me weep for our future.
When I first started swapping Z32 calipers/rotors onto a S13, we never had the luxury of 5 lug hubs. I was able to redrill the rotors to 5x114.3mm (using 1 of the 4x114.3mm holes and drilling 4 more) with zero issues, and virtually every S13/14 guy running 4-lug hubs did the same when upgrading to bigger brakes.
And by the way: It's perfectly safe if you have enough material on the rotor hat, even wheels. See: every 9x114.3mm/9x100mm and dual bolt pattern wheel ever made.
-alex
Old 02-01-2014, 09:23 PM   #32
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
Originally Posted by GTM_Challenge View Post
We explored this option back when we were thinking about getting an FR-S. While there are a lot of 5x100 wheels out there, there are infinitely more 5x114.3 wheels with aggressive offsets.
For us, it would have been nice to be able to share wheels between the FRS and our shop s2000s. We already had 7 sets of 5x114.3 wheels - would have been nice to be able to use them.
That being said, we have moved on with the 5x100 setup and haven't had any issues. We've even got a set of dual drilled (5x100 and 5x114.3) wheels to share between the s2000s and FRS.
I was just googing to see if there was a solution for sharing wheels between S2000 and FR-S as I would like to only have to maintain 1 set of track tires at any given time. What wheels did you get that are dual drilled and have a big enough hub bore to accomodate the front axle of the s2k?
AyJay is offline   Reply With Quote
Old 02-03-2014, 01:32 PM   #33
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
Just emailed Megan the other day about these hubs, and they mentioned that they're not on the market at the moment for some reason. They didn't have a date as to when they'd be available again either.
Redstar is offline   Reply With Quote
Old 04-01-2014, 03:31 AM   #34
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
Has anyone tried this setup yet? I am very tempted to go for it, just a little confused on what needs to be done. Do i need to new brakes?
mnsayer is offline   Reply With Quote
Old 04-29-2014, 11:40 AM   #35
Skidrcn
Drives: 2013 Hot Lava FRS
Anyone know of someone running these yet? I know I saw one guy on Instagram running some 5x114.3 hubs but I am not sure what they were. Also do you know of anyone selling them other than Megan Racing? I swear I saw them for like $600.00 somewhere.
Skidrcn is offline   Reply With Quote
Old 04-30-2014, 12:18 PM   #36
brz_star21
Drives: DGM BRZ
Hard Race is the other brand but since they look similar to the Megan ones they're probably from the same manufacturer. I forget which one I heard through the rumor mill was having problems with the bearings.
There's a shop in Japan that modifies your stock knuckle to accomodate a different hub (Legac, R32,etc) so I'm sure it's possible if you find a good fabricator.
brz_star21 is offline   Reply With Quote
Old 11-08-2014, 05:39 AM   #37
eztygr
Drives: Toyota
Old thread, but I think the reason you can't re-drill the standard front rotors is the Megan / Hardrace front hubs wont fit inside them.
Megan list their 114.3 front and rear hubs as 145mm in diameter, whereas the external diameter of the hub part of the front rotor is 139mm (see image below). The insides got to be smaller so the hubs aint going to fit.
The same measurement on the rear rotors is about 200mm so if they are redrilled, the hubs will fit inside
eztygr is offline   Reply With Quote
Old 01-18-2015, 06:41 AM   #38
cslntuee
Drives: Subaru BRZ Limited
Do I also need to new brakes using this kit?
Thanks.
cslntuee is offline   Reply With Quote
Old 01-25-2015, 02:45 AM   #39
mnsayer
mnsayer's Avatar
I have been running for just under a year all is good
Old 01-27-2015, 11:16 AM   #40
manonastick
Drives: WRB ZC6
Thanks.
I should make it clear for people.
You can re-drill the rear rotor and it will fit fine
The front you "will" need to change the calipers and rotors because the stock front rotors cannot fit into the Megan/hardace hubs( 145mm diameters of the hub as mentioned) cause its too small making it physically impossible to retro fit with our front rotors with them (139mm hub diameter)
The OP has mentioned a few methods and i think the legacy 2012+ front brake kit is your cheapest bet if your keen
manonastick is offline   Reply With Quote
Old 03-06-2015, 09:46 PM   #41
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
I cannot find 2012+ legacy front brake kit...and I don't want to drop 3k on the Brembo brake kit...granted that's for all 4...what else can be used?
Can I just swap the rotor and retain the same brakes?
Also the rear what rotor do I buy? I'm not a fan of re drilling them...
Celigts is offline   Reply With Quote
Old 12-22-2016, 02:35 PM   #42
Vivos71
Vivos71's Avatar
Drives: R.S. 2.0
The new WRX's have 5x114.3, would those rotors fit?
Vivos71 is offline   Reply With Quote
Project Kics 11mm or 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) Evasive Motorsports Wheels and Tires 31 06-13-2015 08:09 PM
CUSTOM Wheel spacers/adapters 5x100 & 5x114 conversion (15mm / 20mm / 25mm) JonMotoring Wheels and Tires 102 04-30-2015 08:22 PM
Lug Nuts - Muteki, Rays, Kics, Syun Project & Megan 5x114.3 Conversion Kit eauto Wheels and Tires 359 10-15-2014 01:45 PM
Project Kics 10mm 5x100 to 5x114.3 Conversion Spacer Hubcentric deedz Wheels and Tires 12 05-22-2013 04:18 AM
Megan Racing's FR-S Drifting @ Extreme AutoFest Guaruja Tracking / Autocross / HPDE / Drifting 3 06-11-2012 06:02 AM
