Old 06-05-2013, 02:38 PM   #29
taimysho0
Drives: frs
Originally Posted by UnOvertime View Post
I have a friend with BC racing and he loves them. His FR-S is a daily driver. I was strongly leaning towards BC (BC is local to me) until I saw the intro deal on the tarmac zeros. BC's with the swift upgrade will be decent and fulfill what you are looking for.
where are you seeing the deals for the tarmacs? is there a vendor selling them on here? how much do they go for
taimysho0 is offline   Reply With Quote
Old 06-05-2013, 02:46 PM   #30
taimysho0
Drives: frs
Originally Posted by Racecomp Engineering View Post
They are built by KW for us...truly custom valved KWs for the BRZ/FRS. We worked with them to dial in the valving and spring rates even more (and have a lifetime warranty). We've been working with them since 2006.
- Andy
sen you a pm for more info on tarmacs
Old 06-05-2013, 02:48 PM   #31
you can buy them from us ! (we are on the forums..) =)
Myles
Old 06-05-2013, 02:51 PM   #32
sent.
Old 06-05-2013, 03:51 PM   #33
ScionFR-J
Drives: 2013 Argento FR-S
any good references on where to buy those? i didnt see any in the vendors forums or on ebay..thanks
http://www.frs86.com/suspension/rs-r...moto-spec.html
ScionFR-J is offline   Reply With Quote
Old 06-05-2013, 03:58 PM   #34
qoncept
qoncept's Avatar
IMO, if you want stock ride quality you don't want coilovers, period. To get a quality coilover you are spending over $2000. If you want to lower your car, get springs or coilover sleeves on stock struts.
qoncept is offline   Reply With Quote
Old 06-05-2013, 04:12 PM   #35
taimysho0
Drives: frs
alright, after much consideration i think im going with springs on oem shocks. i dont need to buy aftermakret bump stops right? im leaning towards swift springs since they have a 1" drop, anyone can compare these with the rce springs?
Old 06-05-2013, 04:13 PM   #36
taimysho0
Drives: frs
also, i will be mounting 18x8.75 rims on 225/45/18 fornt and 245/40/18 rear tires, so hopefully the drop will make that look good..
Old 06-05-2013, 04:19 PM   #37
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
I was between the Swift and RCE's for springs as well. The RCE's come with replacement bump stops whereas the swifts do not. You don't NEED aftermarket bumpstops. Swift will have the 1" drop, RCE has about .8" drop. I was swayed to RCE because of the positive reviews, now there should be more about the swift springs on the site. Both are quality so you cannot go wrong with either set.
UnOvertime is offline   Reply With Quote
Old 06-05-2013, 04:21 PM   #38
qoncept
qoncept's Avatar
If you're going with a mild drop you shouldn't need to replace the bump stops.
Here are the spring rates (kg/mm). The drop roughly equal.
RCE 4.6K F / 4.6K R
Swift Springs 3K F / 4.5K R
Stock FR-S 2.3K F / 3.7R
Stock BRZ 2.6F, 3.5R
The more ratio of stiffness is rear biased, the more oversteer you'll see. I'm very surprised to see the RCEs are equal. I would recommend Swift over that.
Old 06-05-2013, 04:55 PM   #39
taimysho0
Drives: frs
thanks for everyones help! i pulled the gun on a set of stance with swift springs. it was for a price i couldnt resist. since i will be planning multiple rim setups in the future i want everything looking flushed so the need to adjust ride height is a must, plus the swift springs should keep things nice and soft
Old 06-05-2013, 04:59 PM   #40
CSG David
CSG David's Avatar
Much more than that if you want very good dampers.
Old 06-05-2013, 06:32 PM   #41
taimysho0
Drives: frs
im sticking with 6k/7k spring rate with the swifts, since i was informed by the salesman that its the recommended spring rate for stance. im thinking of going 6k/6k since im looking for a softer spring rate but was told at 6k/7k with swift, it should already feel softer than 6k/7k on stance springs since swift is a lighter and higher quality spring
Old 06-05-2013, 06:35 PM   #42
qoncept
qoncept's Avatar
I would go with the 6/7 just so the car doesn't handle like a pig, but
is a bunch of sales nonsense. 6k is 6k no matter who makes the spring. You might find some that use steel that fatigue faster or weigh more but whoever said they would be softer is full of shit.
The Following 2 Users Say Thank You to qoncept For This Useful Post:
JoeBoxer (06-05-2013), Mgivens (06-05-2013)
Stock ride height numbers? xwd Tracking / Autocross / HPDE / Drifting 16 07-11-2018 01:42 PM
Coilover to Raise Ride Height Furtive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-28-2014 01:57 PM
Want to know where the closest BRZ at a dealer is.... Opie BRZ First-Gen (2012+) — General Topics 423 03-18-2013 04:43 PM
***KSport Coilover Exclusive** IN STOCK - FT-86 SpeedFactory FT-86 SpeedFactory Brakes, Suspension, Chassis 13 09-13-2012 10:45 AM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 11:58 AM
