Old 04-29-2013, 07:52 PM   #29
Raceseng
Raceseng's Avatar
Originally Posted by dwx View Post
Raceseng can answer definitely but the way the upper portion seems to fit within the opening of the strut tower would mean the perch wouldn't sit quite as low as a perch which fits completely flat under the shock tower.
You are dead on! When I started designing the caster/camber plates, I wanted to minimize the stack height without sacrificing travel. This was the best solution I found which offers the lowest stack height with independent caster and camber travel.
Raceseng is offline   Reply With Quote
Old 04-29-2013, 07:54 PM   #30
Raceseng
Raceseng's Avatar
Originally Posted by Shit Luck View Post
These are awesome...
integrated tower brace coming?????
Absolutely, we are working on several strut tower solutions now with the same design approach taken on the caster/camber plates.
Old 04-29-2013, 08:04 PM   #31
Shit Luck
Drives: red frs
I really need to stop up and see you guys....
Shit Luck is offline   Reply With Quote
Old 04-29-2013, 08:06 PM   #32
Raceseng
Raceseng's Avatar
Where are you located?
Old 04-29-2013, 08:41 PM   #33
Shit Luck
Drives: red frs
York, Pa.
Old 04-30-2013, 06:17 PM   #34
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Just wanted to give you guys a heads up as to what is going on inside Raceseng. We are developing a true independent caster and camber adjustment plate. These plates will mount under the strut tower, have plenty of caster/camber adjustment and minimum stack height! The key to our design is to make the caster and camber adjustment independent of each other. Below are some shots of our product design, development and prototyping in process!
Wow! Looks great. I love the fact that it can be adapted to different shocks and springs. I look forward to see what you come up with for a strut brace.
Newby/uninformed question: A lot of metal seems to have been removed to allow a wide range of adjustments. Is there enough metal left to prevent deflection/fatigue under track and/or street pothole conditions?
Old 05-01-2013, 09:39 AM   #35
Raceseng
Raceseng's Avatar
No worries, I can understand your concern. To put things in perspective for you, the top plate on my Cusco coil overs is 1/4" aluminum plate. The thickness of the caster/camber plate where the camber slot is cut out is over 5/8" thick. We have a prototype sets machined and being tested now. Simmons is testing a set with KW V3 coil overs on his autocross car.
The Following 2 Users Say Thank You to Raceseng For This Useful Post:
Eric@ptuning (01-28-2014), whataboutbob (11-01-2013)
Old 05-01-2013, 10:42 AM   #36
s2d4
s2d4's Avatar
Please pardon my ignorance, will this be fronts only?
Old 05-01-2013, 10:46 AM   #37
Raceseng
Raceseng's Avatar
It's cool... There is no need to make an adjustable top plate for the rear because the coil over/strut is bolted to the lower control arm which adjusts rear camber.
So, yes this will be fronts only. Thanks!
Old 05-01-2013, 03:08 PM   #38
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Any ideas on preliminary pricing? With the SCCA proposing an allowance of camber plates in its new Street class next year I am 100% interested. I'm a northeast guy as well so I'll probably just head to a NNJR autocross and check out Simmons car.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 05-01-2013, 03:11 PM   #39
OrbitalEllipses
Drives: Attitude
This. What price range are you targeting for these?
Old 05-02-2013, 07:01 PM   #40
Esoteric
Esoteric's Avatar
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
Jarret and the crew are exceptional nice people and tremendously talented at making sexy parts that will work.
We are excited that they are local to us, and will be looking forward to rounding out our product line, with those that they will be offering as well.
Keep an eye our for their parts!
Esoteric is offline   Reply With Quote
The Following User Says Thank You to Esoteric For This Useful Post:
Raceseng (05-03-2013)
Old 05-05-2013, 05:42 AM   #41
s2d4
s2d4's Avatar
What is the projected price for his combination?
Old 05-06-2013, 09:13 AM   #42
Raceseng
Raceseng's Avatar
We are still in the development phase of the caster/camber plates. I won't have confirmed pricing until we get production cycle times off our machining centers. Thanks for inquiring!
billet, billet aluminum, caster adjustment, caster camber plate, raceseng
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 02:21 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 01:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 02:48 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-28-2013 12:38 AM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 07:44 PM
