Old 04-24-2013, 12:19 PM   #29
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
I'd be interested in the lbs difference between the stock to aluminum and cf also
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 04-24-2013, 02:11 PM   #30
SatinWhitePearl
Drives: '07 Subaru STi / '11 Honda Civic Si
I've got an ACPT carbon d/s on my '07 STi and love it.
If there's going to be an application for the FR-S / BRZ that's a collaboration between two great companies, it'll be worth the money - without question.
Thanks for bringing a great product to market for this community!
SatinWhitePearl is offline   Reply With Quote
Old 04-24-2013, 02:22 PM   #31
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
The stock one is around 24-25lb
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Old 04-24-2013, 02:32 PM   #32
Driveshaft Shop
Drives: 31 Ford, Viper GTS,65 Riviera,Cayen
Ok, here we go
The stock 2 piece shaft is 24lbs
The 3.5" aluminum one is 18lbs
Carbon is 15lbs.
hope this helps.......
Driveshaft Shop is offline   Reply With Quote
The Following 9 Users Say Thank You to Driveshaft Shop For This Useful Post:
adprokid (04-26-2013), Chewie4299 (04-24-2013), DAMotorsports (08-30-2013), Freeman (04-24-2013), JDKane527 (04-24-2013), lbroskee (08-26-2013), PERRIN (04-24-2013), RehabJeff86 (04-26-2013), tisb0b (04-24-2013)
Old 04-24-2013, 02:50 PM   #33
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Originally Posted by Driveshaft Shop View Post
Ok, here we go
Carbon is 15lbs.
This puts it at 1 lb heavier than the PST Carbon Fiber drive shaft. How is the torque handling capability of the DSS carbon fiber shaft compared to PST?
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
Old 04-24-2013, 09:54 PM   #34
Driveshaft Shop
im going to guess its higher being we use a high modulus tube instead of a reg modulus tube, the joint will break before the bond or tube. ours is actually 14.2lbs but i round up. sorry. with the aluminum ends i sure its lighter.
p.s. the 2.25 high modulus tube we use on the WRX/STI has broken several trans case output shafts, also if you need a stronger one we can do the 3.25 tube also
The Following User Says Thank You to Driveshaft Shop For This Useful Post:
Old 04-24-2013, 09:59 PM   #35
Driveshaft Shop
Originally Posted by FT_Monk View Post
Based on my experience, I would not buy anything DSS. But of course that is just me.
im very sorry you had that issue, i know the problem well. we make the spline area out of chromoly and have it thru hardened, after the hardening is done the end where the spline is welded is supposed to be tempered back. there was a run the heat treater did not do this on and the welds broke due to hydrogen embrittlment .
im here to help, if you ever need anything send me a pm. let me know what you lost in the process and ill take it off the bill with a reduction in price as well.
Frank..
The Following 4 Users Say Thank You to Driveshaft Shop For This Useful Post:
lazyluka (08-13-2013), Nightbringer (08-13-2013), ProjectD (04-26-2013), shaunsweeney (01-21-2014)
Old 04-24-2013, 09:59 PM   #36
JDKane527
JDKane527's Avatar
Sounds good.
Old 04-25-2013, 01:14 PM   #37
Argento_FR-S
Drives: Scion FR-S
What is the torque capability of the aluminum shaft?
Argento_FR-S is offline   Reply With Quote
Old 04-26-2013, 01:13 PM   #38
Driveshaft Shop
Hey guys i made a thread for the links to our axles, but i also wanted to do it here.
Carbon-Fiber
http://www.driveshaftshop.com/import-driveshafts/toyota/gt86/2012-scion-frs-subaru-brz-toyota-gt86-3-5-aluminum-1-piece-driveshaft
600 HP axles Direct fit
http://www.driveshaftshop.com/import-axles/toyota/gt86/2013-subaru-brz-scion-frs-toyota-gt86-600hp-direct-bolt-in-rear-axles
Pro-level axle/hub kit
http://www.driveshaftshop.com/import-axles/toyota/gt86/2012-scion-frs-subaru-brz-toyota-gt86-pro-level-axle-hub-kit
Old 04-26-2013, 01:33 PM   #39
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Quick Q, under load, then releasing load (like shifting 1st to second fast) causes a sound like someone unlocking their car (that faint beep like a horn sound) is that normal operation for a CF driveshaft? While it loads unloads quickly?
stuff
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 05-07-2013, 08:28 AM   #40
Driveshaft Shop
Just a head up, the Auto shafts are a go..........
Freeman (05-07-2013), Lonewolf (05-25-2013), neutron256 (05-07-2013), ShadowSeraph (08-15-2013)
Old 05-07-2013, 12:45 PM   #41
Chase Bays
Chase Bays's Avatar
Drives: FR-S | 335i | S13
I've been using Driveshaft Shop axles on various project cars for years and I love them.
Chase Bays is offline   Reply With Quote
Old 05-07-2013, 09:44 PM   #42
Captain Insano
Outstanding!!
Thank you sir.
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 05:42 PM
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 12:10 PM
The Driveshaft Shop Custom Axles and Shafts Sportsguy83 Engine, Exhaust, Transmission 26 01-11-2013 05:55 PM
Automatic Carbon Fiber Driveshaft? Yes! RallySport Direct Engine, Exhaust, Transmission 13 12-15-2012 01:40 AM
