Old 04-18-2013, 10:12 PM   #29
swift996
swift996's Avatar
Originally Posted by wparsons View Post
SRT4's with stickier tires would easily hit a 13.8 otherwise stock, and since RWD hooks up way better I wouldn't doubt an FR-S could easily hit a couple tenths faster still.
An e46 M3 will run a low 13 with the stock 330hp at the crank and about 600lbs more weight (they're ~3400lbs), so I see no reason why an FR-S making an honest 250whp couldn't run low 13's either.
I ran a 13.047 with my M3 (w/ intake) and had a friend run a 13.9 many years ago in a bone stock SRT4.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 04-19-2013, 04:14 AM   #30
s2d4
s2d4's Avatar
Originally Posted by kioton32 View Post
I will be fine taking a base system and modifying it to be what I want... Putting a larger blower means ill have to modify the bracket and base and I'm fine doing that... I know what om doing and am not going to ruin anything... I'll be doing a full build thread to show progress and it will be fine.
So you are going to spend 3.6k on a kit and only have use for one pipe? The inlet, outlet, placement and size (specifically length) may mean that it wont even fit let alone the extensive modification.
Perhaps it would make much more sense to start from scratch if you knew what you are doing?
Old 04-19-2013, 09:44 AM   #31
wparsons
wparsons's Avatar
Originally Posted by Xdragonxb0i View Post
it doesnt quite matter the methods, just the HP and TQ curves.
500whp will get you in the 12s or less but at this point the the problem will be putting all the power down to the wheels
There's at least one car making ~400whp on video running an 11.3@127mph, 500whp is enough to get deep in the 10's if the transmission holds up.
flickr
Old 04-19-2013, 11:29 AM   #32
Supermassive
Supermassive's Avatar
Accelerated Performance posted an 11.2 on 460WHp, so yeah it's possible.
Supermassive is offline   Reply With Quote
Old 04-19-2013, 11:44 AM   #33
kioton32
kioton32's Avatar
Drives: 14' Monogram FRS, ulramarine, white
I need the intake manifold, fuel rail, downtube, pulley, belt, and the ecu remapping tune for the Twin Screw... A TS SC is a lot different then a turbo tune or centri SC so I need thier tune to modify.
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
kioton32 is offline   Reply With Quote
Old 04-19-2013, 01:07 PM   #34
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I would guess upper 13s-14s with low to mid 200s in whp, as it will depend on the driver as well as the car. I've only drag raced a couple times and with a tuned VW R32 with 285chp I did low 14s and with a stock evo 9 rs I did about the same, which seems right since they had similar horses to weight and both all wheel drive.
stockysnail is offline   Reply With Quote
Old 04-19-2013, 02:07 PM   #35
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
And their trap is good for a high 10 second pass. This car doesn't need more than 425rwhp to get into the 10's, it just needs the traction.
For a bit of perspective, a 2014 mustang runs high 11's with that power.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 04-19-2013, 02:11 PM   #36
skatery1989
Drives: BRZ Limited
Thinking about going this week to see how the superchager helped my time.
skatery1989 is offline   Reply With Quote
Old 09-07-2014, 12:12 PM   #37
BRZ NA
Drives: WR blue
Just curious, how much is Jackson supercharger kit weight? I assumed that Turbo charger kit might weight less right?
BRZ NA is offline   Reply With Quote
Old 09-07-2014, 05:58 PM   #38
Poodles
Drives: 2015 Series.Blue
What kills me about that HKS Supercharger making 300HP is how little torque they make. I'm running 7lbs of boost on my turbo setup which is good for 260WHP with 211 Wtq, while the 300WHP HKS setup is making only 222Wtq...
Superchargers are cute...
Also boost spikes come from equipment issues/failures, also if you get a good tune with EcuTek or run an AEM failsafe you can protect your car from such issues.
Doesn't matter, HP is what really wins races.
Old 09-11-2014, 11:28 AM   #39
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You really thought this was the year old thread to bump to get that question answered? Go ask that question in the Jackson Racing Owner's thread. I would say that a JR supercharger using the OEM header would weight more overall than a turbo kit.
1/4 Mile times Boosted2.0 Tracking / Autocross / HPDE / Drifting 368 02-13-2021 07:52 AM
1st time on 1/8' mile FRS8SIX Tracking / Autocross / HPDE / Drifting 1 08-16-2013 06:10 PM
10,000 mile update jeebus BRZ First-Gen (2012+) — General Topics 23 05-28-2013 06:59 PM
My first 100 mile impression bdbx18 BRZ First-Gen (2012+) — General Topics 20 12-12-2012 11:42 PM
Standing Mile _hollywood Scion FR-S / Toyota 86 GT86 General Forum 5 07-16-2012 02:33 AM
