Old 03-19-2013, 02:49 PM   #29
wparsons
wparsons's Avatar
^^ Absolutely not, at least not from being linear alone. If the rates are way too high then it doesn't matter if it's linear or progressive.
flickr
Old 03-19-2013, 03:16 PM   #30
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
Should I worry that RCE's will create more understeer? To a fault perhaps?
eikond is offline   Reply With Quote
Old 03-19-2013, 03:52 PM   #31
Calum
That Guy
Drives: 2013 asphalt FRS MT
In a steady state corner the stock setup is fine, the front end lets go a little before the back making for a 'safe' setup. But have you hit the front bump stops yet? I have a few reducing radius turns on my way to work that I like playing with. Even on OEM tires I have to slow down so I don't run into the damn bump stops and have the back end of my car start racing with the front end.
I like a car that's predictable and controllable at the edge. I honestly can't believe the FRS was release the way it is.
Old 03-19-2013, 04:12 PM   #32
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
I have RCE yellows and love them!
mechaghost is offline   Reply With Quote
Old 03-19-2013, 04:43 PM   #33
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Not at all. Springs are just part of the equasion. Get a good alignment with some actual negative camber and the car will be wonderfully neutral. RCE's starter kit is great for getting a real alignment.
Old 03-19-2013, 05:43 PM   #34
eikond
eikond's Avatar
I've got a set of Yellows ready to install as soon as the weather gets a little warmer. I have some camber bolts as well.. should be a good start.
Old 03-19-2013, 05:49 PM   #35
Draco-REX
Corner Junkie
Draco-REX's Avatar
With the starter kit I'm at -2 degrees front camber and -0.8 degrees rear. The car may want more in the rear, but that's where I'm at for now. On the street it's very neutral. The rear will stick when I want or start following the front if I let it. The front is just perfect with godly amounts of grip.
I've had to wait 7 months to get this to an AutoX. Hopefully it'll be warm enough on the 30th to get a good test. I'm very confident.
Old 03-20-2013, 12:25 PM   #36
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I have a set of these RCE springs in the garage. My car is pretty tail happy even with a alignment. Hoping these settle the back end down a bit. Worried the rebound is going to get even worse though.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 03-20-2013, 01:02 PM   #37
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
What do you have installed for camber correction? What is your alignment?
Grimlock is offline   Reply With Quote
Old 03-20-2013, 01:09 PM   #38
bakerr6
Drives: 2013 raven black fr-s
anyone compare these to mach v springs?
bakerr6 is offline   Reply With Quote
Old 03-20-2013, 01:56 PM   #39
feldy
feldy's Avatar
this is what its at. Soon to be installed are the springs and whiteline rear camber bushings.
Old 03-20-2013, 02:16 PM   #40
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
From what I hear, a bit of toe in the rear (1/16") really settles the back end down. I go for my alignment next week and that's what I'm going to get.
Do you have crash bolts up front? Which ones?
Old 03-20-2013, 02:25 PM   #41
feldy
feldy's Avatar
I have whiteline camber bolts.
Old 03-20-2013, 08:36 PM   #42
panoy86
Drives: FR-S, e36 M3 (all stock)
Very useful thread, thanks all. I met 1 fellow FR-S owner, sw20kosh (i think???) at Thunderhill, and from what I recall he posted a 2:12 on RCE Yellows with 245 or 255 width tires, very impressed.
Anyone knows if any vendor sells the RCE Yellows as a "kit", i.e., springs, camber correction bolts/perches, etc, etc?
panoy86 is offline   Reply With Quote
Insight on winter wheel/tires? BRZranger Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 61 09-20-2013 11:06 PM
Cricket TSB - Local insight needed NickFRS Northwest 12 11-27-2012 05:32 PM
I Spent the Weekend Driving my FR-S in Snow - Insight SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 49 11-16-2012 04:56 PM
Insight on my first M/T Car. Veloist Other Vehicles & General Automotive Discussions 24 08-31-2012 11:58 AM
Would love some insight on these rims... Exhaust Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 03-26-2012 08:02 PM
