Old 02-28-2013, 12:57 PM   #29
MI FR-S
MI FR-S's Avatar
Drives: Ultramarine FR-S MT
Thanks for the pictures.
It certainly helps me to narrow down my choice for an exhaust.
Good luck with contacting them again. Hopefully you get a satisfactory resolution.
MI FR-S is offline   Reply With Quote
Old 02-28-2013, 01:07 PM   #30
Tainen
Drives: First SWP BRZ-L
My info was wrong, sorry!
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 02-28-2013, 01:21 PM   #31
OrbitalEllipses
Drives: Attitude
Originally Posted by Tainen View Post
FYI, perrin exhaust is not made in USA. not sure if it's 304ss or 409ss either. But I <3 Perrin as a company.
"Designed by Perrin in Oregon" sticker not included?
Old 02-28-2013, 01:32 PM   #32
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Wow. That is alot more rust than I expected. Scotchbrite is the correct tool for this job.
LINK - couldn't find less than a 20 pack, but the maroon (fine) or gray (coarse) styles do a great job on stainless.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 02-28-2013, 01:37 PM   #33
DarkSunrise
DarkSunrise's Avatar
See below.
Originally Posted by PERRIN_Mladen View Post
All our PERRIN catback exhausts are 100% made in the USA. Even down to things like the mufflers, flanges, tips, every part of it is! We pride ourselves on not having to go overseas to be competitive on things like catback exhausts. It's important to keep the US economy rocking and it's a way for us to feel good about what we sell.
Originally Posted by PERRIN_Chris View Post
Don't worry, the PERRIN exhaust is 304 stainless throughout, plus has a lifetime warranty!
2022 BRZ Build
2013 FR-S Build
Old 02-28-2013, 01:51 PM   #34
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
What a shitty exhaust, the stock one on my car has almost no rust and I went through a lot of salty roads here also since november. Not impressed at all.
Rayme is offline   Reply With Quote
Old 02-28-2013, 01:57 PM   #35
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Dang I almost got the Takeda exhaust, too, to go with my Takeda intake. I think if you clean it a bit then maybe spray some rust neutralizer that converts the rust into a firm material you'll be good. But I'd confirm with someone who knows if that's safe on an exhaust which needs to expel heat. I'm not too familiar with automotive rust lol because I haven't lived in a cold winter area til this past year.
Skip to the 4:00 minute mark to see where I got this idea:
[ame="https://www.youtube.com/watch?v=i1TQPx_0mkU"]Mazda MX5 part 2.avi - YouTube[/ame]
IMO only the tips really matter for aesthetics and yours are still good. Exhausts are wear items anyway and start deteriorating the moment you start using them. Plus your rust probably matches other spots in our under body that I've seen rust even when not in winter weather. If your exhaust still sounds good, breathes good, and isn't rusted through the inside then you should be fine for awhile.
Old 02-28-2013, 01:57 PM   #36
trish07
Drives: Scion FR-S 2013
I wonder, if I clean the rust, will it appear again in a few month?
For safer roads
TEAM MASC - JOIGN US AT WWW.TEAMMASC.COM OR ON FACEBOOK!!!
trish07 is offline   Reply With Quote
Old 02-28-2013, 02:29 PM   #37
Shankenstein
Frosty Carrot
I take back the statement. Check out this link: MATERIAL SPECS
They suggest that the surface coating will happen in normal air, and a light rust will protect against further corrosion. Seems like you should not remove the rust, but rather just deal with the finish.
I don't like that answer, but a few other sources say similar things.
Borla uses 304, I've seen some pricey systems use titanium. Cheap exhaust is aluminized steel. This is the first I've ever heard of 409, but apparently it's the go-to material for exhausts because it's inexpensive, relatively corrosion resistant, and weldable.
Old 02-28-2013, 02:37 PM   #38
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Ouch to the response you got
Hope for the best
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 02-28-2013, 02:44 PM   #39
switchlanez
Based on @Shankenstein's finding, I take back what I said about cleaning it off and spraying rust neutralizer.
Old 02-28-2013, 03:32 PM   #40
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by 2forme View Post
This makes me want to check my SRT.
the SRT exhaust is stainless steal. mine sat around in constantly melting and the freezing snow all winter. Exhaust is still solid. I will check it this week and confirm with you but a few days ago it looked great.
Old 02-28-2013, 03:41 PM   #41
trish07
First of all, thanks to all of you guys. Really appreciate your help!
The thing is, you can see partially the "S" in the exhaust and the rust on it. The tips are fine, but if you took a closer look, you can see the rust over the rest of the exhaust.....I like my things to look "mint"....I can't beleive it......
It sounds so good, perfect to me
For safer roads
Old 02-28-2013, 04:29 PM   #42
trish07
Also, I may be wrong, but I don't see anything about the "409" stainless, here's the description of the exhaust from their website:
Availability: In Stock
The Takeda cat-back exhaust system produced 3 horsepower and 5 lbs. x ft. of torque. This unique transverse exhaust system is constructed from 2.50" mandrel bent stainless steel and is MIG-welded. This system was designed and engineered by tuning the perfect tube lengths, ultimately maximizing performance across the power band while maintaining a great tone. Countless hours of R&D was used to ensure the perfect decibel level without compromising performance, furthermore, ZERO DRONE. To finish off this exhaust are two 4.75" oval double wall 304 polished stainless steel tips. This exhaust uses all factory hanger locations for a hassle free installation. No modifications necessary.
All aFe exhaust systems are engineered and manufactured in our Corona, California manufacturing facility.
Simple Installation:
All systems use factory mounting locations providing stability and hassle-free installation.
Leak-Free Seal:
High quality band clamps are used for a complete 360 degree sealing surface.
Aggressive Sound:
A free-flowing muffler is used to absorb high pitch tones producing a powerful sound and unleashing all available horsepower and torque.
http://afepower.com/shop/details_new...0-P&print=true
For safer roads
afe Takeda Exhaust Minovsky Engine, Exhaust, Transmission 6 04-04-2017 11:30 PM
**SPECIAL PRICE ON AFE TAKEDA EXHAUST SYSTEMS** genometuning Engine, Exhaust, Bolt-Ons 41 09-12-2013 03:35 PM
AFe Takeda Cat Back Exhaust FR-Shadow Engine, Exhaust, Bolt-Ons 7 01-07-2013 01:20 AM
Anybody else's car rusting yet? Selvedge Issues | Warranty | Recalls / TSB 17 10-31-2012 09:11 AM
aFe Power/Takeda Air Intake System and Exhaust aFePower Engine, Exhaust, Bolt-Ons 10 08-06-2012 03:03 PM
