Old 04-12-2016, 12:32 PM   #29
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Mythbusted
Old 04-13-2016, 10:42 PM   #30
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I love that this old thread is still up for debate!
Pure Automotive is offline   Reply With Quote
Old 05-13-2016, 04:56 AM   #31
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Mate you could amply the throttle signal to 400v and it wont get you any more power.
That thing just adjusts the voltage output of the stock accelerator pedal sensor, such that say a small movement of the accelerator pedal can now cause a larger voltage to be applied to the ECU input and hence cause a larger throttle plate movement for a smaller accelerator pedal input change.
This will certainly give you the impression that the car has more power or acceleration, but the simple fact is its not going to produce any more power or torque than if you just were more aggressive with the standard setup.
The ecu has say a 0 to 5v input and this is interpreted as the accelerator pedal movement say 0v is no throttle and 5v is full throttle. Your device can adjust the rate of change of this voltage, but putting more volts than 5v onto this input of the ECU achieved nothing as the ecu has already interpreted it as 100% throttle application at 5v so feeding 6v or 8v into it achieves nil.
you can achieve the same result by adjusting the throttle tables in the ecu code, but again you produce NO extra power or torque. your just adjusting the "feel" of the throttle pedal to make it more or less aggressive.
for the cost of that device you could likely get a proper ecutek or oft or other tune and actually achieve power and torque increases, by actually changing the ignition timing, fueling, intake and exhaust cam timing.
If you want one of those throttle controllers then buy one but the claims are false and misleading.
Originally Posted by churchx View Post
steve99: it's as you wrote on all accounts of how it works and what provides, what not .. but still, that 'feel good' bit, that some testing it reported. - Yes, it won't bring more power, but seems that those that tried, prefer throttle opening curve with this to that of OEM .. so at very least imho this might be worthwile mod to try to implement with OFT, alongside other existing mods, like cold start, economy mods and such. Just like clutch pedal bite point adjustment or short throw shifters, it may enhance enjoyment of driving and imho worth experimenting with, even if there is no actual performance improvement except subjective feel. But it's fun we are after in these cars, no?
Throttle tables are not changed in OFT? Too bad ... It would provide a more direct pedal feeling and as mentioned I believe that it provides a better torque curve in the low-mid range. It doesn't solve completely the torque-dip issue, but I believe that it gives a better feeling. By the way, I never stated that this kit provides an increased peak power.
Personally, I don't like to play with the ECU tables and values. I did this once in another car with the FB20 engine, but I don't want to do it again. In the other car, the results were as stated before. I had a better drivability and the reason was not that I didn't floored the gas pedal.
Anyway, I already ordered a sprint booster kit. I'll receive it today and install it tomorrow. I'll provide afterwards feedback.
The Following User Says Thank You to nikitopo For This Useful Post:
steve99 (05-13-2016)
Old 05-14-2016, 12:35 PM   #32
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I drove my car today with the sprint booster. It is the best modification I've ever done. The difference is much bigger in comparison to a similar modification in the FB20 engine. The FA20 engine has much more potential! Overall, my car is now very different in the mid-low range with much more torque. I am very happy with the change. I definitely suggest this modification.
Old 05-14-2016, 03:14 PM   #33
KoolBRZ
KoolBRZ's Avatar
This item is ideal for all those people that have leased their car. They don't want to do anything permanent, yet they want more power. So, for all those out there who want more power, but want it easily returnable to stock for lease return or dealer service, here is the product for you. It doesn't say anything about mileage though, so count on your city mileage going down.
If I say yes, will that make you think I understand?
Old 05-14-2016, 03:24 PM   #34
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Ridiculous, buy an OFT then and do a stage 1 tune, instead of using some sort of device that just intercepts the throttle map. OFT is easily not permanent and can be flashed to stock and be sold for almost no loss.
I'm confused why are people saying this gives more power and torque, all it does is remap throttle response. I won't believe this scam till someone shows dyno proof it gained power. This isn't a worthwhile mod, its a farce that gives you the assumption of speed, power and a "better torque range" as you described, buy an open-flash tablet and you can actually get some real results.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
humfrz (05-14-2016)
Old 05-14-2016, 03:55 PM   #35
humfrz
Reminds me of back-in-the-day when some folks would drill out the jets in a carburetor.
Yes, that would let more gas into the intake manifold, but, without changing the cam, all that it did was ....... burn more gas ....... car didn't go any faster ......
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
FRSBRZGT86FAN (05-14-2016), MTpockets (05-14-2016), Tcoat (05-17-2016)
Old 05-14-2016, 04:43 PM   #36
FRSBRZGT86FAN
humfrz
I've re jet a carb on a friends car and bear in mind how young we are I dropped the float needle and lost it somewhere underneath the car, it wasn't a good day after that.
Tcoat (05-17-2016)
Old 05-14-2016, 04:56 PM   #37
ryoma
ryoma's Avatar
a cheap (free) easy alternative to this is to just push the gas pedal further... come on now, are you guys afraid of going past that halfway mark on the pedal?
The Following 2 Users Say Thank You to ryoma For This Useful Post:
FRSBRZGT86FAN (05-14-2016), humfrz (05-14-2016)
Old 05-14-2016, 05:40 PM   #38
humfrz
Yep, they were slippery little bastards ....... time for a trip to the junk yard .......
humfrz
Tcoat (05-17-2016)
Old 05-14-2016, 05:41 PM   #39
humfrz
shhhhhhh ...... let that be our secret .........
humfrz
Tcoat (05-17-2016)
Old 05-14-2016, 06:17 PM   #40
FRSBRZGT86FAN
Further and faster
Old 05-16-2016, 10:43 AM   #41
exS4
Drives: 2013 Sprintex SuperCharged FRS
I get it
When I used to have a 2000 MustangGT, it had 2 throttle return springs. I removed one spring and instantly got quicker throttle response! It didn't make it any faster, but it did make it much more responsive and fun to drive.
So I can see the point of this product assuming it works as advertised.
2013 FRS, 6Speed. HeavyDuty Clutch, AluminumFlywheel, Bilstein Coilovers, Sprintex SC w/small pulley, E85FlexFuel, WhitelineFrontSwayBar, Michelin PilotSuperSportTires, DeliciousTuning/Ecutek, AP Racing BBK, Carbon Fiber DriveShaft, JDL UEL Exhaust, Big Radiator, Oil Cooler, Ventilated Carbon Fiber Hood, Carbon Fiber Rocket Bunny Kit, Carbon Fiber Interior pieces, and a bunch of other stuff!
exS4 is offline   Reply With Quote
Old 05-16-2016, 03:18 PM   #42
KoolBRZ
KoolBRZ's Avatar
I think there is something being overlooked here. The ECU's sensitivity to voltage changes is increased by this adapter. As any OFT user can tell, throttle sensitivity drops after loading a tune. I think this is because the signal is below a certain threshold, and the ECU drops that threshold over time as it "learns". I think the "off-idle" transition is at a very low signal strength, and is hard for the ECU to recognize, immediately after a flash. If this adapter sends a more recognizable signal to the ECU, it would eliminate that "off-idle" delay that infuriates every drive-by-wire performance driver.
TOYOTA EMBLEMS FOR YOUR FRS! @ PURE AUTOMOTIVE PERFORMANCE Pure Automotive Exterior Parts - The Rest 12 02-18-2013 06:36 PM
Anybody want to help me pick up my car at Pure Automotive? TyperRspec789 Mid-Atlantic 4 01-31-2013 03:07 PM
Anyone tried the Sprint Booster? Black Tire Engine, Exhaust, Transmission 6 01-27-2013 05:13 PM
Throttle Controllers harajukukei Engine, Exhaust, Transmission 31 07-28-2012 01:40 AM
