Old 10-06-2012, 08:50 PM   #29
Rawhyde
Drives: B4C Camaro, 2005 MINI JCW, Civic
Originally Posted by 70NYD View Post
Itold you in the 1st reply
1 you can get a narrow chisel and a hammer and break the al nut apart
If that fails
2 drill the stud out
His lugs aren't just aluminum. The threaded portion is steel.
Rawhyde is offline   Reply With Quote
Old 10-06-2012, 09:12 PM   #30
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
you can see the helicoil section still on the thread of the stud, it's only a very thin section of steel...
edit: Also looks like you might have been sold knock-offs... http://forums.clubrsx.com/showthread.php?t=817526
JP is offline   Reply With Quote
Old 10-06-2012, 10:18 PM   #31
Hanakuso
oh man that sucks. It does look like the packaging wasn't the real deal. I hope they weren't advertised as real.
Hanakuso is offline   Reply With Quote
Old 10-06-2012, 10:24 PM   #32
JohnS_Rosamond
Drives: Mazda MX5
Not that you really want to do this, but...
If you can get a chisel or a punch in there, you might want to see if you can make a little land there (for the punch) and then see if you can rotate the lug nut usingthe punch. While I like the dremel idea (trying to make a hex head), I am not sure that it could be done evenly. There is one other suggestion. They make special sockets to remove lug-nut locks (when you've lost the key). Usually they need a fairly deep something to grab onto, but if you got the right size, you might get lucky. To me, I think that drilling the stud might be a losing proposition as you'd have to be dead centre for almost the whole distance (with a bit bit).
JohnS_Rosamond is offline   Reply With Quote
Old 10-06-2012, 11:04 PM   #33
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Looks like you got some fakes there. That sucks. I would get the rest of those off as soon as possible and make sure you get the legit ones.
jadewbj is offline   Reply With Quote
Old 10-07-2012, 01:39 AM   #34
70NYD
70NYD's Avatar
Drives: RX8 S1
The thread of the nut isn't important. If you can break the 60 deg cone seat with I chisel, like I said in the 1st reply of this thread, you can unscrew it with a finger.. You need to break apart the seat first
70NYD is offline   Reply With Quote
Old 10-07-2012, 07:27 AM   #35
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Honestly, your best bet is to drill it out.
Use good sharp bits, start dead center of the stud with a small bit, then a medium, then one the same diameter (or just slightly bigger) than the stud.
It will definitely work, just be careful and use good bits.
uspspro is offline   Reply With Quote
Old 10-07-2012, 10:08 PM   #36
nix
nix's Avatar
Drives: AVO BRZ
Agreed, safest way forwards is drilling the stud out. If you feel confident and have experience do it yourself (mask up the wheel) otherwise pay a shop, not worth scratching the wheels over.
PS. Don't feel bad, most of us have broken a stud or nut by over torquing, even tyre shops do it occasionally.
nix is offline   Reply With Quote
Old 10-08-2012, 04:24 AM   #37
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Yeah I would feel bad if I thought I was over torquing but In this case Im sure it was a faulty component as all 19 went on at the same 1/2 drive wrench tension and this one fractured
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 10-08-2012, 05:31 AM   #38
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I thought I saw that pic before...
I think its time to upgrade to titanium lugnuts.
EDIT: http://www.tikore.com/manage.numo?mo...=catalog&cid=1
stevo_12v is offline   Reply With Quote
Old 10-08-2012, 10:15 AM   #39
JDMenrique
DEEEERP
JDMenrique's Avatar
Whatever you do don't fuck up the wheel! I have to agree with what the general response on here is. I'm an aircraft mechanic and this type of shit happens more often than id like it to.
The lug nut sheared. Whether it was due to overtorque or defective material doesn't matter. This would be my sugguestion if you did decide to do it yourself. Its the same process as removing a rivet.
Find a punch with a point tip and with a hammer center the punch on the stud. You are trying to create an indentation as a guide for your drill bit when drilling the stud. I would sugguest you use a drill bit that is a size smaller (if not two) than the diameter of the stud. Place your drill on the indent created by your punch and starting slowly and increasing speed drill through. You only need to get slightly passed where the lug nut sits so you should not come in contact with the wheel. After that it should be pretty easy to come off.
If you don't feel comfortable doing this, then dont. I would suggest you take it to a professional. Keep us updated.
JDMenrique is offline   Reply With Quote
Broken Sun Visor feldy Issues | Warranty | Recalls / TSB 99 10-10-2022 10:33 PM
Heart broken.....Subaru brz FT86FRS CANADA 26 09-09-2012 03:45 PM
Broken window = out of commission. Mitch BRZ First-Gen (2012+) — General Topics 11 09-02-2012 11:04 PM
First brz broken into...sigh zex CANADA 74 08-04-2012 05:17 PM
Broken Window Help! zex Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-28-2012 03:54 PM
