Old 10-17-2012, 03:21 AM   #29
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Originally Posted by diirk View Post
How do you figure this? 17x8 +35 will fit fine and allow a 245/40-17 to be run with maybe -2°of camber. Unless everyone else is wrong.
Well, as I said in my post, if you run some high camber as you just pointed out. Of course I may be wrong after some further research. It would work great on the track. And I did see someone ran wider tires with some more rolling of the fenders. But they do still stick out a bit with +35 wheels up front. In the rear I think they would tuck in nicely. But again, you are also talking about an 8 inch wheel vs. a 9 inch wheel. My reference was to 9 inch. I'm just concerned about the front.
JimmyMac is offline   Reply With Quote
Old 10-17-2012, 05:07 AM   #30
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I was just answering why the 8" width doesn't have the flat face
I didn't say anything about fitment.
9" wide wheel with +35 offset is going to poke up front on stock suspension, yeah.
but with springs/coilovers and some camber it'll fit fine
but if I wanted track wheels I'd go with the 17x8 personally
dori. is offline   Reply With Quote
Wheel Directory: WedsSport TC105N 17x8.0 +42 Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 94 06-21-2019 05:33 AM
FS/FT: 17x8 +35 TE37 Bronze bAS1c Wheels and Tires 17 05-02-2014 12:52 PM
Wheel Directory: Advan RG II 17x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-11-2012 08:28 PM
17x8 +35, will it rub? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-31-2012 04:26 AM
17x8.5 wheel selection Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 06-10-2012 04:13 AM
