Old 10-05-2012, 11:59 PM   #29
D-VO
Drives: Whiteout FR-S, Evo 8 RS
That's really disappointing to see that the aFe doesn't make as much power as they says it does.
http://afepower.com/shop/details_new...ily&brandID=78
They're showing a max gain of 10hp at around 4700rpm. What the hell?
By the way, I ran into a thread talking about the loss of a pony with the noise generator deleted.
http://www.ft86club.com/forums/showthread.php?t=10366
Has anyone dynoed with and without the noise generator while using one of these intakes?
D-VO is offline   Reply With Quote
Old 10-06-2012, 07:51 AM   #30
2forme
Yea, I'm pretty sure a lot of the manufacturer dynos were done on different days, which can relay different results. I've had my car (not the BRZ, but a different car) baseline with a 5whp difference on different days and the same dyno.
Quite honestly I don't think any intake makes much power on a 91/93 tune. The reason is @Visconti or any other tuner essentially tune out the ideal AFR curve negating any modifications to it that the intake would normally change on a stock ROM.
Now, with that said, the aFe DID outflow the AIRAID by a considerable margin. To take more advantage of that, you would need to tune the intake and exhaust valve timing, and adjust the VE accordingly. We didn't have nearly enough time to do that, that day. But perhaps it might be in the future.
I'd like to note that on my dynos, all stock runs had the noise generator. All intake runs did not.
Old 10-06-2012, 08:32 AM   #31
2forme
Also, on another note... why doesn't this forum have a review section? Or at least a sticky with links to reviews? I think it would be greatly helpful.
Old 10-09-2012, 12:50 AM   #32
D-VO
I understand that the intake cannot be maximized without a tune, but to pay nearly $1000 for something I can't tune myslef is out of the question. I got really lucky with my Evo because there's an open source tuning option available, so i was able to do it myself. I think I'm going to look for a shop with a dyno near me to do the test myself if no one else comes up with an answer before then.
Old 10-09-2012, 07:17 AM   #33
2forme
An answer to what? You didn't really ask a question.
Old 10-09-2012, 09:58 PM   #34
D-VO
I did.
Old 10-10-2012, 09:44 AM   #35
2forme
I did.
Oops, sorry, I had just woken up.
I didn't have a plug for the stock intake so I wasn't able to dyno with and without the noise generator. The aFe was dynoed without, though.
Old 10-10-2012, 06:44 PM   #36
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Removing the snorkel is a must for any aftermarket system. I thought it was understood so I didn't include it in the instructions. It's much easier with two people.
First, thanks 2forme for doing the tests. Although, the results are disoncerting, at least I now have more info. Bums me out that I spent money for some noise, although it's some kick ass noise. I really thought that the Airaid system made power based on what I read of their results. Live and learn I guess...
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
The Following User Says Thank You to zoomzoomers For This Useful Post:
2forme (10-10-2012)
Old 10-10-2012, 08:56 PM   #37
zoomzoomers
I wonder if the guys at Airaid have seen this thread and if they care to comment. Or even inject some of their own data that might refute what you've seen.
Old 10-10-2012, 09:29 PM   #38
ModBargains
ModBargains's Avatar
Drives: FRS, M3
Thanks for posting up the reviews!
-Frank
ModBargains is offline   Reply With Quote
Old 10-10-2012, 09:52 PM   #39
2forme
They can say whatever they want. I posted videos of my issues. @Visconti has done dynos. @Drift-Office has done dynos on two different cars. Nothing they say will fix the bogging I had, or make the intake easier to install, or make those cars make power. I'll gladly offer up my log files to anyone who wants to view the raw data themselves
Old 10-11-2012, 12:10 AM   #40
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I sent them emails asking them these very questions
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-12-2012, 03:54 PM   #41
2forme
I just conducted some temperature testing. I updated the review with this information, but for those who are too lazy to go back and read, I quoted it here Keep in mind, lower is better. The lower the number, the closer to outside temp.
There is a good 1-2 inches of gap space in there. This results in considerably hotter intake temps while driving and throughout the rev range when compared to the aFe. However, the larger filter box helps curb the temperature rise while idling above 2.5 minutes.
Here is a graph showing the idle temp climb over a period of 5 minutes. It compares the delta (difference between IAT and ambient), rather than raw temps, to get a more accurate idea of how heat soak will affect the IAT's at idle. Since the aFe is a true CAI, it registers a lower delta up until about 2.5 minutes. Since the AIRAID has a larger filter box, it's temperature progression is less aggressive than the aFe unit; it doesn't heat soak as fast.
Temperature wise, aFe is a much "cooler" intake. Both intakes are branded as CAI's, while I'd technically consider the AIRAID as a LWAI or Luke Warm Air Intake. As you'll see by my graph of a full 3rd gear pull, the aFe registers a much lower temperature delta (the difference between the IAT and ambient temp), which is compounded by the fact that AIRAID locates the sensor in the filter box, where the air would most certainly be the coolest. aFe locates the sensor on the final stretch of piping right before the throttle body.
Old 10-22-2012, 03:41 AM   #42
Burn
Slack Bum
Burn's Avatar
Hi 2forme,
Do you have a overhead shot of afe intake as I would like to see how much distance between the oil filter and the intake box as my current airaid box is quite near to the oil filter mount and I'm quite concern on the suitability of mounting a sensor adapter when I want to fix on the oil temp/pressure sensor . Thanks
Burn is offline   Reply With Quote
AIRAID vs aFe vs Stock shoot out 2forme Engine, Exhaust, Transmission 108 07-21-2013 09:30 PM
Poll for AIRAID engraving 2forme Engine, Exhaust, Transmission 11 08-13-2012 08:26 AM
Mold - in helmet? Anyone deal with this before? Dave-ROR Tracking / Autocross / HPDE / Drifting 17 08-06-2012 10:44 AM
AZ- Airaid test driver needed Keith@AIRAID Southwest 3 07-19-2012 05:00 AM
Hello From AIRAID Filter Company AIRAID Announcements, Contests, Giveaways 3 06-11-2012 08:00 PM
