Old 10-05-2012, 01:24 AM   #29
boonFRS
Drives: 2013 Scion FRS whiteout
I'm in for a group buy. I don't mind paying 5 for the spoiler painted.
boonFRS is offline   Reply With Quote
Old 10-06-2012, 03:48 PM   #30
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
I bought a factory style lip spoiler for my last car, Lancer GTS, it was $130 shipped color matched from spoiler express or something. It mounted perfect and perfect color match. pricing will come down on this stuff just not sure when. Probably when these bigger companies start making them. I'm looking for something subtle in the 300-$350 range painted and shipped.
FastLane1000 is offline   Reply With Quote
Old 10-06-2012, 03:55 PM   #31
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Originally Posted by jadewbj View Post
I used a cheap ebay lip like one one here (that is actually my car):
http://www.ebay.com/itm/Trunk-Lip-Sp...sories&vxp=mtr
They sell them in all kinds of lengths. You just need to measure the trunk line.
I actually ordered a blank lip spoiler and roof spoiler from this company. When it arrives I will modify it to fit the car, then have it painted. We'll see how it turns out.
The Following User Says Thank You to DarrenDriven For This Useful Post:
PMok (10-06-2012)
Old 10-06-2012, 04:43 PM   #32
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Originally Posted by Flow View Post
From http://www.grazio-co.com/86/86_spd.html
Drawing on my 20yr rusty japanese, the 4th item from the bottom of the price list says ToRaNKu RiPu SuPoiRa = Trunk Lip Spoiler, which is listed as = 29,400 Yen or ~375US.
The 3rd item from the bottom also says ToRaNKu RiPu SuPoiRa = Trunk Lip Spoiler, then 'KaRa-Bo', which I'm blanking on, and is listed at 39,000 Yen, or around $508 US. Edit. "KaRaDo", not KaRaBo, which I'm betting = Colored/Pre-Painted, given that it's used in other line items as well to distinguish between otherwise identical items w/ different prices.
Hope this helps.
Can you decipher any of the text next to the "Sportdesign Rear Fender Garnish"? Are those supposed to serve some kind of purpose?
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 10-06-2012, 10:49 PM   #33
Flow
Drives: DGMBRZ
Well, I was going to say no, cause it had all those ideograms, but when I went to look, Chrome offered to translate it. So, for what it's worth:
"And appropriate aesthetics and rear tire size light weight sport claiming to
be released in order to secure a large allowable even a little, "rear fender
garnish. " Delivers a wide 7mm each of the left and right fixed genuine
safety standards at two services, it further reinforced with double-sided tape and the entire clip
is the specification of adaptation. At the same time it looks just like a European super sports
enjoy. * 4 * Be sure to refer to the lower notes."
Flow is offline   Reply With Quote
Old 10-06-2012, 10:52 PM   #34
Flow
Drives: DGMBRZ
And, here's the full price list, as translated by Chrome. (btw, they moved the trunk prices since my earlier post. They're now the lines beginning with "Tran")
<86 SPORTDESIG N Toyota price compatibility table>
Bodies Front Spoiler 33,600 yen  +5 Mm ground clearance under the bumper bolt fixed ratio genuine genuine
Colored front spoiler 47,250 yen  +5 Mm * 1 ground height ratio fixed bolted under bumper genuine genuine
Bodies side step * 3 44,100 yen  Double-sided tape + bolt fixing scheme cover
A colored side steps * 3 73,500 yen  * Fixed 1 double-sided tape + bolt-on cover system
Processing bespoke two-tone colored side step * 3 10,500  * 2 If the amount of painted as a demo car lower than the center line
Bodies rear mudguard 23,100 yen  1SET fixing bolt left and right
Colored rear mudguard 31,500  1SET * 1 bolt securing the left and right
* Spoiler foundation SPORTDESIGN point SET 3 97,650 yen  SET 3-point front / side / rear guard Matt
* SET colored spoiler SPORTDESIGN point 3 149,100 yen  SET * 1 3-point front / side / rear guard Matt
Tran foundation spoiler clip NEW ¥ 29,400  Fixed double-sided tape
Tran colored spoiler clip NEW 39,900 yen  * Fixed 1 double-sided tape
Bodies rear roof spoiler ¥ 29,400  + Double-sided tape fixed bond
Colored rear roof spoiler 39,900 yen  * Fixed 1 + bond double-sided tape
Bodies rear fender garnish NEW 13,650  7mm wide * 4 fixed at two side clips + screws genuine
Rear fender garnish colored NEW 23,100 yen  7mm wide * 1 * 4 fixed at two side clips + screws genuine
Old 10-11-2012, 02:33 PM   #35
Flow
Drives: DGMBRZ
While not as subtle as the Grazio, I think the Doall Circuit Spec Tune rear lip qualifies, and might appeal to some: http://www.ft86club.com/forums/showp...2&postcount=72.
Old 10-11-2012, 03:05 PM   #36
DarrenDriven
NW Region Moderator
OK, well I learned that the cheap eBay solution is NOT a solution. The components arrived and although it is flexible rubber material, it can only flex across the horizontal plane and would only work for a gently curved trunk. Since the FR-S trunk has a serious compound curve the material will not bend in two directions without warping. Bummer.
The roof spoiler has the same issue. The top corners of the FR-S rear glass has an angled design element that the material just can't compensate for.
Well, $100 down the drain!
Old 10-11-2012, 03:44 PM   #37
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Did you try and heat it?
The one I had on my M45 was quite soft, bent like a snake.
jadewbj is offline   Reply With Quote
Old 10-11-2012, 09:44 PM   #38
PMok
Codename: Stitch
PMok's Avatar
Bummer... Will they take it back since you didn't/couldn't install it?
Old 10-12-2012, 03:26 AM   #39
DarrenDriven
NW Region Moderator
They gave me a 50% refund. I am pretty sure that this material isn't going to contour to the sharp angles of the FR-S trunk line, but I'll try applying heat.
Old 10-12-2012, 03:31 AM   #40
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
painted STI lip gives it a real nice look
chulooz is offline   Reply With Quote
Old 10-12-2012, 09:06 AM   #41
jadewbj
jadewbj's Avatar
Not sure it would work but if you had nothing to do with it I was just curious.
Old 10-12-2012, 02:15 PM   #42
DarrenDriven
NW Region Moderator
It was an experiment, and I'll try to make it work. Who knows, just maybe....
BRZ spoiler on the 86 Z86 AUSTRALIA 38 05-12-2013 12:39 AM
Anyone know this spoiler? Spencer Strayer Cosmetic Modification (Interior/Exterior/Lighting) 2 09-11-2012 03:32 AM
New rear spoiler choice: Carsmo rear spoiler Ray@Carsmo Cosmetic Modification (Interior/Exterior/Lighting) 46 08-10-2012 03:20 AM
FRS With Lip Spoiler ryansb FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 42 04-21-2012 12:19 PM
Ugly Rear Spoiler - Spoiler Delete? iLuveKetchup BRZ First-Gen (2012+) — General Topics 31 02-01-2012 11:57 AM
