BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
11-08-2023, 01:25 AM | #29 | |
Drives: Subaru BRZ 2017
Now regarding the stalling and long crank. Think we may have found the issue. The fuel pump replacement on the AEM pump is missing additional o-ring? I had the engine idle for few minutes. turned it off and removed the fuel line for compression test. Guess what? No fuel? like just a couple of drops.. I mean i literally just turned it off and the car should hold pressure. So I went straight the fuel tank and did the compression there to make sure the fuel line isn't leaking along the way (from the pump). I got same result (pressure is only up to like 30psi and then drops right back to 0). I finally discovered that the pump is missing missing o-ring which is (probably causing the long crank as far as I know). Now, I won't jump into full conclusion if that's what's causing the stalling after reaching driving temp but I'm betting it's might be. We shall see once i reassembly things ~ waiting on the fuel kit. |
The Following 4 Users Say Thank You to ojuniour For This Useful Post: |
11-08-2023, 01:47 AM | #30 |
chicken tonight
Oooo... Yes. Very interesting. ...and plausible!
11-09-2023, 11:28 PM | #31 |
Alright lads and gents. I've updated the original Post for the update.
Thanks for the continued input. Hopefully this helps someone else in the future 😤 whatever you guys think of the current logs? |
11-11-2023, 02:43 AM | #32 | |
Drives: Q5 + BRZ + M796
https://datazap.me/u/ojuniour/idling...88-93&mark=961 I highlighted every perimeter that seems to be cycling with the idle. --Your fuel rail pressure is hitting the 4 mpa target. --No misfires --Fuel trims seem to be within acceptable levels, but I am not a tuner, so take that with a grain of salt. I see people saying within 10% as normal. The LTFT is negative, but this could be because of the repeated oscillations in fuel delivery making things rich, so the system is trying to reduce fuel. The STFT should oscillate back and forth to make fine adjustments and to keep the catalytic converter happy at idle. --Idle is oscillating, but I don't know if it is really noticeable oscillating between 800-850 rpms. Seems like the spark, injector, target map, are all adjusting, and we see maf increase, map increase, and fuel increase to meet the adjustments. The idle speed control (ISC) system per ECUTEK (I believe that is what ISC acronym is referring to) is confusing me. I don't really know what it is because the DBW system would control the throttle, but the throttle is staying "closed" or isn't fluctuating, so our cars do not have the typical air control valve or something to bypass the throttle, unless I am wrong; the system seems to be making corrections or responding cyclically inline with the other parameters. https://datazap.me/u/ojuniour/idling...56-80-82-88-93 --I'm confused why your target is oscillating with your actual AFR. My target is locked at 14.7 at idle, and my actual is slowly moving up and down within 0.05-0.10, but you are hitting 0.5 and are oscillating oddly. What is changing the target AFR or why isn't it locked at 14.7 at idle? I don't know. https://datazap.me/u/ojuniour/idling...8-93&mark=1449 --The oxygen sensor seems to be fluctuating, but I don't know if this is normal with a changing idle, or if the oxygen sensor is sensing a leak, which is causing the idle fluctuations. Chicken or the egg scenario. For the other logs: --Fuel rail pressure is matching target now. --No misfires. --Long term fuel trim is much too high. System is lean and trying to add fuel. This suggests a vacuum leak to me or exhaust leak near the O2 sensor. Maybe something between your MAF and TB. Do that smoke test and exhaust manifold test like I mentioned on texts.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | norcalpb (11-12-2023) |
Similar Threads | ||||
Stalling at idle - HELP!! | Celigts | Issues | Warranty | Recalls / TSB | 27 | 09-13-2022 01:51 PM |
BNIB Fluidampr Crank Pulley + New Crank Bolt + Crank Pulley O-Ring - SOLD | MJones_RB | Engine, Exhaust, Bolt-Ons | 3 | 03-31-2021 03:07 AM |
Car stalling when a/c is on | FRS13_ | Engine, Exhaust, Transmission | 12 | 06-03-2019 11:44 AM |
Second time crank seal leak possible crank walk | kiichiro | Engine, Exhaust, Transmission | 13 | 09-19-2018 05:57 AM |
Not stalling? | grgonium | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 11-17-2012 10:26 AM |
