Old 08-23-2012, 05:14 AM   #29
Sutty
Sutty's Avatar
Drives: Sonic Blue 86 GTS 6AT
Originally Posted by WTF View Post
Hey guys,
Just finished up making Australian License plate holder prototypes, and was curious to know about the license plate mounting for people in other countries. Does anyone have a diagram or can help me with the locating holes for the numberplate mounts?
Here is how we mounted the AU plates:
Also I have noticed that someone said USA doesn't need license plates on the front at all? is this a state by state rule? As such, how do they mount the factory plate holder for your guys? Over here its two giant gaping rectangular holes on each side of the bar, where they slide a spring clamp that has a nut on the back. One for each side of the plate mount.
Anyways, any help would be appreciated, as I don't have access to USA plates and I am unsure if our design would be applicable for anywhere aside from Australia.
Based on how we did ours, maybe you can advise if this is possible or not on USA plates?
What's the cost of these going to be, how long until you go into production and what plate size are you looking at? Tks
Sutty is offline   Reply With Quote
Old 08-23-2012, 05:34 AM   #30
WTF
WTF's Avatar
Drives: FT86, BMW 5, JZA80, Porsche 986S
just waiting on the threaded lugs for the backing as they had to be imported.
Will be $40-$55..
If someone can tell me the spacing for the USA plate holes, we can have those holes added to the template, as the Australian holes are 210mm apart.
The only thing is, if your dealer hasnt added the factory plate mount, then there may not be any locators for this to bolt into.
This uses the two top holes in the stock mount to locate it. In Australia, the front bars have two large rectangles and a hole next to each rectangle. They slide a spring clip with a lug nut on the back of it into the rectangle, and the nut lines up with a 7mm hole in the bar. One on each side, for the plate mount. If that makes sense.
Looking at pics of the FR-S the mounts look the same, but since I dont have USA plate I cant double check it will be compatible.
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
WTF is offline   Reply With Quote
Old 08-23-2012, 05:53 AM   #31
Sutty
Sutty's Avatar
Will be $40-$55..
Yeah I'm in Aus so was just wanting to make sure it was going to fit Qld plates.
Old 08-23-2012, 06:54 AM   #32
fistpoint
Drives: Supercharged Golf Cart
In the U.S., we shoot people that drill holes in our front bumpers...
fistpoint is offline   Reply With Quote
Old 08-23-2012, 07:25 AM   #33
WTF
WTF's Avatar
Sure does, and tested
I am in QLD
DIY: Center Mounting the Front License Plate WITHOUT DRILLING Neurytic DIY (Do-It-Yourself) Guides 28 05-14-2018 05:37 PM
Slimline Plates Plate Bracket eleu2166 AUSTRALIA 40 07-25-2012 11:45 PM
BRZ Front License Plate Custom Mount sure74 Cosmetic Modification (Interior/Exterior/Lighting) 14 06-29-2012 10:17 PM
License plate mounting ideas? csaba Scion FR-S / Toyota 86 GT86 General Forum 1 04-15-2012 09:58 PM
