Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 10-11-2022, 11:04 PM   #29
Pat
Pat's Avatar
Drives: 2023 BRZ
Is it the oil temp or something else? Who knows.
Aww c'mon. Can someone please just answer this correctly? I'm lookin' at you, Data Mike.
Old 10-12-2022, 12:20 AM   #30
DarkSunrise
DarkSunrise's Avatar
Rear world example.
2nd gen pulls on a S2k on a roll race. 8 roll races later, the 2nd gen is now losing to the s2k.
Alternatively, many back to back pulls of a 2nd gen on a dyno reveals a consistent drop in output.
Haha do you actually know the answer? Assuming AP2? I should have a chance to test this out in a few months, should be interesting!
2022 BRZ Build
2013 FR-S Build
Old 11-25-2022, 08:20 PM   #31
Jianlun
Drives: GR86 RC
Different part number to the one for 1st gen.
https://jacksonracing.com/product/fr...toroil-cooler/
2nd gen. 5101-12-J01
1st gen. 5101-07-J02
Wonder if the routing is slighting less awkward and "kinky".
Would it be better to remove the stock 2022 water to oil heat exchanger that is now sitting under the JR sandwich plate? Since the water to oil heat exchanger at the dual rad would be so much more effective than the stock one, no seanse having the oil suffer TWO pressure drops going thru TWO heat exchangers? Wonder what the oil temeratures are of having TWO heat exchangers vs just the JR dual rad set up alone.
Yes i understand leaving the stock heat exchanger installed will help with cold start warm ups but i more concerned with pressure loss and cavitation at high rpms. Removing the stock heat exchanger will relief some of that overall restriction the oil sees.
Maybe experts can chip in?
Jianlun is offline   Reply With Quote
Old 11-28-2022, 04:35 PM   #32
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I don't think the Jackson Racing combo rad/oil cooler is very good at heating the oil up which the stock heat exchanger is quite good at.
I'd rather have fewer failure points, but I think keeping the stock heat exchanger is pretty important for a street driven car in a cooler climate. I couldn't get my oil temps up where they belong on the street if it was under ~45-50 F on my first gen even with a thermostatic sandwich plate.
Old 11-29-2022, 09:11 AM   #33
BioRebel
Drives: Mini Cooper S
Does it replace the stock oil conditioner? I don't think I saw him remove it in that video.
I know their (Jackson Racing) standalone oil cooler is one of the few that doesn't replace it which is why its the one I'm probably going to get.
BioRebel is offline   Reply With Quote
Old 11-29-2022, 09:47 AM   #34
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Savage Geese complained of the same issue, and ultimately had to disconnect his oil cooler during winter months...
LRNAD90 is offline   Reply With Quote
Old 11-29-2022, 10:07 AM   #35
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
It does not replace the stock heat exchanger. The post I was replying to suggested maybe removing the stock heat exchanger would be good though, but I disagree.
The Jackson Racing oil cooler/radiator has the oil cooler built into the radiator... 36F this morning and my thermostat was *just* cracking open 10 minutes into my drive and that's when the oil would finally start being heated. Not really acceptable for winter months, IMO
The Following User Says Thank You to DocWalt For This Useful Post:
BioRebel (11-29-2022)
Old 11-29-2022, 01:36 PM   #36
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
It does get the oil temp up to operating temperature pretty quickly on the 1st gen without a OE heat exchanger as well.
JDMChris is offline   Reply With Quote
Old 11-29-2022, 01:53 PM   #37
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Why? Instead of just covering it with something.
Arthur-A is offline   Reply With Quote
Old 11-29-2022, 02:19 PM   #38
The DROC is pretty quick with getting oil up to temp.
In my experience (22+ specific) with both the JR and GReddy units, you'll get to a full equilibrium 170F+ post-cooler oil temps with an ambient of 25-50F in about 10-15 minutes of gentle driving. Yeah, California desert gets decently cool!
Old 11-29-2022, 05:50 PM   #39
Pat
Pat's Avatar
Drives: 2023 BRZ
When my 2023 BRZ finally show up I can put the JR oil cooler on it. But knowing I often drive in 0*F with my car during ski season, should I cover the heat exchanger somehow in the winter? IIRC, the DROC comes with blue corrugated plastic. Would that be a good thing to do?
I'm imagining pulling out of the parking lot and right on to the interstate after the car sits in 0* for several hours.
Old 11-29-2022, 07:21 PM   #40
Jianlun
Drives: GR86 RC
Thank you. I thinking of getting the DROC and removing the stock heat exchanger to (hopefully) let the oil see similiar-to-stock resistances (thus lower press drop and possibility of cavitation). Since schematically DROC and the stock heat exchanger are doing the exact same thing. What are your thoughts about this? Do you have experienece on whether the stock heat exchanger even moves the needle with the DROC installed or is rendered effectively insignificant in terms of adding more cooling.
I live in a tropical area.
With the stock heat exchanger removed, i assume its a simple blanking off of the water lines to/from it?
Old 11-29-2022, 07:40 PM   #41
I recommend you run a dedicated cooler for your region.
Old 11-30-2022, 11:55 AM   #42
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Interesting info about the JR combo cooler, surprised you get enough heating since the thermostat is barely open and the radiator core is cool to the touch.
2022+ oil coolers CSG Mike GR86 General Topics (2nd Gen 2022+ Toyota 86) 17 05-15-2023 04:29 PM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-13-2022 12:44 AM
2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku BRZ Second-Gen (2022+) — General Topics 20 02-10-2022 12:44 PM
Oil Coolers AldoRaine Forced Induction 4 05-31-2020 02:10 PM
Oil coolers Matey Forced Induction 37 03-13-2015 09:21 AM
