#29 |
Drives: 2017 Toyota 86 (Raven)
#30 | |
#31 | |
#32 |
also do you think buying oem rear shock mounts be worth it when buying the RCE ss1? Racecomp is charging an extra $200 for them and I plan installing the coils myself. Spoke to a mechanic and informed him I’ll be installing them solo and advised I should but I’m not sure what would make the difference if I purchased w/o the shock mounts.
#33 | |
Drives: '23 BRZ
You might talk to someone at RCE and see how strongly they recommend the rear mounts, but IMO if their shocks have as much bump travel as stock, you should be OK with the stock mounts. |
| The Following User Says Thank You to ZDan For This Useful Post: | blakkoutdarko (01-08-2022) |
#34 | |
Drives: Crapcan
No. You only need those if you are running spacers.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blakkoutdarko (01-09-2022) |
#35 |
I know I was asking a sub question to my initial question haha I know dropping the car gives it a slight camber but I need someone who’s running same specs or at least close to mine to give me the exact spacer size they’re using for a flush look
#36 | |
Drives: Crapcan
Suspension advice before I spend my money
I have those exact wheels for my backup set. They are pretty close to flush. You will want to run about -2 camber in the front. Going with minimal drop on the SS1’s will be around an inch lower then stock. That will put the rears at around -2.2 to -2.5 which would be okay. I’d say around -2 front and rear would be decent for street driving. If you want to dial in rear camber you will need a set of LCA’s. SPC makes an affordable set. This is a bit lower and more front camber then you would want to run on the street.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blakkoutdarko (01-10-2022) |
#37 | |
#38 | |
Drives: '23 BRZ
I'm about 35mm lower than stock with -3.2 front -2.7 rear camber (stock LCAs), zero toe all around. I see remarkably little camber wear on my winter tires. I just replaced two of them and the inside tread was only maybe 2/32 more worn down than the outer tread. Spacers is a different subject, but you don't need them either! |
| The Following User Says Thank You to ZDan For This Useful Post: | blakkoutdarko (01-10-2022) |
#39 | |
Drives: Crapcan
LCA's and spacers do different things. LCA's are not a must as stated above. You can street drive at the rear camber that you will end up with without issue.
#40 | |
#41 | |
Grey Man
Drives: 22 MT BRZ
This is a good thread!
I've settled on that tire size too. I'm partial to 17s and feel 235s are the perfect width for our twins. Thanks for all the great advice! |
| Manual vs. Electronic controller for air ride suspension. Should I spend the money? | wise345 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 02-06-2016 09:44 PM |
| time to spend some money. Help me out so i only buy once... | Basket Case | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 01-03-2015 01:10 PM |
| Please Help? Don't want to spend any more unnecessary money! | Khwang89 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 01-10-2014 11:22 PM |
| What should I spend my money on | sf86 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 11-28-2012 05:34 PM |
| Please be aware where you spend your money | KronosPerformance | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 07-28-2012 09:28 AM |
