Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-02-2021, 08:13 PM   #29
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by slimfit View Post
Hmmm, I should mention this is my first manual RWD car. Maybe it’s a trait of that?
Yeah, I was going to ask "were all your previous cars FWD/AWD?".
It might have something to do with the combination of:
- having a longer drive shaft between the transmission and the diff
- having shorter / stiffer linkage between the gear shifter and the gearbox itself
timurrrr is offline   Reply With Quote
Old 12-03-2021, 10:34 PM   #30
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Transmission is smooth, but sometimes the second does not engage. Not sure if a problem or if it is a characteristic.
Coming from a 18 BRZ.
Stonehorsw is offline   Reply With Quote
Old 12-03-2021, 10:38 PM   #31
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Is it only when cold? How cold does it get where you are?
Interceptor777 is offline   Reply With Quote
Old 12-03-2021, 10:45 PM   #32
Stonehorsw
Stonehorsw's Avatar
Happens when in normal temperature, and more when downshifting from 3rd to 2nd. I may be missing the gate (pulling too much to the left), maybe I am used to the 18 shifter and putting more force than needed.
I will do some testing this weekend and see if I can turn the issue on-off with my inputs (which I suspect is the case).
Old 12-03-2021, 10:47 PM   #33
Interceptor777
Huh, weird. I've noticed 2nd gear does need a tiny bit more force to engage compared to the other gears, but it's never refused.
Old 12-04-2021, 12:26 AM   #34
eyeballs
Drives: '22 BRZ
I thought that "thunk" felt odd at first too. This brz is my 7th or 8th RWD car, and I don't recall noticing it in other cars. My most recent one being a turbo '99 miata that I sold less then 2 mos ago, so it's not likely something that I just forgot about.
eyeballs is offline   Reply With Quote
Old 12-04-2021, 03:01 PM   #35
Fingat
Fingat's Avatar
Drives: 22 BRZ (WRB)
Quick question, has anyone noticed a thunk going into 1st from neutral? Sometimes in other gears as well. Feels like the synchros maybe. Nothing crazy just enough to notice it.
Yes there is a little thunk when its engaging. Also noticed a loud whirring noise when in low rpm and its about to bog.
Fingat is offline   Reply With Quote
Old 12-04-2021, 05:44 PM   #36
slimfit
Drives: ‘22 BRZ
Thanks, knew I wasn’t going crazy! Also, just about every manual Subaru I’ve ever driven makes a whirring noise. My WRX sounded like it was supercharged after short shifter and bushings. There’s a good amount of rawness in this car that I wasn’t expecting but glad it’s there!
slimfit is offline   Reply With Quote
Old 12-05-2021, 12:06 AM   #37
Fingat
Fingat's Avatar
Yea things are definitely louder up front than they were on the wrx. The engine startup is really loud.
Old 12-05-2021, 12:10 AM   #38
tenderization
Drives: 88 RX-7, 2022 BRZ
Am definitely noticing something "spin down" when going into 1st at a brief stop, feels like it's actually wobbling the shifter if you go too quickly/aggressively. In other cars WRX, Mazda3 it seemed like it would just prevent you from going into 1st at all in that situation for a beat rather than letting you perceive any movement in the shifter.
tenderization is offline   Reply With Quote
BRZ/FRS AZ6 Manual Trans Upgraded Gearset RockySDS Engine, Exhaust, Transmission 169 09-15-2022 08:55 PM
What Manual Trans Fluid Do You Use? McG86 CANADA 50 03-22-2020 08:19 PM
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 10:44 AM
Manual Trans 12k miles $750 OBO Amir Ghadiri Transmission and Driveline 4 05-23-2015 02:35 PM
Bump start in a manual trans? bayank BRZ First-Gen (2012+) — General Topics 11 02-16-2014 06:47 PM
