Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-16-2021, 12:19 PM   #29
LanceLane174
Drives: 2022 BRZ Limited WRB, MT
Originally Posted by Pete View Post
Will do. There was talk about an optional factory sub a while back, that's going to be my first choice if it makes an appearance any time soon.
Toyota config site just went live and they show one on theirs. So I am guessing we could get that for our cars, even if Subaru doesn't brand one themselves.
LanceLane174 is offline   Reply With Quote
The Following User Says Thank You to LanceLane174 For This Useful Post:
Pete (11-16-2021)
Old 11-16-2021, 02:45 PM   #30
s30series
Drives: 2015 BRZ Series.Blue
Originally Posted by mazeroni View Post
Where are folding mirrors practical living in the U.S.? Even the most narrow of parking spaces, I've never encountered issues.
On a Tahoe, sure. It is necessary as most people don't have garages designed for such a larger vehicle.
Do you own a new home? Most new homes built around me in the city of Atlanta have 20x20 garages. Walking between cars or sides of garage without folding mirrors is annoying.
s30series is offline   Reply With Quote
Old 11-16-2021, 02:51 PM   #31
Dylans47
Drives: Scion FR-S
There should be an optional sub coming for the BRZ soon! The configurator went live recently for the GR86 and it's a $700 option. Not sure how this would compare with the previous gen's popular oem audio brand subwoofer.
https://www.toyota.com/configurator/...022/series/86/
Dylans47 is offline   Reply With Quote
The Following User Says Thank You to Dylans47 For This Useful Post:
soundman98 (11-17-2021)
Old 11-16-2021, 03:25 PM   #32
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by LanceLane174 View Post
If you find an easy sub that works with our current amp, I would be interested to know. I'm looking for the quickest and easiest way to get some bass and be happy with the stereo. The 1st gen sucked and I'm not going to just leave it be if it sounds like that.
The stock amp definitely isn't going to push a sub.
Look at something like the OEM Audio upgrade. Not only does it replace the stock amp, but also has a dedicated sub amp.
Old 11-16-2021, 03:30 PM   #33
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
FYI, This link does not work everywhere. If you get the "Out of Stock. But not out of reach." page then change your zip code in the upper right corner to 90011.
PhatFreshPrince is offline   Reply With Quote
The Following User Says Thank You to PhatFreshPrince For This Useful Post:
Pete (11-16-2021)
Old 11-16-2021, 03:31 PM   #34
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The Kicker sub for the ZC6 BRZ used a patch harness at the headunit to function as a crossover, and the sub has a built-in amp.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Simmons (11-16-2021)
Old 11-16-2021, 05:10 PM   #35
LanceLane174
Thanks. That is very helpful info. My hope is to get the OEM sub upgrade.
Yoshoobaroo (11-16-2021)
Old 11-16-2021, 05:21 PM   #36
Yoshoobaroo
TRACKBREAD
I haven’t heard the old sub in person, but apparently the speakers benefit a lot from the crossover (makes sense). It doesn’t just pump the bass up, it clears up the mids and highs too.
Old 11-16-2021, 06:06 PM   #37
OkieSnuffBox
I watched the install video for it earlier because I was curious.
I assumed, the replacement amp still powered all 8 speakers. But if that's the case, I don't understand why they would need to put a passive crossover on the mid in the dash.
And I don't think if anyone had confirmed it before, but it looks like the higher end trim GR86 comes with the upgraded stereo like the Limited BRZ. That might swing be back that direction because of the duck tail and highlighter blue color.
Old 11-16-2021, 11:22 PM   #38
Kona61
Kona61's Avatar
Drives: ‘22 CWP
I’m assuming since they can focus on specific frequencies?
Kona61 is offline   Reply With Quote
Old 11-16-2021, 11:39 PM   #39
OkieSnuffBox
https://oemaudioplus.com/subaru/brz-2/
Old 11-17-2021, 12:11 AM   #40
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Originally Posted by OkieSnuffBox View Post
Thanks. I may have to look into getting that OEM sub. Not super picky about stereos but wouldn’t mind an improvement.
Old 11-17-2021, 01:07 AM   #41
MyHybridBurnsGasAndTires
Drives: what
maybe it will tip the scales to perfect 50:50 weight balance
MyHybridBurnsGasAndTires is offline   Reply With Quote
Old 12-09-2021, 01:25 PM   #42
JoeBRZ18
Drives: 2022 BRZ
Here is the diagram from Subaru parts, if that helps. Probably not.
https://parts.subaru.com/p/Subaru_20...6229CC010.html
All of the mounting points should be identical. Or at least, as others point out, they appear to be the same given the speaker location hasn't changed. But last gen had 8 speakers standard on all cars, so I don't think it is clear if the car is pre-wired for the amp in the trunk and the 2 speakers you lose on top of the dash. Something tells me no. Why would they spend the time and money on that? That would also incentivize owners to spend more for the upper trim. But I could be wrong.
Beyond that, I don't think we know about ports and connections.
So based on this discussion, it sounds like they have 4" in the dash + tweater, 4" in the back and 6.25" in the doors?
Outside of OEM, does anyone recommend the Alpine R, Polk Audio or the Infinity Reference?
JoeBRZ18 is offline   Reply With Quote
what color is your car ..how laid back poll Gilwith1l Scion FR-S / Toyota 86 GT86 General Forum 23 03-24-2014 01:17 AM
Just Got Laid Off Nasty Sausage Off-Topic Lounge [WARNING: NO POLITICS] 37 02-13-2014 08:02 PM
Laid off today. :( stockysnail Northwest 62 04-04-2013 11:51 AM
Just laid down my 2nd deposit m.box.design Northwest 21 07-06-2012 04:03 AM
Just laid down a deposit and... Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 49 02-08-2012 06:22 PM
