Old 07-29-2021, 03:57 PM   #29
Petah78
Drives: 2022 BRZ sport-tech
Originally Posted by ZDan View Post
Are pressures more stable, or just higher in general due to lower temp? My understanding (I haven't logged pressure so I'm going on info from others here) is that the pressure becomes unstable at high rpm due to cavitation rather than from temperature...
I know lower oil temp would equal higher oil pressure because of oil viscosity, but wouldn't the effects of cavitation be less severe because of the lower oil temp?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 07-29-2021, 04:09 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That was my initial thought but I was getting more cavitation at higher temps before.
Old 07-29-2021, 04:43 PM   #31
Petah78
Right. So lower oil temps in theory will produce higher pressure because of
1. Oil viscosity
2. Lower effect of cavitation
Though the question remains: Is low 40's PSI at redline enough for the FA20?
I agree that higher oil pressure/lower oil temps = better safety margin but I am still on the fence about adding an oil cooler. Broken oil lines leading to lost engines are not uncommon. Longer warm up times is also a concern for a street car with the potential of overcooling. For the average user that does maybe 4-5 hours of actual track driving per season, I don't know if it's worth the potential trade off.
Old 07-29-2021, 04:48 PM   #32
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
1. Oil viscosity
I'm 95k miles NA and no rod knock yet (knock on wood). Running 0-20w 300V 95% of the time with a 613 core. 7500 mile oil change interval. I did blow a spare engine that I ran for about a thousand miles from a rocker arm kicking out, but most of the miles are on my original engine.
Old 07-29-2021, 05:23 PM   #33
Icecreamtruk
Drives: Track preped NA FRS
Does the overflow tank fills up more than usual (or even shoots coolant out the top)? I had a similar setup to you and the only thing that made it overheat was the head gasket that went bad and it was pushing compression and heat into the water. Test your rad water for carbon in it, its the easiest way to tell you you are pushing stuff from the cylinders into the coolant (and hence, a bad head gastket).
Old 07-29-2021, 07:51 PM   #34
Petah78
That is 95k with an oil cooler and track abuse, right?
Old 07-29-2021, 08:12 PM   #35
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
About 60K when I started doing some autoX then track day. Probably 45K with oil cooler.
Old 07-30-2021, 07:04 PM   #36
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I'm not behind cavitation (yet).
I think obvious culprits needs to be looked at like head gasket or thermostat.
I'm racing with 6 degrees advanced over stock on 100 oct (doesn't burn as cool as E85), in a draft on a 90 degree day on an OEM radiator and temps aren't a concern.
Just pulled my data from Portland: 90 degree day, lots of time drafting, 30 minute sprint race. Never saw a water temp above 210.2F on the hottest lap. Oil peaked at 244.4 on that lap as well with center mounted greddy oil cooler. This was with 0w-40 oil.
PRO86 | STL | LuckyDog
Old 07-30-2021, 08:11 PM   #37
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am pretty sure it is thermostat at this point. I don't know how I glossed that over. Coolant has no oil in it, plugs are clean.
Old 07-30-2021, 09:52 PM   #38
jflogerzi
jflogerzi's Avatar
With all that cooling at least it's an easy fix. But it makes sense
2013 Series 10 FRS #553
Old 07-30-2021, 10:59 PM   #39
Ultramaroon
not playing cards
Ultramaroon's Avatar
I jumped right into the mod pit with you.
Old 08-01-2021, 07:56 PM   #40
Icecreamtruk
Also kind of unrelated to it but the last post by @rice_classic made me think about it. I have an LS1 under the hood now and kept a stock sized koyo rad. No fans, no shrouds, only ducted in the front (bumper to rad) and vents in the hood. Water temp is at a solid 196F all the time, regardless of outside temp so far. If pushing 3 times the power is still not enough to overload a kind of stock sized radiator, I really doubt any kind of NA power can actually push too much heat into it unless something is wrong (water pump, thermostat stuck closed or head gasket).
Old 08-01-2021, 11:55 PM   #41
Ultramaroon
not playing cards
Stock radiator is amazingly effective. Cooling system design and layout are top notch.
Old 08-02-2021, 11:26 AM   #42
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, my monkey brain was stuck in "what else" mode and not "what if" mode. I know boosted guys running stock cooling setups with no issues so it kind of left me going WTF and figured I would ask the hive mind. Took the car out for a drive. Still no oil in the coolant or vise versa. On the street water temps sit in the 160's even on a 90F ambient day as long as I am moving. Pretty sure now the thermostat is not opening up all the way when hot. It should be here this week.
Engine Management Q2 Forced Induction 9 12-04-2017 05:37 PM
heat management, CF hood alternative Reaper Forced Induction 70 07-05-2017 01:22 AM
Rotrex vs Turbo (AVO) for Track use (transient response, IATs, heat management, etc) glamcem Forced Induction 56 08-25-2014 06:07 PM
Top half car covers for cabin heat management on track dp1 Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2014 11:08 AM
Avo turbo heat management on track ICantAffordAnLFA Forced Induction 18 09-09-2013 11:00 AM
