Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 07-27-2021, 08:24 AM   #29
racingfool
racingfool's Avatar
Drives: Miata
Originally Posted by Boccaccio View Post
"In WOT dyno testing, likely the rings are seated by the end of the first few runs"
about 80% of the ring sealing takes place in the first hour of running the engine,
The loss in power from an easy break-in and the resulting poor ring seal can be anywhere from 2% - 10% !!
http://www.mototuneusa.com/break_in_secrets.htm
racingfool is offline   Reply With Quote
Old 07-27-2021, 10:55 AM   #30
Originally Posted by racingfool View Post
That site is annoying enough in it's format and get's worse as he gives his "expert" opinion. Anecdotal experts are the worst of all. "I tried it and it was good on my custom built superbike engine so it is good for everything".
I will listen to the people that designed and built the engine thank you very much.
Old 07-27-2021, 10:59 AM   #31
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Is there an official recommendation from Subaru on break-in? I never dug through the manual to find out since I bought mine used.
Old 07-27-2021, 10:59 AM   #32
Yes
Old 07-27-2021, 12:28 PM   #33
Sasquachulator
Pavement Grey
I actually looked in my manual the other day looking for this info.
In the Canadian spec model it says 1600km of easy driving and the usual gibberish of dont exceed 80km/h for extended periods of time, dont go over 4k rpm, etc. I think all cars say the same thing, except the total kms would probably the only value that varies per car.
Old 07-27-2021, 12:30 PM   #34
Yoshoobaroo
TRACKBREAD
Sounds like pretty antiquated CYA verbiage considering all engines are dyno’d at the factory these days. If anything I would take it easy on the transmission and diff for the first few thousand rather than the engine.
Old 07-27-2021, 12:49 PM   #35
They are dynoed for 10 seconds (if at all) so not exactly a break in.
What are they covering their ass for? Early failure? They don't care what happens when it is out of warranty so if the break in is "not needed" then why is a CYA for early failure situation?
No doubt all the usual bunk of "Oh it doesn't matter and this way is far better because it worked on my rebuilt bike engine" is going to get thrown around as usually when this subject comes up but I guess it is the same bunch of people that think the designers knew nothing anyway.
Everybody just do as you please.
Then we will hear all the whining from the same group that the engines are no good because they leak or burn oil or anything else that can't possibly be because they knew better than the people that built it!
OUT.
Old 07-27-2021, 01:18 PM   #36
racingfool
racingfool's Avatar
Drives: Miata
Don't hold back, tell us how you really feel.
Old 07-27-2021, 01:58 PM   #37
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by RZNT4R View Post
My favorite is Ford's oil pressure gauges where the needle only actually has two positions: low and middle.
It's all a sham. I'm too simple to ever buy into that kind of crap. I'd quit before agreeing to design a deceptive device.
Old 07-27-2021, 01:58 PM   #38
ayau
Drives: Some rust bucket
it's just general 'break-in' procedures that every user manual has. it's not specific to engine break-in. whether or not the engine actually needs a break-in, only the engine designers can tell you that.
like anything, products are designed for the lowest common denominator, e.g., doesn't read owners manual or know anything about cars. just drive the car as you wish.
Old 07-27-2021, 02:37 PM   #39
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Just no
Old 07-27-2021, 06:17 PM   #40
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Hey it's true that it takes combustion pressure to press the rings into the cylinder wall.
That's why I spent my first tank/night with my 86 doing 1-2-3 gear firm (not wot) pulls to high RPMS (not red line, shift ligfht set just past 6k) and engine braking 3-2-1 back down.
And doing it again
And doing it again
And if I was on a road that didn't allow it I was running up and down 3-4-5 and back down constantly. Combustion pressure to seat the rings, engine braking to pull some oil through the rings, lubricate and cool them down, more pressure to seat them, more cool down, etc. Not wot, just firm. and over a few hours, not over 5 minutes on a dyno.
A race engine might be happy being born like this
But that's a bit... stout... for a street car.
Old 07-27-2021, 09:21 PM   #41
soundman98
ProCrastinationConsultant
soundman98's Avatar
i run diesel fuel through the car every other tank.
helps with seating the rings, and no problems yet!
Old 07-27-2021, 09:33 PM   #42
Decep
Drives: 2013 FR-S Series 10
You were hoping for a useful feature? I'm sorry. That's not how modern regular cars are made. They figured out that most people don't know what to do with useful features so they make butt warmers and touch screens instead.
Hopefully I can control my butt warmer with the touchscreen? I love fumbling for buttons that have no feel whatsoever while I’m driving.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
"Unable to read program. Please check SD card or the program" coconutboy Electronics | Audio | NAV | Infotainment 1 08-13-2019 06:23 PM
2013 production date cars more "reliable?" jacobzking Issues | Warranty | Recalls / TSB 64 09-30-2013 10:17 AM
What Subaru of America says about the "break-in period"... mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 21 08-07-2013 10:17 PM
The "First 86 Program" Should be revised!!! Jay Grey Scion FR-S / Toyota 86 GT86 General Forum 36 05-16-2012 11:22 AM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
