Old 04-01-2021, 04:49 PM   #29
Transport3r
Drives: -
Tpyota 86 AT 2013 oil consumption, pls help
Originally Posted by Dzmitry View Post
Just to add to this, to be more clear, 0w-30 and 0w-20 do not have the same cold start protection. 0w-30 may have a higher viscosity index (but not always, you can search up various oils and their viscosity indexes to get an idea), but it will still have a higher viscosity at most of the temperatures we witness.
EDIT: quick example - see link below on last page. Notice that even a 5w-20 still has better cold start protection than a 0w-30. The number on the right tends to hold fairly true for how oil behaves at hot temperatures, but the number on the left is more of a general guide for what the oil is trying to shoot for so to speak. Further apart, such as 0w-40, means the oil will typically have a better index, which is a good thing.
https://amsoilcontent.com/ams/lit/da...tins/g2880.pdf
Fair enough, thanks for that. Still, better cold start protection than a comparable 5w30.
Transport3r is offline   Reply With Quote
The Following User Says Thank You to Transport3r For This Useful Post:
Dzmitry (04-01-2021)
Old 04-01-2021, 08:18 PM   #30
86TOYO2k17
Drives: 2017 toyota 86
Agreed on most points. One thing I would say though, is a DD is constantly seeing temps above 210F, and probably far more often than 180F. I have never seen my car settle or stay at 180F even for a short period of time. I live in Pennsylvania where climate varies from freezing to 100F on a nasty summer day. I am mostly DD and during the winters my temp holds around 210F once warmed up fully. During the summers, I am seeing 210-220F if I'm babying the car around, and almost always around 230F+ if I am riding highway or pushing it around a bit. In which case, to back up my statement, you said yourself that 5w-30 can become advantageous at 220F+, which I agree with.
I would also FAR rather go with 5w-30 oil rather than spend the money on an oil cooler and deal with the contrary issues of trying to get the oil up to temp (especially in the winter) and any other minor issues that can go along with one, such as leaks from mistakes, etc.
You’re temps are far higher than mine. I have a oil temp gauge front and center monitoring temps entire time. And run a lot cooler than that even beating the balls out of her.
Old 04-04-2021, 11:06 PM   #31
pro_turbo
Drives:
Originally Posted by RToyo86 View Post
Non American user manuals had 5w30 mentioned as an option. I recall the Japanese manual even mentioning something up to the effect of a 5w40 under heavy load conditions (racing)
https://www.ft86club.com/forums/showthread.php?t=105134
Edit: post 3
https://www.ft86club.com/forums/showthread.php?t=131389
Hey thanks again
I am swapping to 0w20 last saturday. Car seems very light and engine is not fluttering at idle.
I will try to drive the car everyday to see that i still have a leak or not.
Yeah i might be changing again over 5w30 once the supercharger installed.
I have several option here..
Ams signature 5w30
Motys m100 5w30
I would prefer ams.. what you guys thinking
pro_turbo is offline   Reply With Quote
Old 04-04-2021, 11:08 PM   #32
pro_turbo
Drives:
I will install the oil temp sensor and connected to motec
Actually i made another thread about what sensor shpuld i add.
Please have a look
https://www.ft86club.com/forums/showthread.php?t=144803
Old 04-05-2021, 08:20 AM   #33
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
That may very well be the case, and I am not sure why. But from what I've read on this forum, my temps are nothing out of the ordinary. But of course, you make the judgement based on your conditions as yours definitely vary from mine.
Dzmitry is offline   Reply With Quote
Old 04-05-2021, 08:28 AM   #34
Dzmitry
Dzmitry's Avatar
Originally Posted by pro_turbo View Post
Hey thanks again
Ams signature 5w30
Motys m100 5w30
Oil brands have also been discussed repeatedly on this forum. The general consensus is you choose whatever oil brand you like and stay away from any unknown or cheap brands you may be weary of (none that I really know). People have been using just about every kind of oil brand on this car and have loved their own choice.
If you're leaning on those two only, I would say make your judgement based on whatever is cheaper for you. Also as someone else mentioned earlier, it would be nice to check that it is GF-6 vs GF-5 as it has reduced wear and other various benefits if you're looking for the best.
As for gauges, oil pressure would be one of the most beneficial I would say if you're interested in knowing how it various based on your driving style and temperatures. The rest are not necessary and can be viewed through free apps that are out there or something like EcuTek.
Old 04-09-2021, 04:20 PM   #35
pro_turbo
Drives:
Hey im back.. i found the leak.. it was from rear crank seal..
I have to fix it.
And i already fill it with 0w20
It sounds prettier.. and quiter on my engine
Especially when cold
I wil go wwith my eneos 0w20 up untill supercharger.
I am gonna install oil temp and oil press so i can compard Nd share to you guys here when im done with pw20 and later with 5w30
For your info too.. i have oil cooler installed.
So it might not the same with you guys.
The Following User Says Thank You to pro_turbo For This Useful Post:
DarkPira7e (04-09-2021)
Old 04-09-2021, 08:09 PM   #36
86TOYO2k17
I had NA FBO w/ no cooler
NA FBO w/ “oem/ned” cooler
Supercharged w/ “oem/ned” cooler
Supercharged w/ “oem/ned” cooler + oil cooler
Supercharged w/ “oem/ned” cooler + oil cooler + oil cooler fans.
I chose 0w-20 for all variations.
Supercharging doesn’t change engine tolerances. Doesn’t change oil requirements.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
pro_turbo (08-24-2021)
Old 04-13-2021, 02:40 PM   #37
pro_turbo
Drives:
agree i will stay on 20
Old 06-02-2021, 05:33 AM   #38
AleksShamles
AleksShamles's Avatar
Drives: Just a student
Good
AleksShamles is offline   Reply With Quote
2013 BRZ oil consumption Project N64 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 32 01-16-2020 06:56 PM
Oil Consumption? smbstyle Tracking / Autocross / HPDE / Drifting 42 10-08-2019 05:50 PM
Oil consumption? Please chime in OnTheFence Issues | Warranty | Recalls / TSB 48 10-01-2019 09:42 PM
E-85 consumption Lunatic Tracking / Autocross / HPDE / Drifting 16 01-28-2016 09:15 PM
86 / BRZ Oil Consumption ZZT86 AUSTRALIA 1 04-29-2013 09:53 PM
