Old 11-18-2020, 06:05 PM   #29
Ashikabi
Ashikabi's Avatar
Originally Posted by PulsarBeeerz View Post
Its 13.5:1..
Seriously? And they only added 25hp with a 20% increase in displacement?
Old 11-18-2020, 06:15 PM   #30
PulsarBeeerz
Drives: JRSC BRZ SOLD
Current and future emissions/mpg regs. The ND2 miata is only getting 185hp from 2.0l and 13.0:1 comp.
PulsarBeeerz is offline   Reply With Quote
Old 11-18-2020, 06:18 PM   #31
Ashikabi
Ashikabi's Avatar
I guess it is pretty close to 100hp per liter so yeah I shouldn't have expected more. At least e85 will be crazy on it
Old 11-18-2020, 07:02 PM   #32
yep. It is one of the specs on the actual Subaru press release.
Old 11-18-2020, 07:33 PM   #33
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by RToyo86 View Post
Considering 17+ engines are a Easy to swap into older cars I don't see it being simple to swap a FA24 into older cars.
It might get easier via kits if it has enough interest.
FIFY. Next to swapping any other engine in this car, this is cake.
The Following 3 Users Say Thank You to Kiske For This Useful Post:
Hades (11-19-2020), Irace86.2.0 (11-19-2020), soundman98 (11-19-2020)
Old 11-19-2020, 12:40 AM   #34
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
20% peak horsepower you mean.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
DarkPira7e (11-19-2020)
Old 11-19-2020, 07:07 AM   #35
Yes compared to doing other engines it is easy. It is still not a drop in plug and play by any stretch though.
So if the "minor" differences between a 2016 and 2017 engine swap are not plug and play then trying to swap one from an even greater changed platform is going to be even more difficult. People will think because the car has the same badge it should just drop in and away they go. This will not happen.
RToyo86 (11-19-2020), soundman98 (11-20-2020)
Old 11-19-2020, 09:27 AM   #36
alex87f
Meow
alex87f's Avatar
Drives: Focus ST mk4
Looking back at when the 86 was released, everybody thought the WRX FA20DIT would be to go-to performance swap for our cars. Seven years later, and -AFAIK- nobody's got it to work properly.
These FA24s might very well be the same story. Can it be done? Of course. Does it make any sense vs. a low-boost supercharger kit that's known to work? Probably not.
That's also a byproduct of running DI. You can crank up the compression ratio (and thus efficiency) without concern for knock, even if you're not looking for maxxxx hp.
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
Tcoat (11-19-2020)
Old 11-19-2020, 10:22 AM   #37
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Would make no much sense, would be better selling the car and starting with an uodated platform (including chassis).
I would say that the FA24 from accent would make more sense.
Stonehorsw is offline   Reply With Quote
Old 11-19-2020, 11:31 AM   #38
All low end torque designed for low revs and a CVT tranny. For all intents and purposes a truck engine designed for heavy vehicles. The paper HP and torque numbers look nice but in a sports car application that version of the engine would suck balls.
Old 11-19-2020, 11:37 AM   #39
Tomm
Identifying as a Member
Tomm's Avatar
Drives: 2013 FRS LS1
lol @ truck engine. I'd still like to see it.
Me with low end tq:
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline
Tomm is offline   Reply With Quote
Old 11-19-2020, 11:40 AM   #40
Ashikabi
Ashikabi's Avatar
All torque you say?
Old 11-19-2020, 11:56 AM   #41
Me with low end tq:
If anybody was going to do this swap (if it is even feasible as Alex pointed out above) then they would be better off to wait and see what they do to this engine series for the WRX/STI.
Wouldn't change the issues of the swap but may at least be worth doing.
Old 11-19-2020, 11:56 AM   #42
Irace86.2.0
People have done the FA20F swap, but it is an inferior engine, so there is no reason to swap the motor. It has lower compression, so it can take more boost on pump gas, but it takes more boost to make power. The rods are only slightly stronger, but generally, 350hp is around the max target. The turbo system is mounted under the engine, so there is likely some type of interference issues unless the engine is mounted higher. It might require an aftermarket turbo system anyways. Then the starter is on the opposite side of the engine, so I think some custom work would need to be done to mount the transmission. It makes more sense to just install an aftermarket turbo system, so this is why swaps aren't common.
For the FA24, there is more low end torque, there will be more power potential, it likely has stronger internals for more reliability at a given horsepower or a higher power potential, it will spool a turbo faster, etc. The cost of a swap could be cheaper than building a piston/rods motor FA20, and it might have an improved power curve.
If the motor has the same dimensions, but is just bored out larger, or rather, it has larger sleeves then the block might possibly be matted to the FA20's heads with some minimal head work to open the chambers. We don't know yet.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
Hades (11-19-2020), RuyGuy2 (04-30-2022)
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
