#29 |
#30 |
Drives: JRSC BRZ SOLD
#31 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#32 |
yep. It is one of the specs on the actual Subaru press release.
#33 | |
Drives: RX-7 / BRZ
FIFY. Next to swapping any other engine in this car, this is cake.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged Last edited by Kiske; 11-18-2020 at 08:05 PM. |
| The Following 3 Users Say Thank You to Kiske For This Useful Post: |
#34 |
Drives: Q5 + BRZ + M796
20% peak horsepower you mean.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | DarkPira7e (11-19-2020) |
#35 | |
So if the "minor" differences between a 2016 and 2017 engine swap are not plug and play then trying to swap one from an even greater changed platform is going to be even more difficult. People will think because the car has the same badge it should just drop in and away they go. This will not happen.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | RToyo86 (11-19-2020), soundman98 (11-20-2020) |
#36 |
Meow
Drives: Focus ST mk4
Looking back at when the 86 was released, everybody thought the WRX FA20DIT would be to go-to performance swap for our cars. Seven years later, and -AFAIK- nobody's got it to work properly.
These FA24s might very well be the same story. Can it be done? Of course. Does it make any sense vs. a low-boost supercharger kit that's known to work? Probably not. That's also a byproduct of running DI. You can crank up the compression ratio (and thus efficiency) without concern for knock, even if you're not looking for maxxxx hp. |
| The Following User Says Thank You to alex87f For This Useful Post: | Tcoat (11-19-2020) |
#37 |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Would make no much sense, would be better selling the car and starting with an uodated platform (including chassis).
I would say that the FA24 from accent would make more sense. |
#38 |
All low end torque designed for low revs and a CVT tranny. For all intents and purposes a truck engine designed for heavy vehicles. The paper HP and torque numbers look nice but in a sports car application that version of the engine would suck balls.
#39 | |
Identifying as a Member
Drives: 2013 FRS LS1
Me with low end tq:
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline |
#40 | |
![]() ![]() ![]() Sent from my ONEPLUS A5010 using Tapatalk |
#41 |
If anybody was going to do this swap (if it is even feasible as Alex pointed out above) then they would be better off to wait and see what they do to this engine series for the WRX/STI.
Wouldn't change the issues of the swap but may at least be worth doing.
#42 | |
People have done the FA20F swap, but it is an inferior engine, so there is no reason to swap the motor. It has lower compression, so it can take more boost on pump gas, but it takes more boost to make power. The rods are only slightly stronger, but generally, 350hp is around the max target. The turbo system is mounted under the engine, so there is likely some type of interference issues unless the engine is mounted higher. It might require an aftermarket turbo system anyways. Then the starter is on the opposite side of the engine, so I think some custom work would need to be done to mount the transmission. It makes more sense to just install an aftermarket turbo system, so this is why swaps aren't common. For the FA24, there is more low end torque, there will be more power potential, it likely has stronger internals for more reliability at a given horsepower or a higher power potential, it will spool a turbo faster, etc. The cost of a swap could be cheaper than building a piston/rods motor FA20, and it might have an improved power curve. If the motor has the same dimensions, but is just bored out larger, or rather, it has larger sleeves then the block might possibly be matted to the FA20's heads with some minimal head work to open the chambers. We don't know yet.
| FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
| 2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
| FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
| Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
