| Engine Swaps Discussion of engine swaps. |
Drives: 2014 Subaru BRZ Sterling Silver
Second Gen Swap? FA24
Hello all,
So the second gen was officially unveiled this morning. The first thing I thought of was engine swap.. I dont want to buy a new gen 86. There is just no need. However.. I have a full bolt on, e85 NA build. So just a tad over 200whp. Imagine the same on the FA24 which is estimated 228 crank hp ~191hp at the wheels. So.. how likely, how possible would it be for a FA24 swap. Will there be a need for a MOTEC? What are yall's thoughts on it? |
#2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#3 |
Drives: 2013 Subaru BRZ
I'm mostly excited/curious about the possibility of a hybrid swap like the EJ guys would do back in the day (2.5 block on 2.0 heads)
#4 | |
#5 |
Drives: 22 BRZ limited
I think it would all depend on sensors used. If both engines have the same sensors it should be close to a direct swap. Especially if you can swap sensors over. We'll have to wait almost a year to see, really.
#6 |
Drives: 17 Asphalt 86
Considering 17+ engines are a PITA to swap into older cars I don't see it being simple to swap a FA24 into older cars.
It might get easier via kits if it has enough interest. |
#7 |
Panda Trueno
Drives: No twin now.
They also stated the engine is mounted lower. So, is that just new mounts or is there more to it? It might have physical issues as well as electrical / wiring ones.
At this point... WTF KNOWS!?!?! |
#8 | |
#9 |
Identifying as a Member
Drives: 2013 FRS LS1
While the gearhead in me says that swap would be sweet and probably not very complex. The practical side is questioning if the juice is worth the squeeze.
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline |
#10 | |
#11 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Long as I can drop the 2.4 into my '13 FR-S.
Once I get the valve springs changed and gum spit into the oil passages I don't have much hope for the original engine.
"I gotta rock." -- Charley Brown |
#12 |
#13 |
I could definitely see the 2.4L displacement being very responsive to boost. Yea the more I dig into the LS swap, the less I want it - but the cool factor is thru the roof.
#14 |
Only happy when it rains.
Drives: series.blue
Heck i'd be willing to switch out everything, that new interior looks awesome. Engine, wiring harness, ecu, steering wheel etc all into the old car. I highly doubt it would be "worth it," but it might be fun.
| FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
| 2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
| FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
| Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
