Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
10-29-2020, 12:18 PM | #29 | |
Drives: '23 BRZ
What's keeping you from getting 225 (or 215) RE71R, A052, RT660, etc? That would make a bigger difference in grip and handling feel than 225 vs. 215 PS4S...
I really doubt there's a whole lot in it, either 225 or 215 will work on 7.5" wheel, personally I'd go 225 just based on 215s looking puny on 17x7.5"... Quote:
10-29-2020, 12:27 PM | #30 | |
Drives: 2019 BRZ PP
Sent from my SM-N960U using Tapatalk |
10-29-2020, 12:44 PM | #31 | |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Either buy nicer rims for daily and use stockers for autox. Or buy used wheels for auto x to save money for the tires. |
10-29-2020, 12:57 PM | #32 |
Drives: '13 Whiteout
With mostly street driving you need to be careful with too much negative camber as while great for track and AC it tends to wear the tires unevenly. If you just use camber bolts instead of plates you won't be able to get enough to be harmful.
10-29-2020, 01:03 PM | #33 |
Drives: Crapcan
As long as you keep on top of your tires pressures it is not that big of an issue. I have been running between -3 to -3.4 in the front for years with fairly even wear. The rears at around -2.2 to -2.4 wear very evenly. I do rotate every oil change. I have been street driving my car an average of around 15K miles a year since I have owned it.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | TommyW (10-29-2020) |
10-29-2020, 01:07 PM | #34 | |
Drives: 2019 BRZ PP
10-29-2020, 01:11 PM | #35 |
Drives: Crapcan
Usually try to keep them 34-36 cold. I can get some pretty big temp differences in a short amount of time. Starting last week my TPMS light started coming on in the mornings but would be off in the day. So I tend to set them a bit higher in the winter. If I run them low it eats the insides quickly, I did that once
10-29-2020, 01:18 PM | #36 |
Drives: '23 BRZ
RE71R, A052, RT660, these are street tires, you can daily on them. I have dailied on such tires through track season for years. Also on some "R comp" tires like NT01. Honestly I wouldn't bother with PS4S
10-29-2020, 01:52 PM | #37 | |
Drives: '23 BRZ
I've just run my cars with 3-4 front and 2-3 rear camber all year and not worried about it. This kind of camber, with modest near-zero toe, might reduce tire life on the street by ~15%. If you track any at all it will even the wear out a lot. Toe is the real tire-destroyer... |
10-29-2020, 02:20 PM | #38 |
Drives: 2014 GT86
I would disagree. Good non-tracked tires for many last for eg. 3 seasons. Five+ trackdays can wear down set. So if tire set due tracking might not last even whole summer, who cares if daily driven at that time that set may see uneven extra 5% wear vs wear you see on track? Despite incomparably longer DD mileage, sedate driving wears little, even on not optimal for such driving alignment. Also people may care for most speed/grip on track with all that competitiveness, and easily give up/compromise during "normal driving". And then there is extra hassle and spending on doing several alignments .. i'm not surprised seeing many driving their dual-used cars on track-oriented alignment just fine on street. I myself switch between alignments .. but only in autumn and spring, it's more for me summer+track vs winter snow/ice alignments, not track vs street.
02-09-2021, 01:13 PM | #39 |
Drives: 2017 BRZ PP, 2004 WRX
I'll put my 2 cents in.
225/45/17 on a 17x7.5 wheel is going to be completely square for most 225's. If you've seen the stock Michelin in 215 off the wheel, you'll see the sidewall is flat. When it's on the wheel, it's stretched on the wheel. For whatever reason, Subaru or Toyota decided they wanted stretched tires, possibly for less grip, like how they explained they went with the Primacy HP as the tire choice. No, it's not "too big" and you won't feel any real change in feedback, given you use the same tire in comparison. Anyone claiming 215's are crisper are probably comparing a stiffer sidewall tire to a less still 225. Now, if you pinched a 245 on a 7.5", yes you will give up some responsiveness and even have some rollover that might not be great for the track/autocross... but, at least for autocross, nearly 10/10 times the wider tire is faster. Track times might be different based on feedback and how hard you push. 225 is a no brainer on a 7.5" wheel with a +48 offset on these cars. I'd even say 225 is a great on the 7 inch non-PP wheels too. |
02-12-2021, 02:13 PM | #40 |
[jay-kuh-meh-low]
Drives: 2016 FRS RS2.0 #293
I just upgraded from my stock Turanza EL400 215/45/17 (trash tire) to a Pilot Sport AS4 225/45/17. I wanted to get the Pilot Sports in 215, but 225 was as close as I could get with the sizing they have available right now.
Honestly, I think the 225 looks better. That extra 10mm filled out the wheel wells more, which is essential if you want 17s to look good. I’m not sensitive enough to notice a handling difference between 215 and 225, and I doubt 95% of this forum is either. I kept the stock wheels btw. TRD 17x7.5 +43.
IG: @appamatic
02-12-2021, 08:08 PM | #41 | |
Drives: 2014 FR-S Monogram
02-12-2021, 09:06 PM | #42 |
Drives: 2014 GT86
Common reason to decide on 225/45 might be for it often being more common and thus cheaper sizing then 215/45, grip/width/handling aside.
Similar Threads | ||||
Performance package wheel/tire weight vs. regular wheel/tire combo | qqzj | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-26-2019 01:27 AM |
Wheel Directory: MIM TecnoMagnesio Sao Paulo 7,5X17 +35 | Daria | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 04-14-2015 03:13 PM |
General wheel questions (Yes I have read the sticky's) | milleniacinder | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 07-13-2014 04:53 PM |
Steering wheel/dashboard getting sticky in the heat. | daftpunk | Issues | Warranty | Recalls / TSB | 15 | 06-26-2014 05:58 PM |
WTB: One FR-S OEM 17'' Wheel (don't need tire) | brillo | Wheels and Tires | 1 | 09-17-2013 09:32 PM |
