Old 01-19-2020, 07:51 PM   #29
86MLR
86MLR's Avatar
Yeah the air box is fine IRT flow, but from my experience the cats stifle the flow, alot, removing both cats removes the restrictions, by alot.
Full decat and good DT tune will surprise many.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 01-19-2020, 09:41 PM   #30
Lantanafrs2
Drives: 2013 frs red
Imo the idea is to get a decent header and tune to make the car more enjoyable. Real gains are available without spending a lot of money. Big money should be spent on forced induction, not chasing 5 horsepower
Old 01-19-2020, 10:38 PM   #31
Ultramaroon
not playing cards
Ultramaroon's Avatar
...or wheels
Lantanafrs2 (01-19-2020)
Old 01-19-2020, 11:29 PM   #32
86MLR
86MLR's Avatar
In the end I had pulled 198hp from a 2017 OEM decated header and OEM decated exhaust, and the only bit that remained from spending money on a Tomei header, a Ultrex overpipe and a X force catless front pipe and cat back, was........ the $90 Ultrex overpipe.
Hell, it still had a OEM paper filter.
The only reason I now have a 2.5" system is because turbo.
I did recoup some coin from selling the Tomei and XForce to some kid who was all "torque dip" "boxer rumble" "powerers"...and stuff.
These are waiting quietly for the car fund nest egg to grow for injectors, fuel pump, clutch and maybe flex, maybe, not alot of E85 around these parts.
I was like, "yeah, this is what you need man".
Am I a bad man?
The Following User Says Thank You to 86MLR For This Useful Post:
Lantanafrs2 (01-20-2020)
Old 01-20-2020, 02:23 AM   #33
tomm.brz
Drives: brz 2017 hksv2
you are a bad man untill you not provide a base to confront with
198hp starting from what?
those 198hp can be 198hp at that day in your dyno, and 210 in another dyno and 187 in another dyno... who cares then if you dony have something to honestly compare is just a random number with no value
The Following User Says Thank You to tomm.brz For This Useful Post:
MrSkubi (01-20-2020)
Old 01-20-2020, 03:05 AM   #34
86MLR
86MLR's Avatar
OK, I made additional 33 killerwasps on the day
Or 44 hp
My journey of wasted money > http://www.ft86club.com/forums/showthread.php?t=133311
The Following 2 Users Say Thank You to 86MLR For This Useful Post:
Griever423 (01-29-2020), tomm.brz (01-20-2020)
Old 01-20-2020, 03:16 AM   #35
86MLR
86MLR's Avatar
Because original base line vs AVO turbo at 8 psi with 2.5" overpipe, resonated front pipe and OEM catback.
Why, because spending a couple of thousand dollars on NA mods is a waste of money.
Also I highly recommend Paul Fisher at Pulse Racing in Menai, NSW.
The care and time they take to get things perfect, plus their unbelievable after sales service is amazing.
https://pulseracing.com.au/toyota-86...ance-packages/
https://www.facebook.com/PulseRacingWorkshop/
Old 01-20-2020, 10:32 AM   #36
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by churchx View Post
On LHD you should be safe to get A350. As for tune, for Ace headers i suggest to get DT tune (ecutek). Ace headers doesn't show up that much gains (which probably were reason to buy those headers in first place) with OTS tunes, hence suggestion to go for DT tunes. Buy it, install, send logs back, they will tweak/release update revision(-s) and you should be ok. Most probably result will be much better with DT tune, despite "not local"/"remotely", then with some local tuner that hasn't spent that much time to get specific tune for these headers right (dyno time & tuner's time costs, a lot). There might be competent tuners around locally, i don't want to belittle anyone, but they simply won't have as much experience to dial specifically these and you won't have budget for them to replicate those hundreds of dyno runs and month(-s?) of fine-tuning tune to get result on par with DT's.
I would have gone with DT as well.. except for having a track only non-street legal car doesn't really make remote tuning all that easy
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-20-2020, 10:42 AM   #37
PulsarBeeerz
Drives: JRSC BRZ SOLD
Our cars show better gains on Dyno Dynamics than Dynojets for some reason..Seen massive gains on that style of dyno often. Maybe it's the tuners.��
PulsarBeeerz is offline   Reply With Quote
Old 01-20-2020, 11:02 AM   #38
Lantanafrs2
You can show some gains by 4th gear baselines and 5th gear post tune.
Old 01-20-2020, 12:26 PM   #39
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
A few updates, since our dyno plots are being discussed. We always do a baseline at 100% stock when possible. Always the same dyno. Always the same tire pressure. Always SAE corrected with same smoothing.
Blub was a healthy engine, made 172whp after three back to back pulls on CA91. ACE350 header made good power. Fitted a JDL header hoping for gains past 7200 and saw a mild improvement. No gain in peak power but less drop off after 7200. I scrutinized the datalogs and noticed a left over OEM control strategy that reduced power past 7200rpm. Suggested a small change, it worked. Now only minimal drop off on the top end. We sold our ACE350 header and stayed with the JDL.
As a tuner myself, I spent a lot of time looking at datalogs. I have tuned dozens of our MX5 street and multi championship winning race cars mostly on Megasquirt. Tuned our ND MX5 with Ecutek. We asked William to make many small changes to our maps to improve driveability, linearity and response. He was eager to work with us, trading logs back and forth. I never did any tuning on the 86, just looking at tables, data logs and driving. He tells me that most of those changes we requested became standard in all his 86 tunes. I imagine those are trade secrets now so I won't share any further detail. Too many other shops copying IP I know for sure that other 86 tuners aren't doing End result from DT is a true motorsports level tune right out of the box. Really happy with how Blub is working.
Also, almost no difference between 4th and 5th gear pulls on a Dynojet if you let the dyno resync for gear ratio. Like 1-2whp which is within the "noise" of regular readings. We do our pulls in 4th.
949 Racing is offline   Reply With Quote
The Following User Says Thank You to 949 Racing For This Useful Post:
PulsarBeeerz (01-20-2020)
Old 01-20-2020, 12:47 PM   #40
PulsarBeeerz
Can you throw up the dyno of the JDL? I could only find the ACE dynos in the build thread.
Old 01-20-2020, 01:27 PM   #41
JIM THEO
Drives: BRZ 2018
Still searching for independent dyno graphs with DT-ACE headers that replicate what DT claims, the only one from justynco is quite conservative and although has very good power/torque curves in midrange, imho doesn't worth the money they ask especially if you pay for extra corrections until fine tuned:
More realistic figures from known tuners:
https://www.gt86.org.uk/forums/forum...aru-brz-build/
and again:
https://www.gt86.org.uk/forums/forum...otorsport-hfc/
JIM THEO is offline   Reply With Quote
Old 01-20-2020, 01:53 PM   #42
tomm.brz
actually, yes your dyno was being discussed, but in a good way
it seems very realiable and trustable... we were talking "bad" about certain other dyno pulls, at least I speak for me
Gruppe S Headers j_ros94 Engine, Exhaust, Bolt-Ons 5 05-25-2019 09:08 PM
FS (So Cal) Gruppe-S Headers Unmarried OFT Sros1031 Engine, Exhaust, Bolt-Ons 2 02-08-2018 09:16 AM
OFH 3 vs Gruppe-S Headers.. RichardJ Engine, Exhaust, Transmission 24 04-09-2017 10:20 PM
WTB: Gruppe-S UEL Headers Russo Want-To-Buy Requests 1 03-15-2017 10:45 AM
