Old 11-01-2019, 03:38 PM   #29
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Originally Posted by arkanist View Post
I run the IRP short shifter and love it. Beware though, some people get really bad rattles with it. Also i took the clutch spring out after a couple months and haven't looked back. I got in a car with the spring and thought the clutch was fucked up lol
How difficult is installing the IRP kit?
JesseG is offline   Reply With Quote
Old 11-01-2019, 03:43 PM   #30
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
[ame]https://www.youtube.com/watch?v=gI7ozf-3Tfg[/ame]
Doesn't look too bad.
Beachin86 is offline   Reply With Quote
The Following User Says Thank You to Beachin86 For This Useful Post:
JesseG (11-01-2019)
Old 11-01-2019, 03:58 PM   #31
JesseG
JesseG's Avatar
Originally Posted by new2subaru View Post
Did none of you guys test drive the AT?
*Click*
Lol I considered it, for a minute
The Following User Says Thank You to JesseG For This Useful Post:
new2subaru (11-01-2019)
Old 11-01-2019, 04:06 PM   #32
JesseG
JesseG's Avatar
It doesn’t seem too bad, using a lift is required it looks like. The IRP shifter is much taller with very quick throws, that would be perfect for the track!
Old 11-01-2019, 04:08 PM   #33
JesseG
JesseG's Avatar
And I really like the FT86SpeedFactory videos They have some great walkthrough videos
Old 11-01-2019, 04:13 PM   #34
Ultramaroon
not playing cards
Ultramaroon's Avatar
That seems like the best option, I want to reduce the vague bite point.
It still doesn't fully engage until the very top but it's much better not having to swing through such a long arc of mush.
Full engagement is unusually high because the stock clutch is rated to let go before input torque frags the transmission. It's actually a sign of high mechanical stiffness of the overall mechanism relative to the springs.
bcj (11-01-2019), JesseG (11-01-2019)
Old 11-01-2019, 05:41 PM   #35
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
1. Been driving the car for a while and been used to it. Sometimes you would have to put it in 2nd then into first but perhaps that's just mine
2. The "tractor" sound isn't so pleasant to the ears. Drop a gear and commence smiles per gallon.
3. Short shift kits are a matter of preference. I am currently running it stock for almost 5 years so far but I am thinking of getting the TRD quick shift kit and/or STi short shift kit. on the TRD shift knob.
4. I have tried both. I kept mine and it's great for daily driving. A cousin of mine removed the spring from his tS. It is heavier but feels a bit more "engaging" if that makes sense.
Just my two cents
KMA KiCKz is offline   Reply With Quote
Old 11-01-2019, 05:55 PM   #36
Grady
Grady's Avatar
*Click*
I did, the first BRZ I drove in 2013. they did not have a manual on the lot. Then I went and drove the FRS Primer gray edition with manual. Then I went and bought a CRZ. Fast fwd 4 years later I went and bought a Yellow BRZ and did not not even drive it.
Old 11-01-2019, 06:15 PM   #37
new2subaru
Weight Weenie
Drives: 15 FR-S
I've actually been considering another one with a manual for a track car only.
Old 11-01-2019, 06:23 PM   #38
Beachin86
Beachin86's Avatar
Heathen!
Sent from my Pixel using Tapatalk
Old 11-01-2019, 06:42 PM   #39
JesseG
JesseG's Avatar
Originally Posted by weederr33 View Post
1. I do experience some crunch when it's really cold. But once it's warmed up it's smooth. I feel the '17 is better than my '13.
2. There is a 'tractor' sound but it's mostly drowned out by the full exhaust I have and its quite pleasing to my ears. The only woman who seems to like the sound is my mom? lol
3. I have the STI currently and it's minimal change but I like it. I had the shitty TRD shortened linkage thing. It was garbage and the bolt kept backing out. I know some have had success. I'd just leave it stock if you don't want to spend money. I know the weight of a shift knob can make a difference. I flip flop between weighted and light weight like the TRD.
4. I've heard good things about removing the spring. I haven't done it because I've gotten used to the clutch as it is.
Your Mom is a cool lady then! I had my Mom in my car recently and she mentioned I should get an aftermarket exhaust. She drives a Mini Cooper S.
So STI makes a short shift kit? Or is it a STI shift knob? I probably won’t get the TRD kit. I already have TRD springs, intake, wing, and shift knob.
Old 11-01-2019, 06:49 PM   #40
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
There is both an STI knob and an STI short shifter kit.
STI Knob: Part SG117CA010
STI Short shifter for MY17+: Part C1010CA100
wolffbite is offline   Reply With Quote
Old 11-01-2019, 07:06 PM   #41
JesseG
JesseG's Avatar
Leave the spring installed and do the slave cyl. swap. It's not the panacea but it does shorten that vague region. The spring only affects pedal weight.
Ultramaroon, what is involved in swapping the slave cylinder? Do you sell them? Sorry I know I’m late to the party.
Old 11-01-2019, 07:10 PM   #42
JesseG
JesseG's Avatar
BOO this man! BOOOOO!!!
LOL
JK I did the same thing. I initially test drove an auto because that’s all my local dealership had. It was still a fun driving experience. And I’m glad you dumped the CRZ.
Engine from Manuel to Auto Transmission Kevyn Engine, Exhaust, Transmission 12 05-22-2018 10:56 AM
Manuel vs automatic transmission? sci3 Engine, Exhaust, Transmission 46 08-15-2014 04:00 PM
white gts manuel available now !!!! sprang86 Australia Classifieds 0 02-12-2013 10:59 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
AT VS Manuel Based off Life length Xdragonxb0i Engine, Exhaust, Transmission 8 04-26-2012 02:23 AM
