Old 06-27-2019, 10:09 AM   #29
wparsons
wparsons's Avatar
Originally Posted by Kerber23 View Post
I was able to log the both with the car in the accessory position. The accel went from o-100 and I heard the throttle body opening as wel.
It doesn't sound like a sensor issue on the pedal then. Getting stranger and stranger.
flickr
Old 06-27-2019, 10:58 AM   #30
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
Originally Posted by Kiske View Post
As stupid as it seems wipe the codes and battery reset the ecu. That should fix your 4k issue. And likly what your seeing with the tps. I'd start with the map. Sadly, when I had issues with mine, LJ could only sell me another one to see if that fixed the issue. Fbm map sensors are just restickered omni 3/4 bar sensors should you noy want to spend 90$.
There are some boosted boys around here. Ill see if I can borrow one of the sensors before I start dropping bills for "potential" fixes. That would start adding up fast if they didnt work lol. Thanks for the tip!
Kerber23 is offline   Reply With Quote
The Following User Says Thank You to Kerber23 For This Useful Post:
wparsons (06-27-2019)
Old 06-27-2019, 11:46 AM   #31
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Have you checked for this boost leak?
http://www.ft86club.com/forums/showthread.php?t=109444
Old 06-27-2019, 03:04 PM   #32
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
At first when I thought it was a boost leak I was thinking that, the guy I got the engine from says he already clamped that hose down (he was boosted, now is doing an LS swap). But it just seems odd that a leak would stop all throttle response. The logs show the throttle angle not corresponding to the accelerator angle. Even flooring the accelerator during that portion didn't cause a bump in accelerator angle
Old 06-27-2019, 03:19 PM   #33
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I figured, just thought I would throw that out there. I thought I read in a previous post that the ECU was logging 0-100% throttle and you could hear the TB opening. If the throttle angle does not correspond to the accelerator angle it sounds like the TPS is out of range.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Kerber23 (06-27-2019)
Old 06-27-2019, 03:23 PM   #34
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
Well I just pulled out the gas pedal, reset the codes and it instantly started doing the idle really high and ignore throttle response. Normally after I clear DTCs I can get the car to idle. I have someone coming over who will let me try his gas pedal. see if that solves things.
Old 06-27-2019, 06:45 PM   #35
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
https://imgur.com/a/WoKLKO0
https://imgur.com/a/wlDKpgc
So I took the intake manifold off, and the notorious boost leak area was a non-issue. The only odd thing I noticed was one of the manifold gaskets. Do you think that this could be causing my problems? I doubt it. I was jiggling the wires going to the MAP Sensor and it was causing stuttering. I ended up buying another MAP sensor and we will see if that fixes it. If not Ill try and sell it.
Old 06-27-2019, 10:05 PM   #36
soundman98
ProCrastinationConsultant
soundman98's Avatar
starting to sound like it's an issue with the vehicle-side MAP wire connector. my diagnosis would start there. check for distorted/bent/corroded pins, tug the wires for a oem-poorly crimped wire as well.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Kerber23 (06-28-2019), wparsons (07-02-2019)
Old 07-29-2019, 02:21 PM   #37
wparsons
wparsons's Avatar
Did you get anywhere with this?
flickr
Old 07-04-2020, 11:47 AM   #38
jacob.hawk.fcp
Drives: Scion FRS
Yeah I have the same issues. Mines holding at 2k. After 5 mins mine will start bouncing rpm. Replaced the pedal and the throttle. No change. Any word on the sensor?
jacob.hawk.fcp is offline   Reply With Quote
Subaru Dealer Holds BRZ Hostage After Facebook-Stalking The Owner's Track Day Photos Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 35 08-19-2017 12:46 AM
Where do you keep your revs? ScionFrsFan Scion FR-S / Toyota 86 GT86 General Forum 54 06-11-2015 12:07 AM
Caliper Sliding Pin - What Holds It In? elbles Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-08-2014 09:03 PM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 12:20 PM
BRZ holds its own in Auto-X with rookie driver mtimney Tracking / Autocross / HPDE / Drifting 4 08-11-2013 12:24 PM
