Old 06-10-2019, 01:36 PM   #29
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by tobin View Post
Do you guys crawl under those?? Looks like a death sentence...
it actually feels more stable than a normal 2-post lift, if that makes sense.
I've had the BMW on this for 2 weeks now, I'm already using the car for storage haha.
This is as stable as the floor or surface you have it on. Any imperfections in the concrete or floor will magnify into the stability of the car on it.
Old 06-10-2019, 02:11 PM   #30
Ultramaroon
not playing cards
Ultramaroon's Avatar
The rubber blocks are fine. A little awkward to have to place them carefully. I bought a length of 2x6 to cut into blocks that will fit into the pans. If you go that route, make sure the grain is perpendicular to the pinch welds.
What's the Pro Stand?
Old 06-10-2019, 02:19 PM   #31
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
A thousand dollar stand for your Pro Display XDR from Apple.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Ultramaroon (06-10-2019)
Old 06-10-2019, 03:57 PM   #32
Ultramaroon
not playing cards
Oh, shit! Haha... I heard about that thing. What a crock!
EAGLE5 (06-10-2019)
Old 06-10-2019, 10:00 PM   #33
Windycitystig
Drives:
Just saw this in the manual.
Do not work under an elevated Vehicle unless properly rated Vehicle Jack Stands are in place under the factory-recommended Lifting Points.
Where do you put the jack stands if the lifting points are on the QuickJack?
Windycitystig is offline   Reply With Quote
The Following User Says Thank You to Windycitystig For This Useful Post:
tobin (06-11-2019)
Old 06-11-2019, 07:59 AM   #34
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I have this one and fits perfect. Order the pinch weld blocks.
100% order the pinch weld blocks. The blocks that come with it will split on you since they are designed for a flat surface, not the "sharp" pinch weld. If you continue to use the "stock" blocks, one day during a test drive you'll hear this God awful thumping sound. When you return home to put it back up on the Quick jack to figure out what you did wrong, you'll be missing a block...ask me how I know.
The Quick jack is the jack stand.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Sapphireho (06-11-2019)
Old 06-11-2019, 11:26 AM   #35
mav1178
mav1178's Avatar
What this simply means is that if you somehow lift the car using anything other than factory lift points (some cars you can lift via subframe mounting points), then you need to have jack stands (or equivalent) under the lifting points. This is because that's the part of the chassis that is designed to hold the vehicle weight in its entirety.
Old 06-11-2019, 12:08 PM   #36
Dake
Dake's Avatar
It's also for liability purposes. That way if it does collapse and kill someone, they can say, "Oh, we told them to use jack stands also."
Dake is offline   Reply With Quote
The Following User Says Thank You to Dake For This Useful Post:
tobin (06-11-2019)
Old 06-11-2019, 01:48 PM   #37
humfrz
I'd still put a backup under there -
humfrz
BirdTRD (06-11-2019)
Old 06-11-2019, 02:37 PM   #38
BirdTRD
Simply Forgotus
BirdTRD's Avatar
humfrz
I was thinking more like...
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
humfrz (06-11-2019), soundman98 (06-11-2019)
Old 06-11-2019, 07:39 PM   #39
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Does anyone with a QuickJack use these things that came with it?
Old 06-11-2019, 08:32 PM   #40
humfrz
I don't think that box will hold up the car -
humfrz
Old 06-11-2019, 10:27 PM   #41
EAGLE5
Dismember
EAGLE5's Avatar
I thought quickjacking was... oh nevermind.
Old 06-11-2019, 11:03 PM   #42
Dake
Dake's Avatar
Nope.
FS: (MA) Bendpak QuickJack BL3500 Portable Lift gutbomb Mechanical Maintenance and Tools 9 07-25-2021 11:12 PM
QuickJack setup and testing with my BRZ justinco DIY (Do-It-Yourself) Guides 27 12-28-2020 03:57 PM
Bendpak QuickJack BL-5000 cnk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 104 05-22-2017 06:21 PM
Costco sale on oil!! stockysnail Northwest 2 02-12-2016 10:19 PM
Costco Gas now Top Tier N1rve Off-Topic Lounge [WARNING: NO POLITICS] 22 04-15-2014 06:19 PM
