Old 12-26-2018, 10:21 PM   #29
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Something that has a lot of inertia that is often overlooked is the alternator.
Gates has retrofit kits for 1ZZFE corolla where they replace the hydraulic damped tensioner with a simple sprung one, and replace the alternator pulley with a one way clutch to improve the setup.
The alternator may be ratio'd at many times the speed of the engine, and that rotor is nothing but laminated steel and wound copper. Of course the blower may not be helping, but every time the engine has a hickup, the inertia in that rotor shoves the belt pretty hard It might be a cheaper avenue to look for a decoupled alternator pulley than for a hydraulic tensioner
Old 12-26-2018, 10:52 PM   #30
Ultramaroon
not playing cards
Ultramaroon's Avatar
The inertia from the accessories do add together. I like the idea of a sprag clutch. I think HKS designed one into their supercharger. Wonder why others don't.
The cheapest fix would be to smooth out that cold idle.
Old 12-27-2018, 09:56 AM   #31
gtengr
Drives: 2017 BRZ
I have an extra flanged idler pulley from the used Cosworth kit I picked up (bought a new pulley and gaskets from Cosworth just because). I could sell it pretty cheap. I believe there's about 15-20k miles on it but cannot say for sure. I don't have any reason to think it's bad, but the bearing in it is serviceable and could be replaced as a precaution.
gtengr is offline   Reply With Quote
The Following 2 Users Say Thank You to gtengr For This Useful Post:
BirdTRD (12-27-2018), Ultramaroon (12-27-2018)
Old 12-27-2018, 02:25 PM   #32
Ultramaroon
not playing cards
Originally Posted by gtengr View Post
...flanged idler pulley...
Excellent.
gtengr (12-27-2018)
Old 12-27-2018, 06:54 PM   #33
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Interested. Which pulley does it replace? The green one has a flange and the Edlebrock kit adds the red ones.
BirdTRD is offline   Reply With Quote
Old 12-27-2018, 08:29 PM   #34
gtengr
Drives: 2017 BRZ
I misspoke earlier it's actually the tensioner pulley.
Old 12-27-2018, 08:50 PM   #35
BirdTRD
Simply Forgotus
BirdTRD's Avatar
PM'd
Old 12-27-2018, 09:36 PM   #36
Ultramaroon
not playing cards
Here is where the belt goes slack.
Serpentine belt issue / So Cal LAX Airport russsak Issues | Warranty | Recalls / TSB 12 09-09-2018 05:11 PM
Serpentine Belt SlyCayer Engine, Exhaust, Transmission 3 04-13-2015 02:40 PM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 02:33 PM
Serpentine Belt Changeout Guide FRS BRZ Binbear4 DIY (Do-It-Yourself) Guides 0 11-17-2013 06:35 PM
