#29 |
Drives: brz 2017 hksv2
you can use the v4 k00g as a base to mod, what I meant is that if you keep using that stupid tune you only will have shitty performance... i would copy majority of the tables from a a01g o b01c V4 tunes to your k00g manually and use that as a starting point.. it runs just better in every way
also if your coolant gets to 93 the radiator fan values you are using are obviously not working try 89 91 90 95 or even more pushed: 88 90 89 94 in both the tables for rad fans, this way you will never pass 89-90C |
#30 |
Drives: BRZ 2018
Looking back logs (34C ambient) with my car unmodified I've had more or less same ECT, is it only my car or is something different from yours, who knows!
![]() Min are in Fahreneits 190.4 - 194 - 192.2 - 203 so practically same values with second set you posted above. Last edited by JIM THEO; 11-04-2018 at 06:52 AM. |
| Motul gear 300 or Redline MT90? | BRZ NA | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 70 | 11-30-2016 03:02 PM |
| AmsOil/Motul oil flush... increased mileage? | aznatama | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 01-28-2015 09:53 PM |
| Fluids @ Maximal - Motul, Redline, Royal Purple and more! | Maximal | Engine, Exhaust, Bolt-Ons | 17 | 08-13-2014 02:38 PM |
| Transmission fluid blending Redline MTL and Motul Gear 300 okay? | imom | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 11-01-2013 08:03 PM |
