Old 11-07-2018, 06:14 PM   #29
steve99
Originally Posted by Mr_Eyo View Post
I don't see it in the OFT defs.
Thats because the defs dont have those tables
But i dont think thats your problem, switching between pi and di is usually seemless unless you have messed with the scaling or pressure tables. and you dont appear to have an AFR issue
your last logs show your ignition timing going to "0" or "2" degrees when on throttle transients like changing gears, normally this would be arround +10 degrees as a minim
you may have adjusted something in tune thats causing this like transient retard settings or have some very strange ignition maps.
https://datazap.me/u/protoformx/log-...5209&mark=5115
Old 11-08-2018, 01:31 AM   #30
Mr_Eyo
Drives: 2017 Toyota 86
The OTS transient retard tables have nearly the same magnitudes as the advance table, so transients do cause timing to drop quite a lot. How much retard can I remove from the table safely?
Mr_Eyo is offline   Reply With Quote
Old 11-08-2018, 03:11 AM   #31
steve99
If your using standard values in the transient tables and the associated trigger tavles then that may not be the issue as everyone would experience that.
Look at what you have changed , stuff lioe adding exhaist pops can also do that.
Old 11-08-2018, 04:46 AM   #32
Mr_Eyo
I don't have anything like that changed. I also notice a drop to 0 deg ignition timing after cold start after about 70 seconds. Fueling mode goes from CL to OL at that same time. I wonder if that is an instance of transient response retard kicking in.
Old 11-08-2018, 06:45 AM   #33
steve99
Ignition timing poxt start waemup phase is set to 0.04 ie 0 degrees in oft v4 tunes so thats normal. Car will cold start in open loop till o2 sensor warms up then go closed loop again normal.
Load a stock tune into car if your on petrol , see if you get same issue. This will tell you if its tune or hardware
Old 11-09-2018, 06:38 AM   #34
Mr_Eyo
I haven't tried returning to stock because I haven't had time and I don't really want to considering I haven't changed anything substantial in the tune. I did some searching and stumbled on this old post talking about a TSB that resulted in retard being added to mitigate the knock/DI seal destruction issue when shifting at high loads. The icture of the transient retard table is waaaay different from the one in OFT OTS v4.03. Which table is it supposed to look like? Looking in my logs, it's pulling ~20 deg per upshift.
http://www.ft86club.com/forums/showthread.php?t=50088
OFT v4.03:
<table type="3D" name="Transient Ignition Retard" category="Alpha - BRZ" storagetype="uint8" endian="big" sizex="7" sizey="24" userlevel="4">
<scaling units="Ignition Timing Correction (degrees)" expression="(x*.3515625)-50" to_byte="(x+50)/.3515625" format="0.000" fineincrement=".2" coarseincrement="1" />
<table type="X Axis" name="Engine Load" storagetype="float" endian="little" logparam="E32">
<scaling units="g/rev" expression="x" to_byte="x" format="0.00" fineincrement=".01" coarseincrement=".1" />
</table>
<table type="Y Axis" name="Engine Speed" storagetype="float" endian="little" logparam="P8">
<scaling units="RPM" expression="x" to_byte="x" format="#" fineincrement="50" coarseincrement="100" />
</table>
Old 11-09-2018, 07:00 AM   #35
tomm.brz
Drives: brz 2017 hksv2
that table is identical to stock >my17, subaru made it really aggressive probably to eliminate totally knocks on transients
it s a bit up to you, you can reduce it to improve driveability but then you must accept the risk
Old 11-10-2018, 02:21 AM   #36
Mr_Eyo
OK, that helps a bit. I'm confused though that transient retard is near 0 for high load at all RPMs. I thought knock was very bad at high load & RPM.
For tuning these down, can I just gradually decrement them and just watch AFR and knock correction? Or would it be much harder to monitor for?
Old 11-10-2018, 03:48 AM   #37
steve99
Transient retard is mainly for when your full throttle high rpm then you lift off to shift , the "load" is not rearly load its a derived parameter from rpm and air flow. But as you lift off quickly the load drops hence the ecu wouod normally increase timing as per the ignition tables, but if its considered a transient ie its passed the checks in the transient retard section the transient retard table becomes active and reduces timing.
Now usually at low loads your running say 30 or 40 degrees advance but if transient retard is active it will subtract that value and you should end up with about 10 degrees advance.
But for some reason your getting zero
Did you change any of fhe activation ot threshold tables
Old 11-13-2018, 08:51 PM   #38
Rezi
Drives: GT86
Personally i wouldnt recommend to dig at the trans ign retard table around for this issue.
Copy the "minimum cfp delta for trans ign retard" from the MY17 over onto yours should solve the issue for 99%.
I had the same.
Rezi is offline   Reply With Quote
The Following User Says Thank You to Rezi For This Useful Post:
tomm.brz (11-14-2018)
Old 11-14-2018, 10:51 AM   #39
tomm.brz
I had the same.
That was nice to know.. i never paid attention to this map and always kept the lower values of ots maps. Tried it today and going back to stock my17 improved a lot the driveability for me
thanks
Old 11-15-2018, 01:45 AM   #40
Mr_Eyo
I had the same.
Soooo... I have the USDM MY17 AT, downloaded the ROM from the car when marrying the OFT, and the v4.03 def I got for it from OFT (OFTv4_ZA1JK00D.xml) can't read it in RomRaider...
  1. Where can I get a def that works?
  2. In the meantime, what are the 8 factory values in the table if you have them handy?
Thanks guys.
Old 11-15-2018, 09:09 AM   #41
steve99
Thanks guys.
their is no opensource def for K00D
you oft K00D rom is actually an K01I rom internally
Old 11-15-2018, 10:55 PM   #42
Mr_Eyo
So where can I find the stock min CFP Delta retard table if I can't read my own stock ROM?😢
E85 OFT tune Bucking/surging Vmax911 Software Tuning 5 07-30-2017 04:27 AM
Horrible bucking and shutter after clutch install Scikotic Engine, Exhaust, Transmission 32 07-12-2016 09:10 PM
2-3K RPM hesitation/bucking - logged 86fun Software Tuning 5 01-29-2016 09:58 AM
Today, my car made a violent bucking sound on start up... lupindub Issues | Warranty | Recalls / TSB 3 11-28-2015 10:27 PM
loss of power/ bucking in rain fasteddy Issues | Warranty | Recalls / TSB 30 10-20-2015 03:08 AM
