Old 10-21-2018, 09:12 PM   #29
byun
byun's Avatar
Drives: 2015 BRZ CWP
Originally Posted by 86TOYO2k17 View Post
I ran ace, with hks FP, and stock exhaust. It didn’t really buzz. But personally I thought it sounded bad. Hard to explain something just sounded off. So I got the CSG touring86 didn’t make it louder but deepend and crispened up the sound. Now it sounds right. Just my opinion and experience.
Yea, plan on ordering the csg catback
byun is offline   Reply With Quote
Old 10-22-2018, 01:19 PM   #30
mgarcia707
mgarcia707's Avatar
Drives: 2017 Toyota 86
Currently running JDL UEL Catless Header with stock catback.
mgarcia707 is offline   Reply With Quote
The Following User Says Thank You to mgarcia707 For This Useful Post:
tobin (10-25-2018)
Old 10-22-2018, 03:32 PM   #31
strat61caster
strat61caster's Avatar
Originally Posted by jsimon7777 View Post
I'm probably the only guy running a Borla EL with the stock exhaust. I like the sound. A bit more revvy.
I'm on Tomei EL + stock
We're just lame nerds
Although I struggle to jack up the rear with the stock can, CSG tempting me with their exhaust after I gave up on the cheap axleback...
Originally Posted by stlgrym3 View Post
I’m just surprised how quiet the car is now with the stock catback. I know it’ll be quieter than before but this is almost exactly stock-quiet. Doesn’t header by itself make the car louder? I’m not complaining just curious.
You'll notice the difference if you compare back to back. I think just a header is quieter than an axleback exhaust. Getting louder can be tricky if you're picky.
ineedyourdiddly
EAGLE5 (10-23-2018)
Old 10-23-2018, 07:09 PM   #32
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I ran Tomei EL with stock midpipe and Nameless single exit muffled axle back.
I found that, in most cases, having an aftermarket header paired with an aftermarket mid pipe (especially one that isn't resonated) leads to the exhaust note sounding very raspy and obnoxious in the higher RPMs.
So I opted to keep the midpipe stock and was really happy with the exhaust note.
TylerLieberman is offline   Reply With Quote
Old 10-23-2018, 09:32 PM   #33
dostoyevsky
Drives: 2017 BRZ
Ive personally found that UEL headers with HKS lega max is the perfect balance between loud and quiet
dostoyevsky is offline   Reply With Quote
Old 10-24-2018, 10:56 PM   #34
Calum
That Guy
Drives: 2013 asphalt FRS MT
It's not. Check out the Touring86.
Do you guys sell these through any Canadian dealers? www.ft86motorsports.com perhaps?
Old 10-25-2018, 12:27 AM   #35
Unfortunately not, but it can be shipped via UPS Ground!
Many Canadian folks ship to a depot south of the border.
Calum (10-25-2018)
Old 10-25-2018, 04:30 PM   #36
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Ive tried different setups (4 now) and that was my favorite, with HKS dual resonated FP.
Im on ACE 350 headers, Hooker Catted/ Helmholtz resonated FP, Borla Catback. I wanted 2.5" piping all the way through and I got a bit lighter.
However I prefer the sound with the HKS Legamax premium the best I regret selling it.
I still find it hard to believe there isn't a bottleneck when using the stock FP with the ACE 350 headers. The Ace headers end in a 2.5" opening, the Stock FP is ~2", That's a huge restriction
Almost all aftermarket FP's taper down to the stock FP diameter size at the back end so after the FP its doesn't really matter as much the diameter of the Catback.
In conclusion I would go with a FP with a high flow cat and Diameter piping that matches up with your headers. The catback size doesn't seem to matter after that. Its what do you want in sound/weight at that point.
SuperTom is offline   Reply With Quote
Old 10-25-2018, 05:26 PM   #37
tobin
tobin's Avatar
Drives: '13 BRZ
How much louder is it? Do you have a video clip? This is the setup I'm looking at.
tobin is offline   Reply With Quote
The Following User Says Thank You to tobin For This Useful Post:
mgarcia707 (10-29-2018)
Old 10-27-2018, 07:36 PM   #38
HachirocksU
Drives: Friggin Really Sweet
Thats. . quiet wow. What exhaust? Ace or Touring86?
HachirocksU is offline   Reply With Quote
Old 10-28-2018, 09:04 AM   #39
stlgrym3
Drives: 2017 Subaru BRZ Limited
After one week of daily commute with this setup I think I will go back with aftermarket catback again. Nothing wrong with stock catback, but starting to miss that deep growl once a while. Main targets are quiet catbacks with good build reputation. I’m down to two choices: Perrin 2.5 resonates or CSG Touring 86. I have ACE 350 header and stock front pipe. Which one would you pick?
stlgrym3 is offline   Reply With Quote
Old 10-28-2018, 10:45 PM   #40
Neither actually, because both the Ace and Touring86 did not exist at the time; it was a modified (now discontinued) GReddy.
Old 10-29-2018, 02:47 AM   #41
Enkrow
Enkrow's Avatar
I have the Skunk2 EL header, paired with a stock catback.
Until the upper end of the rev range, the exhaust is more quiet than my GrimmSpeed intake.
I'd go with the CSG touring, personally. IIRC it was supposed to be around 90db or so max, so it won't blow out your eardrums.
Enkrow is offline   Reply With Quote
Old 10-29-2018, 01:25 PM   #42
mgarcia707
mgarcia707's Avatar
Compared to stock it's night and day. I love how it currently sounds, but I do plan on getting a different exhaust to really complement it. As far as a video clip I can try and send you one this weekend.
tobin (10-30-2018)
Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp fooddude Engine, Exhaust, Transmission 11 08-11-2016 07:18 PM
Aftermarket catted front pipe with stock catback Aenv Engine, Exhaust, Transmission 1 12-07-2014 12:30 PM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
Aftermarket Catback (Q300) but using the stock muffler. Wise Engine, Exhaust, Transmission 11 10-16-2014 02:42 AM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
