Old 11-11-2018, 09:08 PM   #29
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Originally Posted by dpaqu View Post
Interesting numbers. What is cheaper than a FT? How much more are HPDE than W2W? I have a buddy who says his spec 944 isn't costing him more to run than his Corvette was.
The vast majority of operation cost is tires. Stuff like engines- at least for us common folk, won't be that big per hour because they last so long. For an OEM engine you should be able to run it a long time and refresh with new bearings everyone in a while on most engines.
Brakes can be expensive too. Then you have fuel and oil and etc
$1600 tires are good for about 8 hours (at most- even that is pushing it and I'm running 18s instead of factory size. That's $200/hr - probably more because 8 hours is a lot of time for a set of tires on a car likethe c7)
$1200 for front rotors and pads all around that lasts about 12 hours. That's $100/hr
Fuel is about $50/hr
Oil change, brake fluid, trans fluid, rear diff fluid, etc is the rest.
Tires are what carries the most. The c7 will use far more expensive tires and eat them up faster. Brakes are also variable which is why you hear everyone telling you about how a bbk will save you money. Not having $350/each rotors helps. Not putting a ton of heat into them from massive grip, weight and power also helps.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
Tein Street Flex Questions WolF_RS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-02-2016 02:27 AM
Street Mod questions Shit Luck Tracking / Autocross / HPDE / Drifting 61 10-18-2015 04:59 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
New FT86 Owner, some questions. Parix Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 05-26-2014 07:41 PM
