Old 08-13-2018, 02:32 AM   #29
AFRichZC6
AFRichZC6's Avatar
245/40R17 for most tires are square on 17x9. It's the popular setup for SCCA STX autox class, and most competitive cars in that class also happen to look pretty good too.
You may get a slightly larger contact patch with 255/40, but it's a taller tire than 245/40R17 and 215/45R17 so you'll lose some acceleration due to effectively taller gearing.
Even though I have a set of 245/40 on 17x9 because it's optimal for my autox class, I prefer the steering feel and quicker-feeling acceleration of a narrower 215/45 or 225/45 on 17x7.5 or 17x8 for daily street use. It also feels more fun.
FWIW, I think you're putting in way more thought than what's needed in saving a few pounds in your street-driven car's wheel and tire setup. If you're not trying to find tenths and hundredths of a second on a track or autocross, pick a wheel with a size and offset that looks good (to you) with your desired ride height and camber settings, get a tire that's suitable for what you're doing with your car, and just enjoy driving it.
AFRichZC6 is offline   Reply With Quote
Old 08-13-2018, 03:47 AM   #30
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Can't enjoy heavy twin.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 08-13-2018, 08:20 AM   #31
StraightOuttaCanadaEh
Wes
I find the gearing thing not very enjoyable. The MY17 86 already has shorter gearing so I have to shuffle through the gears fast to get up to speed. It's this frantic pacing that gets tiring as hordes of crossovers and sedans with CVTs are on my ass immediately. I live in a big city and people have no patience so I have to get up to 20 over the speed limit asap lol. Smaller diameter tires make that harder, which is what I noticed when I had the OEM rims with a 215 section tire. I much prefer the 18" with a 225 section tire. It may impact acceleration but not to a degree I'd notice. But I do notice that I don't have to shift as frantically now due to an increase in the overall diameter. This is why I said that if I were to switch to a 17" wheel to save weight, I'd still want to maintain the same overall diameter. BUT since that compromises the weight savings and makes it not really worth it in the end, I'll stick with the 18s
And that's the gist of my presentation. The post was also partially like a PSA cause I noticed a lot of people here bragged about lighter 17" wheels but then they have fat heavy tires and may not know.
Instagram: @gt86ws
Old 08-13-2018, 12:14 PM   #32
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Aside from just looks vs performance, I have meaty tires mainly to help with the shitty roads in NYC lol. Running 17x9 RFP1s with 255/40 tires. Absolutely not for performance because honestly, I don't track my car and I'm not gonna pretend I do.
PandaSPUR is offline   Reply With Quote
Old 08-13-2018, 12:36 PM   #33
Wes
Does it improve ride quality? Cause that's one of my problems as well. I have coilovers and have to play with tire pressures to make the ride tolerable.
Instagram: @gt86ws
Old 08-13-2018, 01:13 PM   #34
PandaSPUR
PandaSPUR's Avatar
I went from stock suspension + wheels to Tein Monosports + RPF1 on 255/40. This was like two years ago so I can't be sure, but I don't remember the car feeling any worse in terms of ride comfort. I think the two balanced each other out.
Impossible to compare the two directly in terms of going over potholes and whatnot since I'd have to find the exact same potholes. But I really do think it helps with that. Between the thicker walls with more air to absorb impact and the wider tires to help me just drive over some potholes or at least avoid enough of the pothole so that I dont fall into it.
Old 08-15-2018, 01:42 PM   #35
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Are you turbo'd or sc'd?
I was supercharged with a c38 running on e85. I'm now turbo'd with a gtx2860r and making more power than the supercharger.
pgranberg11 is offline   Reply With Quote
Old 08-15-2018, 02:44 PM   #36
Wes
reason I'm asking is an sc has a more linear power delivery, so I'm assuming traction shouldn't be as much of an issue as it would be with a turbo. Could be wrong. Could depend on what kind of sc and the tune of course
Instagram: @gt86ws
Old 08-15-2018, 04:56 PM   #37
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
It's actually the other way around. the supercharger had so much power down low I couldn't really floor it from the start. The turbo does take a second or so to actually get going. I actually prefer the turbo setup too over the supercharger. It's more efficient (comparing the compressor maps). On 14psi on the supercharger I am no where near as fast as I am now with 10psi on my turbo.
Old 08-15-2018, 05:33 PM   #38
jpmanv3000
Drives: Scion FR-S
18x9.5
Will 18x9.5+35 offset work on stock Scion FR-S. Mainly I’m thinking the front of it will work. I have some people say not unless you have coil overs and some say that it can work without them. Has there anyone that has tried to do this
jpmanv3000 is offline   Reply With Quote
Old 08-15-2018, 06:38 PM   #39
Wes
Yeah I hear you. I had a turbocharged car before though, and for various reasons, would prefer to try an sc this time. Hear a lot of good things about edelbrock. Just waiting for them to release the updated MY17 version. If that doesn't work out, I'll go JDL turbo
Instagram: @gt86ws
Old 09-04-2018, 01:05 PM   #40
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
FWIW, I just went from stock wheels and tires to Apex 17x9's with Firestone 245's and lost .6lb per corner.
bmxr is offline   Reply With Quote
Old 09-04-2018, 01:28 PM   #41
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Nice! Firehawk Indy 500 wide oval? how do you like the tires?
Old 09-04-2018, 04:08 PM   #42
sroby
Drives: 2015 Firestorm 08/05/15
Firestone’s were not worth a damn until Bridgestone bought them out in 1990. Good luck. I’d like to know how they hold up as well Keep us posted.
sroby is offline   Reply With Quote
Does wheel weight matter that much? smg1138 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-06-2015 03:57 AM
Wheel weight, will I notice it? Re~Mix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-09-2014 02:29 AM
Wheel weight.. does it Matter? karma003 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 64 08-22-2013 10:24 PM
Light Weight Fly Wheel denverizzles Engine, Exhaust, Transmission 13 12-03-2012 02:28 PM
What is the penalty for . . . ? calieigh Off-Topic Lounge [WARNING: NO POLITICS] 1 02-23-2010 11:54 AM
