Old 08-13-2018, 04:52 PM   #29
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
There were some owners in Japan having issues even with the stock crank pulley, but they had turbo or supercharged cars. It looks to exist a correlation with high load applications. In such cases they even suggest to use the Fluidampr pulley. I had mentioned it before.
Old 08-13-2018, 04:56 PM   #30
mrg666
pessimistic skeptic
mrg666's Avatar
I will go drive with my smooth engine instead of getting into another light-pulley fight here. Everybody does whatever they want to their cars. Don't eat too much popcorn before dinner!
Old 08-13-2018, 04:59 PM   #31
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Fight on what? Get a bit serious ... No-one said you did anything wrong.
And by the way, here is the old post:
http://www.ft86club.com/forums/showp...2&postcount=24
Old 08-13-2018, 05:51 PM   #32
Lantanafrs2
Drives: 2013 frs red
I was on 93 with header and tune when the motor failed. Spit a rocker at first. Rest of motor was inspected and bearing problem discovered. Toyota was fantastic! I doubt bearings are insufficient for e85 use. Not that much of a load increase.
Old 08-13-2018, 05:57 PM   #33
Lantanafrs2
Toyota did me a solid. If it were another brand I'd be fucked.
Old 08-13-2018, 05:59 PM   #34
Lantanafrs2
Reverse the vacuum on these motors (f.i.) and all bets are off.
Old 08-13-2018, 06:33 PM   #35
mrg666
pessimistic skeptic
mrg666's Avatar
Do you know Edelbrock has powertrain warranty and there is not anybody that I know claimed warranty yet. Jackson Racing tracked their cars several seasons already (they won the championship actually two years ago)? There are proper ways of going FI and there are other ways.
Old 08-14-2018, 06:20 AM   #36
ermax
ermax's Avatar
Load on bearings doesn’t increase when power output increases. Load on bearings increases when starved of oil. Bearings are only there to create the perfect clearance for the oil to create a “bearing”. As long as the oil temps are in range and pressure is good then the bearings never make contact. But throw in a bunch of vibration from something being out of balance and you will potentially wear bearings. I personally would rather stick to a dampened pulley and go with a flywheel to reduce rotating mass. There is more to be had in the flywheel anyways.
Removing crank pulley on automatic nlowell Engine, Exhaust, Transmission 11 11-11-2016 11:08 AM
SOSOSOS CRANK PULLEY AUTOMATIC HELP ScionFR-S Engine, Exhaust, Transmission 5 10-21-2014 10:30 PM
Lightweight crank pulley on an AUTOMATIC Gani21 Engine, Exhaust, Transmission 17 09-30-2013 10:27 AM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
