#29 |
Drives: 2013 FR-S Argento
Holy zombie thread
Sent from my SM-G965U using Tapatalk |
#30 |
Rust bucket enthusiast
#31 | |
Drives: Q5 + BRZ + M796
I haven’t tracked my car, but I routinely take the car to redline. I’m on E85 at a bar of boost on a Harrop SC, Ace150 and Michelin Pilot Sport 4Ss. No issues so far. I always wonder if the issues that lead to motor failures are more about other issues than power in those track situations like not using E85, not properly lubricating or cooling the car or some type of starvation issue. It would be nice to know for sure when a failure happens.
#32 | |
LMGTFY
Drives: 13 FRS, 91 Miata
#33 | |
Were you making a point that I missed?
#34 |
It's too complex IMHO. We humans like to simplify things but in this case don't think it's simple, too many variables and combination of those variables can lead to a failure.
Forget all these commonly addressed factors like heat management, knock resistance, driving habits, etc. Consider basic variance in motor construction - high volume 'cheap' motors typically have a fair amount of variance that is acceptable within the intended design envelope. You can get away with it if your motor has to manage a peak of 160 whp and 130 wtq - "get away with it" meaning they can produce a motor at specific planned cost without having a ton of stock failures/warranty claims. Now, double the torque and hp output - you're way outside that design envelope. Any weaknesses/flaws in your particular motor will quickly be made apparent - given most manufacturing is relatively consistent and most motors will manage fine, but any variance/weakness will very quickly become apparent. Once that happens we all try to point fingers at the obvious things, but we all have to keep in mind that pushing a motor way past its original parameters is a game of russian roulette to some extent. |
#35 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
1. Higher oil temperatures from sustained high rpm's could lead to early bearing failures and pre-mature component wear as the oil becomes less viscous with temperature increase. 2. Heat soak from high load, high rpm use increases the IAT's. More so, when you are in traffic on track you are not able to get clean air. Higher IAT's/charge temperatures mean increased chances of knock, detonation or LSPI. 3. Depending on track layout, you may be forced to run the car in conditions that you wouldn't normally find on the street. Example: There's sections of tracks that are up steep hills (Laguna Seca for example), which see's long WOT's up hill. This is a scenario where you will be loading the engine (almost lugging) far greater than on the street. Another example is there's a local track that has you between 6800-7400 rpm on and off WOT for like 15 seconds. On the street, it would be very odd to hold 6,800+ rpm for that long. Have you been on track before? It's hard to fathom how hard track work is on a vehicle if you haven't experienced it. Doing a 10 second pull on the street is one thing, but a car can see 15-20 minutes+ of sustained WOT at high engine speeds during a single session. There's a reason why some motorsport dampers can go 100K street miles without a rebuild, yet recommend a rebuild after 20-30 track hours. It's just simply magnitudes harder on components.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
#36 | |
LMGTFY
What I am getting at is that what fuel you run should be what fuel you are tuned for and has absolutely no bearing on blowing an engine. Having E85 is nice but not always available. Knock resistance - Tune for less timing based on what fuel you run. Less boost needed for the same power output - Shouldn't be tuned for more boost/power than you can safely get with your fuel anyway. The way your argument is worded comes to the logical conclusion that everyone should run full on race gas. |
#37 |
Haven’t. Just the canyons n street. Never made time for the track.
#38 |
Drives: 2013 Scion FR-S in Ultramarine
Yeah, I blew a rod bearing with my Spintex SC pushing 8-10 psi (75mm pulley) and e85 was used exclusively. It took 3-1/2 years to reach failure. So I don't think the tune was at fault at all. Car has been sitting in the garage since September. I will be getting it in the shop in January though. New Manley forged rods going in with new King XPG main and rod bearings and a new stock crank shaft. I don't intend to generate more than 300 -320 hp at the wheels. However, I will ask since I can't find the information online. How much HP can the stock pistons handle before they disintegrate??? 120 hp per piston, 150 hp per piston ?? More?? Less?? If anyone knows please post the information for me. I'd like to get a set of forged JE Pistons at 12.5:1 stock compression, but not if the stock pistons can actually handle at least 400 BHP or more. I'm not looking to make crazy power for my daily driver.
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
#39 |
As other have said don't boost unless your prepared to drop another or built engine in. Hell people have spun a rod/bearing in NA cars on the track.
2013 Series 10 FRS #553
#40 | |
Drives: 18 BRZ tS, 27 GRMN 86
1) Catless header + OP + high flow cat front pipe but with stock exhaust? 2) 2.5" Cat-back only Trying to minimize the noise but want to have less back pressure to have less knock events. Thanks! |
#41 |
Drives: brz 2017 hksv2
of course the catless is going to be better for knocks and power
the bigger catback will help by a very small %, and will be more noticeable with forced induction |
#42 | |
I certainly had no more or less knock events due to stock exhaust on the turbo. If you use an external wastegate and dump to atmosphere, you have a lot less backpressure but also when you're in boost past wastegate spring pressure, it's quite loud.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
| Slight engine stutter when AC is running? | select20 | Issues | Warranty | Recalls / TSB | 19 | 08-18-2016 11:46 PM |
| FRS Turbo, Supercharger or none? Trying to get 300HP. | Elliryx | Forced Induction | 22 | 09-06-2015 01:15 AM |
| 300HP Jackson Supercharged BRZ | neroman98 | BRZ First-Gen (2012+) — General Topics | 18 | 08-03-2015 07:28 PM |
| Car running poorly after check engine light cleared | AlexK | Engine, Exhaust, Transmission | 4 | 07-07-2015 03:16 AM |
| 300hp vs 380hp evo | sosick | Tracking / Autocross / HPDE / Drifting | 20 | 08-12-2014 07:35 PM |
