Old 12-08-2017, 04:10 PM   #29
Originally Posted by ZDan View Post
To be able to drive on plowed roads in RI/Mass through the Winter, while maintaining some handling precision. I was only looking at the "Performance Winter/Snow" category tires.
Glad to see you put that term in quotation marks. You can have one or the other but I have always found that the compromises were to great to have a real "Performance winter tire" no matter what they claim. The requirements for a good winter tire, that will make sure you arrive alive, almost totally eliminate the possibility of really good performance.
cjny (12-09-2017)
Old 12-09-2017, 01:07 PM   #30
churchx
churchx's Avatar
Drives: 2014 GT86
Tcoat: no, there are tires that are good winter tires and performance ones. Not road legal though . - So called "saws" in slang, long-studded sport tires. With such on some tracks opened all year round on ice often track lap records are better in winter then in summer on dry tarmac. Of course, such studs are not fit due grip & damage to pavement for normal plown tarmac roads .. but still, you get both performance & winter in one package
Old 12-18-2017, 11:17 AM   #31
ZDan
ZDan's Avatar
Drives: '23 BRZ
There is a pretty big difference in wet/dry capabilities of "Performance Winter" tires vs. studdable/non-studdable winters.
They give up very little in terms of snow/ice performance while giving much better wet/dry grip vs. the best non-"performance" winter tires.
https://www.tirerack.com/tires/tests...y.jsp?ttid=181
https://www.tirerack.com/tires/tests...y.jsp?ttid=193
Performance Winter tires:
50-0 mph Stopping (ft) wet, dry; cornering (g) wet, dry
Bridgestone Blizzak LM-60 136.3, 94.2; 0.58, 0.84
Dunlop SP Winter Sport 4D 105.9, 91.9; 0.75, 0.88
Michelin Pilot Alpin PA4 105.4, 88.8; 0.76, 0.89
Pirelli Winter Sottozero 3 106.9, 85.6; 0.78, 0.90
Studless ice and snow Winter tires
Bridgestone Blizzak WS80 128.0, 88.2; 0.61, 0.87
Dunlop Winter Maxx WM01 159.4, 97.6; 0.54, 0.81
Michelin X-Ice Xi3 131.4, 93.2; 0.63, 0.84
Yokohama iceGuard iG52c 148.8, 94.7; 0.55, 0.81
Old 12-18-2017, 11:26 AM   #32
Summary
Compared with Studless Ice & Snow winter tires, Performance Winter / Snow tires deliver better handling on clear roads along with improved wet and dry traction in winter's cold temperatures. The tradeoff comes with modestly lower ice and snow traction. But when winter weather strikes, Performance Winter / Snow tires still deliver better performance than the best all-season tires.
There is still a compromise. There is always a compromise. As stated they do beat the AS tires by a mile.
Old 12-18-2017, 12:14 PM   #33
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Summary
Agreed.
Until we're using different compounds that work within a fairly different set of criteria we are used to working within for tires, everything is a compromise with tires.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 12-18-2017, 02:00 PM   #34
churchx
churchx's Avatar
Drives: 2014 GT86
One needs to retrofit ship anchor auto-deploy system for emergency stops and keep driving on primacies all year round!
For milder stops parachute system should do too. Pitty it will cover front window of car following.
And all proper roads should have sidewalls, so that one can take curves by hitting them. Hey, it worked in Need For Speed! . As for roads that still have no concrete sidewalls - it's fault of government. Also blame Canada.
Old 12-18-2017, 02:21 PM   #35
Racecomp Engineering
My Blizzak WS-80s did good this weekend. No drama in about an inch or 2 of accumulation on the road. Easy to pull away from a stoplight on a hill, and easy to brake smoothly. Little bit of dorifto fun but not unexpected and they were super easy to control.
In the dry they're fine. It's still noticeable that it's a 205/55/16 winter tire but not annoyingly so IMO.
I was tempted by the General Artics, but there was a sale on the Blizzaks . And the dry performance was a selling point on the Bridgestones. We don't get much snow and when we do I can usually just stay home. I expect to have these tires on for about 3 months a year. The Michelin X-Ices were also tempting...Myles has them on his 2018 STI and really likes them. I think they were a tiny bit more expensive.
- Andrew
Old 12-18-2017, 04:15 PM   #36
ZDan
ZDan's Avatar
Drives: '23 BRZ
I just bought a '17 PP over lunch
I'm going to get the Pirelli Sottozero 3s in 225/45-17 for the stock 17x7.5 wheels. 0.90-g capability at 40F plus snow/ice functionality looks like the best compromise for me.
Racecomp Engineering (12-18-2017)
Old 12-18-2017, 04:36 PM   #37
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
That's my kind of lunch!
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
ZDan (12-18-2017)
Old 12-19-2017, 12:58 PM   #38
mnuttall
Drives: 2013 Audi Allroad, 2017 Subaru BRZ
The Pirellis are a good choice. We've got them on our Audi and they work great.
mnuttall is offline   Reply With Quote
Old 12-20-2017, 08:08 PM   #39
JMon85
JMon85's Avatar
Drives: 2019 WRX
205/50/17 Continental Wintercontact Si ~ Love these things^^
JMon85 is offline   Reply With Quote
Old 12-20-2017, 09:45 PM   #40
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I've been using General Altimax Arctics for years now here in Chicago.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
Hyper4mance2k (12-22-2017), JMon85 (12-21-2017)
tires, tires and wheels, tires help, winter
SOLD CB390248 Wheels and Tires 65 09-12-2019 11:30 AM
Winter Tire setup DVNARC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-17-2015 02:17 PM
TRADE: Winter Tires+Wheels+Cash for OEM Setup harkbrz Canada Classifieds 0 12-13-2014 09:24 PM
Winter setup cnk NY / NJ / CT / PA 72 12-13-2012 09:48 PM
