Old 07-07-2017, 05:15 PM   #29
Last Lemming Alive
Drives: WRB 2017 BRZ Limited w/ PP
Originally Posted by DarkSunrise View Post
Could it be that you're not yet used to the increase in sound at part throttle?
In other words, it's now much louder under load without any corresponding increase in speed, tricking you into thinking the car has gotten slower.
The reason I say this is I've got the 2.5" Perrin and didn't notice any loss in low-end torque, but it is definitely much louder under load.
Let me explain what's exactly happening: I start to accelerate normally, the engine gets to 2000 rpm and then it's like the fuel cuts for an instant, the engine falls flat on its face and then it picks back up and gets going. I've tried modulating the throttle to no avail. It's like the fuel map isn't keeping up. That is just what it feels like. You could also say it feels like a bog of the engine at 2000 rpm.
The only way I am able to overcome it is to launch off the line and make sure the rpm don't fall to 2k. Btw, the car has 2400 miles on it.
Last Lemming Alive is offline   Reply With Quote
Old 07-07-2017, 07:08 PM   #30
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Interesting. Almost sounds like you are hitting the torque dip extremley early. Torque dip suually shows up at like 3500 RPM. However the new 17 MY torque dip while smaller, is also drastically deeper. I didnt really notice the torque dip on my 16 but when i test drove a 17 it was super obvious
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 07-07-2017, 07:56 PM   #31
modbus
Drives: '14 BRZ | '95 Range Rover
I have the Perrin 2.5" resonated. I went to it after about 5k miles on the car. I put the stock back on for a while and it "felt" faster than I remember.
I'm going to guess that my perception of "loud = fast" was leading me to believe the car was faster when the stock catback is attached vs. when I had my catback.
The mind is a powerful thing... and can lead you to the wrong conclusions if real instruments to measure are not used.
modbus is offline   Reply With Quote
Old 07-10-2017, 09:47 AM   #32
wparsons
wparsons's Avatar
There's simply no way a cat-back alone is doing that unless you've got something totally blocking it like a piece of plastic or packaging.
flickr
Old 07-11-2017, 06:21 AM   #33
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I wouldn't believe a lot their dyno graphs. Most legal catbacks cannot increase power. If you had any gains, the noise would be so much that it would not pass any regulations. Your only chance to get any gains is if you install a competition exhaust.
Old 07-11-2017, 10:49 AM   #34
wparsons
wparsons's Avatar
That's simply not true. See the thread on the ACE Laguna Seca exhaust.
flickr
Old 07-11-2017, 11:34 AM   #35
Icecreamtruk
Drives: Track preped NA FRS
That exhaust doesnt gain you power, it just doesnt take power (or little) and reduces sound.
Old 07-11-2017, 11:38 AM   #36
wparsons
wparsons's Avatar
Compared to what? It makes more power than stock and isn't as loud as other exhausts with comparable gains.
flickr
Old 07-11-2017, 11:56 AM   #37
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
I reinstalled the OEM exhaust tonite, and even without unplugging it the torque was back. It feels like 7-10 ft lbs was gained.
Perhaps this is your answer and your solution.
Scrappydoo is offline   Reply With Quote
Old 07-11-2017, 12:03 PM   #38
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Based on this, I'd be concerned about an exhaust leak with the Perrin.
Lynxis is offline   Reply With Quote
Old 07-11-2017, 12:13 PM   #39
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Instead of guessing why not contact Perrin....just my two cents
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 07-11-2017, 12:50 PM   #40
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
That's what it says here: http://counterspacegarage.com/ace-cs...na90-gt86.html
"CSG commissioned a project with ACE to provide a Laguna Seca legal exhaust that emits an output of under 90dB without considerable loss of power or response. "
Anyway, I would never install a Taiwanese exhaust in my car. Personal preference. Sorry.
Old 07-11-2017, 01:10 PM   #41
humfrz
Yep, my take is that if you do enough dyno pulls, on enough dyno machines, you can generate enough graphs to show almost anything ........ just pick one ......
humfrz
Old 07-11-2017, 01:14 PM   #42
Icecreamtruk
Why dont you ask them that? Where do you see it makes more power than stock and has comparable gains? Comparable to what?
See, two can play this game. The ACE Laguna 90 is an exhaust for really low sound output, nothing more, nothing less.
FS: Perrin 3" Intake, Torque Solution engine mounts jonesy Engine, Exhaust, Bolt-Ons 4 01-10-2017 04:03 PM
FS: Perrin 3in Catback Exhaust, Perrin 3in Front Pipe, Perrin Overpipe SOLD johnb831 Engine, Exhaust, Bolt-Ons 13 05-21-2015 05:27 PM
FS: Short Antennas: Craven Speed, Perrin and Torque Solutions BRZNutt Exterior Parts (Aero, Lighting, Etc.) 6 03-12-2014 03:42 PM
Exhaust torque specs Prowl647 Engine, Exhaust, Transmission 0 08-13-2013 12:57 PM
Does Perrin catback exhaust LOSE torque? wbsrazzle Engine, Exhaust, Transmission 23 04-30-2013 08:32 PM
